Old 08-31-2013, 04:50 AM   #5851
CraigM's Avatar
Trader Rating: 34 (100%+)
Originally Posted by Typeone View Post
Good to know how does the conversion handles with the motor more towards the middle yokomo ant3?
Moving the motor inwards makes the direction change much sharper. The different top deck increases overall grip and improves the way the car turns in. I really like the smokem conversion, it's cheaper and more elegant than the raceberry set and maintains the 417 belts and centre shaft
www.facebook.com/mcpheerc
CraigM is offline   Reply With Quote
Old 08-31-2013, 05:23 AM   #5852
Losiho's Avatar
I just emailed in my pre-order for the new Smokem V7 kit and an extra top deck
Losiho is offline   Reply With Quote
Old 08-31-2013, 08:20 AM   #5853
C van der Hagen's Avatar
SRP motormounts are in stock now.
Topdeck expected next week.
C van der Hagen is offline   Reply With Quote
Old 08-31-2013, 09:59 AM   #5854
Typeone's Avatar
Trader Rating: 30 (100%+)
Ok thanks Craig are u a planning on getting a v7 kit?
Typeone is offline   Reply With Quote
Old 08-31-2013, 01:46 PM   #5855
Potoczak's Avatar
Trader Rating: 109 (100%+)
Link please.
Pete Potoczak
Home entertainment specialist
Secure Technologies/ www.stiworldwide.com
Potoczak is offline   Reply With Quote
Old 08-31-2013, 01:55 PM   #5856
OnRDPassion's Avatar
Trader Rating: 54 (100%+)
Wow its only $75!!! I am definitely picking up one despite what I said earlier
Jay Williams
Xray RX8 2014
RC America - Protoform Racing - KO Propo USA - Kevco Racing / Picco EDO Modified - Byrons Fuels
OnRDPassion is offline   Reply With Quote
Old 08-31-2013, 02:57 PM   #5857
CraigM's Avatar
I already have it
Old 08-31-2013, 11:57 PM   #5858
Super Moderator
Grizzbob's Avatar
Hope I'm not missing anything obvious, but are there any US shops that sell the Smokem stuff? Or does Somkem sell directly? This V7 kit is piquing my curiosity....
Bob Seay
Tamiya TRF417, TA05v.2, TRF211XM, M-05ver.2R, XRAY X12, Associated B5m Factory Lite
Go Pokes!!!
Grizzbob is offline   Reply With Quote
Old 09-01-2013, 05:57 AM   #5859
Originally Posted by Potoczak View Post
Link please.
https://www.facebook.com/SepesRacingProducts
Old 09-01-2013, 01:01 PM   #5860
Typeone's Avatar
I'm having issues with traction roll. I have a high roll center setting running 32.5wt shock oil with hpi silvers in front and hpi blues in rear with no roll bars in front and rear and ride hight set at 5.5 with 3 degree of tow in the rear. Any suggestions would putting the roll bars back on would this help the car from not traction roll. Btw I'm running 17.5 blinky on a med/high traction asphalt track.
Old 09-01-2013, 01:17 PM   #5861
Disclaimer: I've never owned/driven a Tamiya.
That being said, that setup sounds like a recipe for traction roll. No sways with soft springs will let the car roll a lot. High roll centers will make the inside lift up more. Soft shock oil will let the car cut in hard and generate a lot of rolling momentum. Do you also have a lot of droop?
-Mike
Old 09-01-2013, 01:41 PM   #5862
Typeone's Avatar
No ruining 5mm in front and 4mm in rear. I think ima try the car with the sway bars on if not ima prob just go back to a longer link so lower roll center see if that helps. Also I'm running sweep 32's prob if I go to 36's I think it might help.
Old 09-01-2013, 03:31 PM   #5863
Jochim_18's Avatar
Tim,
I would go 40wt all the way around and put the stock sway bars back..
Localrcracing.com - Your premiere source of Radio controlled Racing in central California.
Visaliahobbies.com * SkyRC * casterracingparts.com
Old 09-01-2013, 03:32 PM   #5864
CraigM's Avatar
^^ that is a lot of droop
Old 09-01-2013, 03:37 PM   #5865
Typeone's Avatar
What would u recommend Craig?
Saudi Arabia RC Club grizzle Manila Racers 6558 01-06-2017 08:50 AM
Tamiya TRF415 JDM_DOHC_SiR Electric On-Road 21094 03-10-2016 11:02 AM
Tamiya TRF416 / TRF416WE / TRF416X academygaz Electric On-Road 10619 01-01-2015 03:36 PM
Tamiya TA05 IFS rcforum Electric On-Road 1132 12-18-2014 05:19 AM
"Ask" Jilles Groskamp Tamiya 416 & 417, Team Orion Motors JGH Electric On-Road 1996 05-27-2014 06:28 AM
