Old 07-17-2013, 07:56 PM   #5656
I just purchased a 417v5 as my first electric touring car. I plan to assemble within the next few days. Any suggestions on gearing, base setup, and hops/spares recommended? I'll be running on a small, tight indoor carpet track and will start with 17.5 blinky. Thanks in advance for any help.
cwood0714 is offline   Reply With Quote
Old 07-18-2013, 12:25 PM   #5657
Skitee's Avatar
Originally Posted by NovakSA View Post
Hi guys, I am really struggling to get steering out of my 417X for our Tamiya Cup race this weekend coming. We have to run either A or B compound tamiya tires and only Tamiya parts as you all know. My car just seem to grain the front tires,but I have to really back off the throttle to get the car to turn on power and off power. Does anybody have a setup for these crappy tires. We run the Tamiya 18T system and gear them 51T/90T. The track is tight and narrow with banked and off camber turns. Will a tire additive help? I am so frustrated.
Attached the setup as requested.
There are a few things you could change which should get you more steering...
Curious as to why you're running 2 degrees of front toe, 1 degree inboard from the 1e/1c blocks and 1 degree outboard. Generally you don't need the arm sweep / inboard toe, so try 1c/1c or 1b/1b as suggested previously.
You're running the front wheelbase longer with the 2.5mm behind the front arms, try running 1mm behind the front arms and the rest in front of the front arms.
3 degrees of toe at the rear is a little excessive for your class(18T), I suspect this is just locking the rear down too much and ploughing the front end through the corner.
There's also no need to run different inserts in the front and rear tyres, in my opinion this messes with the balance and again creates more traction at the rear than the front. Lose the A's and bring them out of the box when it's really cold, B3's are a much better and more consistent tyre.
Xray T4 2017 ~ ORCA Vritra VX3 ~ Motiv RC 4.5
Xray T4 2017 ~ ORCA Vritra VX3 ~ R1 Wurks 13.5
Xray X12 2016 ~ ORCA Vritra VX3 ~ Orca TX 4.5
POWERED BY SPEEDZONE USA
Skitee is online now   Reply With Quote
Old 07-18-2013, 07:27 PM   #5658
VooDooPH's Avatar
Trader Rating: 18 (100%+)
Send a message via Yahoo to VooDooPH
Originally Posted by 2-Bad View Post
Just one thing VooDooPH.
Are you sure about the Droop... In my experience the X preferred reverse droop.
Frt 4mm (under the arm).
Rr 5mm (under the arm)
... Just say'n!
whatever works, i guess... depends on the track and the traction available...
[TRF418][TB-04Pro][FF-03Pro][M-05v2][TRF102][F-104 WGP][TT-01R TypeE]
[Cross CF-01'08][Yokomo R12][Team C TC02Evo][Team C T8E v3]
VooDooPH is offline   Reply With Quote
Old 07-18-2013, 11:07 PM   #5659
Thanks Guys, weather has been crappy in Cape Town. Been raining for 3 days now. Hope it clears up, so I can try all the different setups before race day on Sunday. @Skitee- what gearing do you guys run on the 417 for Tamiya Cup?
NovakSA is offline   Reply With Quote
Old 07-18-2013, 11:41 PM   #5660
Skitee's Avatar
The rules for 4WD GT are different between Gauteng and Cape Town, we run either the Tamiya 7.5 or the Tamiya 10.5 with an open boosted esc so it fits in as the Mod class.
Old 07-19-2013, 03:46 AM   #5661
I run 94t spur and 43t pinion in 17.5 blinky.
I was racing last night with Tamiya slicks. Same inserts all around (Medium).
I really like the aerated shocks built so they have 0 rebound. The car is fantastic on carpet with these (and the montech nazda 4 shell)
Here is a pic of the shell http://www.thercracer.com/2013/07/mo...ing-shell.html
The thing is built to be 'Dead' these shocks dont leak and they are very consistent for me every week.
http://www.theRcRacer.com/
TRF419, TBEvo6, TT02, VDF, TRF501x, TRF201, TRF101, Mi5, X-Ray T4-13, BD7 2014, A700 Evo, WR-02G
Qatmix is offline   Reply With Quote
Old 07-21-2013, 12:52 AM   #5662
Got an odd problem with my car. For the 1st 9 or so laps of the race it feels great but literaly instantly it gets massive oversteer/ over rotation as i lift off to come into a cormer.
Curret serup is.
Trf417 with v5 decks and x shock towers
2 degree rear camber 1 degree front
0.5 deg toe out frnt
3 deg toe in rear
Blue / white springs
40wt oil 3 hole pistons with drilled caps
Sorex 32r preglued medium tyres
1c Frnt split 1c Frnt rear
Split 1xa rear frnt 1e rear rear
4mm under all inner camber links
3mm under rear outer camber links
5.5mm droop all round ( was 6 frnt 5 rear)
1500cst in rear diff
Spool in front
Think thats most of it
scytherat is offline   Reply With Quote
Old 07-21-2013, 12:52 AM   #5663
Curret serup is.
3 deg toe in rear
Spool in front
Old 07-21-2013, 02:44 AM   #5664
Curret serup is.
3 deg toe in rear
Spool in front
I'm Always running:
Suspension mounts front--> front/front D
front/rear split type C
Suspension mounts rear --> Rear/front split type XA
Rear/rear C or D
Spacers on inner camber links:
front 3.7mm
Rear 2.0mm
spacers outer rear camber link--> 3mm
Front toe-out/in is Always 0 (and increase toe-out for more insteer on corner)
Damper springs i use in front--> white or blue
rear --> yellow or red
Droop is set at: front 6mm
rear 5.0mm
The combination of the front suspension mounts will calm the car down and the car feels more smooth. i find the C/C combination makes the car more aggresive, especially when running toe-out in front.
That's my experience.
addicted2blue is offline   Reply With Quote
Old 07-21-2013, 12:22 PM   #5665
Typeone's Avatar
Trader Rating: 30 (100%+)
What's up guys just had a question do u think its worth trading/selling my 417x for a 417v5 considering I have upgraded the car with dcjs front aluminum c hubs titanium screws and the list goes on or should I just wait till tamiya comes out with a new chassis.
Typeone is offline   Reply With Quote
Old 07-21-2013, 12:36 PM   #5666
Typeone's Avatar
Here's a
Old 07-21-2013, 01:26 PM   #5667
vivo quevas's Avatar
Originally Posted by Typeone View Post
Here's a
When is the new tamiya coming out? Did you race last night at hobby town in fresno. The 17.5 race was a lot of fun.
Tamiya/Exotek EXO6 USGT, Tamiya TB03 GT3, Exotek FR1V2
Roche Rapid 1/12, XRay Speed Merchant WGT
http://localrcracing.freeforums.org/
HobbyTown Fresno, Ca. McAllister Racing, Visa/MasterCard's
"Take an early lead and extend it".(Fast Eddie Janis)
vivo quevas is offline   Reply With Quote
Old 07-21-2013, 02:59 PM   #5668
Typeone's Avatar
Yeah I was there not racing tho need to buy a few more things before I hit the track maybe next series. Yeah that 17.5 class was a good race can't wait to join you guys on the track.
Old 07-21-2013, 06:25 PM   #5669
Jochim_18's Avatar
If someone is trading a V5 then do it however the track with on the V5 is too wide so you gonna end up changing suspension mount. I run last night at Hobbytown in Open MOD and help Richard with setup he's struggiling with steering with the stock setup on his 417 V5 due to wider track width..
Localrcracing.com - Your premiere source of Radio controlled Racing in central California.
Visaliahobbies.com * SkyRC * casterracingparts.com
Old 07-22-2013, 01:55 AM   #5670
CraigM's Avatar
Trader Rating: 34 (100%+)
Curret serup is.
3 deg toe in rear
Spool in front
Sounds like your rear tyres are overheating, is this on asphalt?
www.facebook.com/mcpheerc
CraigM is offline   Reply With Quote
Saudi Arabia RC Club grizzle Manila Racers 6558 01-06-2017 08:50 AM
Tamiya TRF415 JDM_DOHC_SiR Electric On-Road 21094 03-10-2016 11:02 AM
Tamiya TRF416 / TRF416WE / TRF416X academygaz Electric On-Road 10619 01-01-2015 03:36 PM
Tamiya TA05 IFS rcforum Electric On-Road 1132 12-18-2014 05:19 AM
"Ask" Jilles Groskamp Tamiya 416 & 417, Team Orion Motors JGH Electric On-Road 1996 05-27-2014 06:28 AM
