Old 07-27-2013, 05:21 AM   #5716
C van der Hagen's Avatar
Originally Posted by CraigM View Post
Not true, they are 64 pitch
Not true, they are 0.4 module. See TRF417V5 box sleeve.
64dp and 0.4 module gears are not interchangeable!!
C van der Hagen is offline   Reply With Quote
Old 07-27-2013, 06:16 AM   #5717
Skitee's Avatar
That's also not true, the 0.4 module and 64dp is that close that you can run them together. I've used my tamiya pinions on 64dp spurs for a number of years , So I KNOW that they work together without reliability issues. 48dp and 0.6 module on the other hand do not work together.
Xray T4 2017 ~ ORCA Vritra VX3 ~ Motiv RC 4.5
Xray T4 2017 ~ ORCA Vritra VX3 ~ R1 Wurks 13.5
Xray X12 2016 ~ ORCA Vritra VX3 ~ Orca TX 4.5
POWERED BY SPEEDZONE USA
Skitee is offline   Reply With Quote
Old 07-27-2013, 07:11 AM   #5718
RedBullFiXX's Avatar
Trader Rating: 34 (100%+)
+1
--> 12th scale Information Source <--
"Men do not quit playing because they grow old; they grow old because they quit playing."
― Oliver Wendell Holmes Jr.
Old 07-27-2013, 06:39 PM   #5719
CraigM's Avatar
Originally Posted by vivo quevas View Post
Is this true by using B blocks reducing track width will increase steering?
Yes and no, it definitely makes the car more twitchy, I find wider like C/C has more mid corner steering and steers more "round" in corners. I always start with C/C XA/E and go from there, and I always use split blocks front and rear
Originally Posted by dizope View Post
I have been running AE 40wt shock oil (500 cst) in the rear diffs. This works fine for the TC6.1.
Okay. Ordered AE 2k diff oil and HPI silver springs yesterday. Ran out of time to order the large springs cups but am going to now.
Should I order any suspension blocks?
What do you mean lower the bottom arm roll center to 0mm/0.5mm?
The TC6 diff has a much lower volume than the TRF diff, so you need to use a much thicker oil in your TRF diff
In the suspension you have 2 places you can change the roll centre. Upper arm by changing the camber link shims and lower arm by changing the spacing under the suspension blocks. 0mm/0.5mm means you'll have no spacers under the FF block and 0.5mm (kit) spacing under the FR split blocks.
See above about the blocks I run
Originally Posted by DPRacing View Post
hi guys, have a few questions about the shocks (417x basic)
- Which O-rings are recommendable? Tamiya # 42137 O-ring or X-ring #42214? or what is the difference?
Or O-rings other manufacturers?( I read a few years time, Jilles drive Muchmore o-ring 50) .
- build with one o-ring + shaft guide or 2 o-rings?
- what advantage brings a downstop O-Ring?
Thanks for answer!
Shaft guide and 1 x ring. I can never remember which x-ring to use, someone else will chime in. It can help to use shims to squeeze the x-ring for a better seal. I haven't seen a downstop o-ring used in years on the tamiya, the team used to sometimes run it on carpet to stop traction roll
I was able to get some more throw out of the servo last night by extending the EPA to 150% (R) and 125% (L). It was at 100% previously.
I installed the servo saver per the manual, one tooth (5*) to the left with the servo in neutral. I built the servo turnbuckle with a 4.5mm gap, like the manual recommends.
I read earlier in this thread where someone else went from a Savox 1258 to a 1251 and had the same lack of throw problem.
All of my other models have 1258's and don't need past 100% EPA. I use an Airtronics MT-4 transmitter.
I used an angle finder to set the throw to roughly 27 degrees (~1mm) from the c-hub. In doing this, I realized the left side has more throw than the right side. Trim is at zero. Subtrim is at R20. REV is normal.
With the EPA extended, I now have a tighter turning radius but is that the correct fix or do I have some other mechanical issue.
I can't really comment on your servo, but as long as you can get full throw you're good. My subtrim is about the same. Here's how I mount my servo horn, with right angle to the link
www.facebook.com/mcpheerc
CraigM is offline   Reply With Quote
Old 07-28-2013, 08:38 AM   #5720
narcotiks's Avatar
With silicon oil you run the 50x o-ring and with mineral oil(TRF) the 70x ring The competition blue ring works well too, it seals a little better than the x-ring but the x-ring gives the smoothest action.
What shims do you use Craig? I've only got 0.1 in, i tried with 0.2 but it wasn't as smooth.
narcotiks is offline   Reply With Quote
Old 07-28-2013, 03:21 PM   #5721
CraigM's Avatar
.4 with the x-rings
Old 07-29-2013, 10:43 AM   #5722
Craig, thanks for the help. I ran the car this weekend and it was night and day better with the additional steering throw.
Richard G.
Tamiya...
dizope is offline   Reply With Quote
Old 07-29-2013, 06:58 PM   #5723
nolo148's Avatar
What is the largest 48p spur that will fit on the 417x?
nolo148 is offline   Reply With Quote
Old 07-31-2013, 06:38 AM   #5724
Csaari77's Avatar
I'm currently running my camber links in the longest position front and rear. The car is very stable and easy to drive but I'm trying to get it to transition faster from corner to corner. Will shortening the links improve the transition speed? If I shorten the links will I need to make adjustments to the roll center to maintain the stability that I have?
Half-A$$ Racing - Problem solved, problem staying solved!
Awesomatix - Serpent - Tekin - Futaba - Cooper Motorsports.
Csaari77 is offline   Reply With Quote
Old 07-31-2013, 07:10 AM   #5725
Shortening links will transition faster from corner to corner, The middle hole is the best allround option for most tracks
Smartypants is offline   Reply With Quote
Old 08-02-2013, 04:31 AM   #5726
I have to say i really like the 417v5. coming from a t3 the tamiya is really smooth and consistent.
rayrush is offline   Reply With Quote
Old 08-03-2013, 02:05 PM   #5727
NItrox416's Avatar
At euros I haven't seen any upgrades on the car, despite the fact that marc as well as jilles feel that the car is very inconsistent.
We can expect a competitive 418 or not?
NItrox416 is offline   Reply With Quote
Old 08-03-2013, 02:28 PM   #5728
syndr0me's Avatar
Trader Rating: 32 (100%+)
Tamiya needs to make a strong move with their next kit, that's for sure.
syndr0me is offline   Reply With Quote
Old 08-03-2013, 03:07 PM   #5729
Potoczak's Avatar
Trader Rating: 107 (100%+)
+1
Pete Potoczak
Home entertainment specialist
Secure Technologies/ www.stiworldwide.com
Potoczak is offline   Reply With Quote
Old 08-04-2013, 03:35 AM   #5730
CraigM's Avatar
So you haven't seen the new tamiya motor mount? Chassis? Top deck?
Are you not competitive with your current car? If so do you blame the car? I made RROC and AOC A-mains with this car. There's nothing wrong with it
Saudi Arabia RC Club grizzle Manila Racers 6558 01-06-2017 08:50 AM
Tamiya TRF415 JDM_DOHC_SiR Electric On-Road 21094 03-10-2016 11:02 AM
Tamiya TRF416 / TRF416WE / TRF416X academygaz Electric On-Road 10619 01-01-2015 03:36 PM
Tamiya TA05 IFS rcforum Electric On-Road 1132 12-18-2014 05:19 AM
"Ask" Jilles Groskamp Tamiya 416 & 417, Team Orion Motors JGH Electric On-Road 1996 05-27-2014 06:28 AM
