Old 01-16-2011, 05:45 PM   #586
Vicko's Avatar
Trader Rating: 14 (100%+)
416X with the exotec chassie... but I just order the 417
Vicko is offline   Reply With Quote
Old 01-16-2011, 08:50 PM   #587
i ran the same. Next week i will run the 417 in open
M3dreamin2008 is offline   Reply With Quote
Old 01-17-2011, 12:09 AM   #588
carborush's Avatar
Originally Posted by Chris Furman View Post
Anyone run the Tamiya Type-C carpet tire yet? I have a set I am going to try tomorrow.. I wonder who makes the tire for Tamiya.
i just got the type C's in from post
they seem a bit on the loose side ?! compared to the type A's.
i'ts not a tight fit around the beed of the wheel
+ once mounted and glued you can feel some "open space" between tire and foam.
normal or is something wrong ?
carborush is offline   Reply With Quote
Old 01-17-2011, 06:14 AM   #589
slakr's Avatar
Trader Rating: 28 (100%+)
Does the kit come with front spool & rear diff?
Another question I have is regarding using steel swing shafts... I believe I have read on here that some are using 44mm and some are using 46mm. I am confused. I think stock are 44mm (front & rear) aluminum. So is the recommendation for steel in the front only (or rear as well) and should it be 46mm or 44mm?
TLR 22 4.0, 22-4 2.0, 8IGHT & 8IGHT-E 4.0~XRAY XB2C~AE TC7.1
Tim aka "slakr" ROAR No. 3-119960
slakr is offline   Reply With Quote
Old 01-17-2011, 06:55 AM   #590
Bad-Andy's Avatar
Originally Posted by slakr View Post
Does the kit come with front spool & rear diff? Yes
Steel front, and I've been using 44mm in mine. No problems with length even switching to a 1E/1D front suspension block configuration (Max width)
Bad-Andy is offline   Reply With Quote
Old 01-17-2011, 07:30 AM   #591
44mm are fine, same with 46mm. What the 46mm will do is make your spool cups last longer. They sit deeper into the cup where the cup is strongest, less chance of the plasitic cracking and breaking.
malkiy is offline   Reply With Quote
Old 01-17-2011, 08:58 AM   #592
EDWARD2003's Avatar
Default Few Q's
Just have a few Q's towards the 417. For carpet racing only.
First off, the 0.5 suspension mount shims - Is it worth taking them out and running zero spacers? What would this do towards handling? Would it make the car to planted?
Shock rebound- I've talked to a few guys and some say run 0% rebound, 20% 50% or 100%.. What would be best for high traction indoor carpet? Does the type of motor have an effect on choosing this setting?
Loosing the top deck- I know it sounds crazy to loosen the top deck, but there are a few guys running Tamiya sedans who've done this and works perfectly. What would problems could arise from this?
Spur gear- I assume Tamiya designed this sedan under the conditions for modified racing? I recognize that there are other spur gear manufactures out there, however I found Tamiya spurs are much quieter than after markets.
Weight balance- I know everyone is running different electronics but I assume there will be a general consensus on weight placement (i.e lead weights). How much and where should it be placed.
Right now I'm running a 13.5 no-boost, what would be a good ratio? Below 4.5 fdr? Any one use roll out with rubber tires as a gearing measurement?
Cheers,
Edward
EDWARD2003 is offline   Reply With Quote
Old 01-17-2011, 06:40 PM   #593
Vicko's Avatar
Hey ask Karl for his set up , his 417 looked really good maybe for boosted
Old 01-17-2011, 06:56 PM   #594
KHoff7's Avatar
Thanks Vic...It was pretty good for the first day out with it at The C. Will try to make it better in February, I plan on being there a lot more.
Awesomatix USA / Middle River Hobbies / Sweep / Psycho Cells Racing
Karl Hoffmeister
KHoff7 is offline   Reply With Quote
Old 01-17-2011, 07:21 PM   #595
Trader Rating: 19 (100%+)
Bring it in and run mod rubber at the c with us, we are trying to get the class started. We have three people for this weekend but want to see it grow a little bit. Your car looked awesome on saturday!
★Randy Banks★
COLD AS ICE is offline   Reply With Quote
Old 01-17-2011, 07:29 PM   #596
KHoff7's Avatar
Thanks man, Ill be in around the end of February since this week is snowbirds and then a big offroad race the 2nd week of February.
Karl Hoffmeister
Old 01-17-2011, 08:40 PM   #597
Trader Rating: 31 (100%+)
Hi All,
Has anyone tried using the Photon's one-piece thrust bearing on their 417? I measured the 417 thrust washers and the inner diameter is 2.6mm and the outer diameter is 6mm, so it looks like it may work....
http://www.redrc.net/2011/01/t-o-p-p...-fd-gear-diff/
Thanks!
ittjv is offline   Reply With Quote
Old 01-17-2011, 08:54 PM   #598
hey Karl
would you mind sharing your set up?
Old 01-17-2011, 09:00 PM   #599
Are you guys really going to run run open? Would you mind if a slow guy like myself joined in? Reggie said he wanted to run foam mod, but i just like the idea of running super fast
Old 01-17-2011, 09:56 PM   #600
syndr0me's Avatar
Trader Rating: 32 (100%+)
My 417 is ready to melt faces at Snowbirds! The way it handled at the track today was... sublime. This is a fantastic car.
syndr0me is offline   Reply With Quote
Saudi Arabia RC Club grizzle Manila Racers 6558 01-06-2017 08:50 AM
Tamiya TRF415 JDM_DOHC_SiR Electric On-Road 21094 03-10-2016 11:02 AM
Tamiya TRF416 / TRF416WE / TRF416X academygaz Electric On-Road 10619 01-01-2015 03:36 PM
Tamiya TA05 IFS rcforum Electric On-Road 1132 12-18-2014 05:19 AM
"Ask" Jilles Groskamp Tamiya 416 & 417, Team Orion Motors JGH Electric On-Road 1996 05-27-2014 06:28 AM
