Like Tree1Likes
Old 08-08-2013, 03:46 AM   #5746
CraigM's Avatar
Trader Rating: 34 (100%+)
Originally Posted by Velocitygt View Post
Looks like a DCJ will fit through!
I thought that as well. If true I bet you'll run them even when the 4 deg hubs would be faster
www.facebook.com/mcpheerc
CraigM is offline   Reply With Quote
Old 08-08-2013, 06:48 AM   #5747
Csaari77's Avatar
Originally Posted by Smartypants View Post
Were you looking at the same photo lol
Yes I was, were you? The bodies look about the same size as the mini shocks and the shaft length is about the same. The only difference might be the height of the top cap. I don't have a set of the mini shocks handy to compare to my TC shocks. Is there anyone out there that can compare the TC & the mini TRF shocks side by side?
Half-A$$ Racing - Problem solved, problem staying solved!
Awesomatix - Serpent - Tekin - Futaba - Cooper Motorsports.
Csaari77 is offline   Reply With Quote
Old 08-08-2013, 07:28 AM   #5748
FYI Mini shocks have alot shorter body and shaft compared to a tc shock hence why they run a shorter spring
Smartypants is offline   Reply With Quote
Old 08-08-2013, 07:42 AM   #5749
Csaari77's Avatar
I know, and that is what the picture shows. The body on the left is 2-3mm shorter and the shaft is shorter. That's why the shockcollar is all the way at the top compared to the shock on the right.
Judging by the comparison picture, the shaft is shorter, the body is shorter, and the cap is shorter. Everything fits with a mini shock, my only question is the cap height on the mini shocks.
Old 08-08-2013, 08:01 AM   #5750
The shocks in the pic have a shorter shaft and a smaller cap, but the cylinder is the same.
As to the 6deg C-Hubs I want them already, I do run more caster to calm the front end but I would rather it be in the C-hub not along the whole suspension arms.
http://www.theRcRacer.com/
TRF419, TBEvo6, TT02, VDF, TRF501x, TRF201, TRF101, Mi5, X-Ray T4-13, BD7 2014, A700 Evo, WR-02G
Qatmix is offline   Reply With Quote
Old 08-08-2013, 08:05 AM   #5751
vivo quevas's Avatar
Trader Rating: 18 (100%+)
Would you use the raceberry lowered shock mounts or is there a tamiya low profile shock mount?
Awesomatix A800 USGT, Awesomatix 800 VTA, , Tamiya Euro Truck, CRC WTF1
http://localrcracing.freeforums.org/
HobbyTown Fresno, Ca. McAllister Racing, Visa/MasterCard's
vivo quevas is offline   Reply With Quote
Old 08-08-2013, 08:41 AM   #5752
Csaari77's Avatar
Look at the picture again. The flange on top of the shock bodies are inline in the picture. The bottom caps on the shocks are not. The shock on the right has a longer body by a few mm. The odd angle of the picture doesn't make it easy to see the difference, but it's there.
Old 08-08-2013, 09:19 AM   #5753
Hebiki's Avatar
Trader Rating: 26 (100%+)
To help you guys out a little bit....
Hebiki Design Works
Custom R/C Vinyl Graphics & Apparel: Your gear, your way!
Web Design - Web Development - Logo Design - Graphic Design
www.facebook.com/HebikiDesignWorks
Hebiki is offline   Reply With Quote
Old 08-08-2013, 10:27 AM   #5754
You just saved me doing that however that should show that its not the mini shocks.
Old 08-08-2013, 11:14 AM   #5755
I still am looking for an answer for what your mounting those mini shocks too?
Old 08-08-2013, 03:00 PM   #5756
CraigM's Avatar
There's no answer yet. Maybe the raceberry tower will work, or tamiya will bring out new towers IF they release these shocks for the 417(8)
Old 08-08-2013, 03:04 PM   #5757
CraigM's Avatar
OK so the shock body appears the same, unless the top thread is smaller to accommodate the bladder under the lower cap. At the bottom the spacer arrangement must be different to fit into a smaller space
Old 08-09-2013, 08:20 AM   #5758
NItrox416's Avatar
however I think that we could already modify the standard shocks,
for an experiment I manage to reach a length of 55mm.
NItrox416 is offline   Reply With Quote
Old 08-10-2013, 12:04 PM   #5759
Outdoor parking lot asphalt track. Washed, blown off and sprayed with soda. How many heats should a set of tires last? I'm using APS Sorex 32's.
Richard G.
Tamiya...
dizope is offline   Reply With Quote
Old 08-10-2013, 01:49 PM   #5760
Sealed asphalt surface treated with Snowcone syrup.
I have been getting 5 raceday's off my sorex 32. Replace tires once a month. I don't think it is the tires worn out maybe too many setup changes, your car was working really good last week! Went out today drove Steves xray t4 it didn't have as good of midcorner steering as my 417 it was interesting! Now I need more hp for my 417. It was good driving a car that works good drives well. I almost felt like a good driver again!
Saudi Arabia RC Club grizzle Manila Racers 6558 01-06-2017 08:50 AM
Tamiya TRF415 JDM_DOHC_SiR Electric On-Road 21094 03-10-2016 11:02 AM
Tamiya TRF416 / TRF416WE / TRF416X academygaz Electric On-Road 10619 01-01-2015 03:36 PM
Tamiya TA05 IFS rcforum Electric On-Road 1132 12-18-2014 05:19 AM
"Ask" Jilles Groskamp Tamiya 416 & 417, Team Orion Motors JGH Electric On-Road 1996 05-27-2014 06:28 AM
