Like Tree1Likes
Old 08-12-2013, 03:00 PM   #5761
Mr.juarez's Avatar
Trader Rating: 37 (100%+)
Default picked up a new 417!
new to tamiya and happy to have finally jumped wagons from ae
been looking to some set ups, but not sure which one is the one that seems to work the best or which one everyone prefers.
i got the 417 with gear diff 2. i started building the car, but i havent gotten to the shocks yet. i put 2k diff oil in rear and went with the spool up front until i can get a gear diff for it or see if i like the spool.
track is mid-high grip outdoor asphalt and bumpy. was thinking of 37.5 front and 32.5 rear?
TRF-417, KYOSHO SCR-SP
Mr.juarez is offline   Reply With Quote
Old 08-12-2013, 09:35 PM   #5762
vivo quevas's Avatar
Trader Rating: 18 (100%+)
I think 2k is too much for our track I recomend going 1k an I tried 35w in the front shocks and then Tim drove my car and said I should go 32.5w in fhe front and 30w in rear.
If I was you I would copy Justin's setup his 417x is so easy to drive fast. I copied it on my car and my car drove great in the main I was down on low and midrange power to chris and steve but the car drove really good! 417's drive so much better then my 6.1 you know I haven't got around the track with any speed since I bought a 6.1 3 month's ago!
Awesomatix A800 USGT, Awesomatix 800 VTA, , Tamiya Euro Truck, CRC WTF1
http://localrcracing.freeforums.org/
HobbyTown Fresno, Ca. McAllister Racing, Visa/MasterCard's
vivo quevas is offline   Reply With Quote
Old 08-12-2013, 10:54 PM   #5763
Mr.juarez's Avatar
Where do I download it or I have to go in the shop and copy it? Do you know if they got 1k in the shop? My tc6.1 has 32.5 front and rears but I was thinking going a stiffer spring in back and #3 piston.
So from what I'm reading with the 417 go with.
35 front
30 rear
What piston?
Hpi silver (can't get them this week) so I got the tamiya with thw stiffer ones)
Whites fronts with blue rears?
Old 08-12-2013, 11:10 PM   #5764
-jacob-'s Avatar
so could anyone here tell me which is the best 417 out of the box for TCS GT1 Class legal?
is it the X or the V5
www.teameamotorsports.com
www.seattlercracers.com
-jacob- is offline   Reply With Quote
Old 08-12-2013, 11:45 PM   #5765
Racing4Evo's Avatar
Send a message via AIM to Racing4Evo
V5. Easier to drive.
Racing4Evo is offline   Reply With Quote
Old 08-13-2013, 12:34 AM   #5766
IN10CT's Avatar
Default Alternative spool cups
Anyone know good alternative spool cups that can be used in the v5? Can't seem to locate any Tamiya ones in stock anywhere...
IN10CT is offline   Reply With Quote
Old 08-13-2013, 02:38 AM   #5767
narcotiks's Avatar
Arena spool cups from rc market.
They have 4 slots on each outdrive so double value for money
narcotiks is offline   Reply With Quote
Old 08-13-2013, 08:48 AM   #5768
roche im pretty sure make spool cups
rayrush is offline   Reply With Quote
Old 08-13-2013, 08:57 AM   #5769
George I would try the car with the stock springs. I just went to the shop an looked at justins car an asked him many questions. He doesn't run split blocks in the front i bought a solid c block to replace my split blocks an moved the solid b block to replace the split b blocks. My has .05' of arm sweep in it. Use the stock pistons an after you have a handle on the car make changes one at a time. Richard made too many changes last week and you see his car went from very driveable to loose!
35 front
30 rear
What piston?
Old 08-13-2013, 10:16 AM   #5770
Yep, too many changes but it was a test night so no big deal, although, I do think a fresh set of tires would have helped. I may start putting on new ones every other race instead of when I think they are worn out.
Richard G.
Tamiya...
dizope is offline   Reply With Quote
Old 08-13-2013, 10:24 AM   #5771
I stripped a side gear (pin side) and bent the shims in a brand new diff II using Ride 45 putty. Do I need metal gears for this putty or did I just overfill it?
Also, the long outdrive has a lot of play when only using the supplied 3 shims. The diff that came with the v5 kit didn't have this kind of play.
Richard G.
Tamiya...
Old 08-13-2013, 11:40 AM   #5772
I would recomendgettig that Tamiya puddy from me it works just fine in the 3 cars I have it in. I have plastic gears in my diff. My car drove really good last week qhen you can lap chris and steve the car worked good! I am making no changes thisweek i got a setup station an my car was off on toe an camber. So we will see if that makes the car drive better.
Old 08-13-2013, 11:57 AM   #5773
Mr.juarez's Avatar
Ill go pester the crap out of him today!!! bringing blank paper and pen!!
Old 08-13-2013, 01:03 PM   #5774
bobbyvegas's Avatar
Default Just picked up 417
Will be running 17.5 stock spec (no boost etc) for a little carpet and asphalt. Got a question or 2.
Originally Posted by Csaari77 View Post
Don't bother with trying to find Tamiya spurs that size. I'm pretty sure they don't make them for the 417. RW racing V2 spurs work really well. You can get them through Speedtech RC.
Thanks for this tip, and the link (spent some $$'s). Did not like the idea of drilling holes in my spur.
Originally Posted by JoeyE View Post
17.5 Blinky I run 90T RW Racing V2 spur with a 43 pinion. FDR is around 4.
I have not run the car on track yet, but starting with a FDR of 3.744 (100/52) should be ok? Is the FDR of 4 a starting point or is that your preference due to track layout??
Also, what gear diff oil wght in rear should I use/start with?
2011 iic Poker Champion
bobbyvegas is offline   Reply With Quote
Old 08-13-2013, 03:39 PM   #5775
CraigM's Avatar
Trader Rating: 34 (100%+)
Actually you bent shims and then stripped the sun gear. The issue is the shims Use 0.3mm shims (like TDX) and always use metal gears with putty. You can shim the outside of the outdrive to get the play nice
www.facebook.com/mcpheerc
CraigM is offline   Reply With Quote
Saudi Arabia RC Club grizzle Manila Racers 6558 01-06-2017 08:50 AM
Tamiya TRF415 JDM_DOHC_SiR Electric On-Road 21094 03-10-2016 11:02 AM
Tamiya TRF416 / TRF416WE / TRF416X academygaz Electric On-Road 10619 01-01-2015 03:36 PM
Tamiya TA05 IFS rcforum Electric On-Road 1132 12-18-2014 05:19 AM
"Ask" Jilles Groskamp Tamiya 416 & 417, Team Orion Motors JGH Electric On-Road 1996 05-27-2014 06:28 AM
