Like Tree1Likes
Old 06-27-2013, 06:46 PM   #5566
CraigM's Avatar
Trader Rating: 34 (100%+)
Originally Posted by ic-racer View Post
On the TRF 417 PDF editable spreadsheet, where are the axle degree parameters measured?
"Front Axle" 2 or 4 degrees
"Rear Axle" ___ degrees
This is referring to the front c-hubs (i.e. 4 deg castor) and the outboard toe of the rear uprights. I'm not sure if they still make +1 deg rear uprights or 2 deg c-hubs
www.facebook.com/mcpheerc
CraigM is offline   Reply With Quote
Old 06-28-2013, 07:17 AM   #5567
Hi Guys
I have done a build / review of the 417v5 on my blog. I also have done a detailed call out in the build on how to build a leak free Tamiya gear diff.
here it is
http://www.thercracer.com/2013/06/ta...ld-thread.html
http://www.theRcRacer.com/
TRF419, TBEvo6, TT02, VDF, TRF501x, TRF201, TRF101, Mi5, X-Ray T4-13, BD7 2014, A700 Evo, WR-02G
Qatmix is offline   Reply With Quote
Old 06-28-2013, 12:29 PM   #5568
helltank's Avatar
Originally Posted by scytherat View Post
Has anyone had any success with low profile shock towers?
Hehe, been busy testing this guy.
Tamiya 419X (Prototype) | Smokem | Raceberry | Sanwa M12S
helltank is offline   Reply With Quote
Old 06-28-2013, 01:49 PM   #5569
Potoczak's Avatar
Trader Rating: 111 (100%+)
Originally Posted by Qatmix View Post
Hi Guys
here it is
Awesome blog. Very informative.
Pete Potoczak
Home entertainment specialist
Secure Technologies/ www.stiworldwide.com
Potoczak is offline   Reply With Quote
Old 06-28-2013, 04:16 PM   #5570
Autocratic's Avatar
Trader Rating: 26 (100%+)
What towers are that? How are you liking the T-Shox?
Thanks to my sponsors for 2015!
XFactory RC | Proline Racing | Fantom Racing | Avid RC | Speed Passion USA | Factory1 | Hy-Traction Juice | Mike's Hobby Shop
Autocratic is offline   Reply With Quote
Old 06-28-2013, 06:03 PM   #5571
On ozite, under what circumstances would you change the hardness of the sway bars? Do most people leave the stock ones in?
Steve Boice
Sponsored by: Speedmerchant, Trinity/Revtech, Destiny, Protoform, Hobbywing USA, KO Propo, Ulti, Xenon, TQ Wire
Hyperform racing--In memory of Lino
Bigdaddyswank is offline   Reply With Quote
Old 06-28-2013, 09:32 PM   #5572
Typeone's Avatar
Trader Rating: 30 (100%+)
I have a question I just recently bought the R1 lightweight spring steel axles and I noticed the pin is just sitting in there with no way of locking it down I'm assuming I have to buy R1's CVD kit ill post pictures unless there's another alternative.
Typeone is offline   Reply With Quote
Old 06-28-2013, 09:33 PM   #5573
Typeone's Avatar
Here's the R1 CVD kit I was talking about.
Old 06-28-2013, 09:36 PM   #5574
Typeone's Avatar
See the kit has the small grub screws to lock the pin attached to the cvd bone. Is there any Tamiya parts that might fit if so can I get some part numbers. Thanks.
Old 06-28-2013, 09:52 PM   #5575
H0LESH0T's Avatar
Just picked up a used 417x, I have a 190mm body, what offset wheels do i use with 190mm body?
H0LESH0T is offline   Reply With Quote
Old 06-28-2013, 11:01 PM   #5576
Trader Rating: 27 (100%+)
Zer0
JoeyE is offline   Reply With Quote
Old 06-29-2013, 12:12 AM   #5577
helltank's Avatar
I had them drawn up and cut out, -8.5mm and -7.5mm, front and rear respectively.
The T-Shox are awesome, although the difference from the normal TRF shock is rather negligible. Perhaps I haven't got the springs right (short springs are required now).
Old 06-29-2013, 03:53 AM   #5578
Helltank they look good. How has it effected the handling? Im gonna make some when my carbon arrives, i have an idea of how i can still use full length shocks but will have to see What happens
scytherat is offline   Reply With Quote
Old 06-29-2013, 09:38 AM   #5579
helltank's Avatar
The car actually felt quite horrible at first, sliding around, no traction.
There's less roll with the lowered shocks, you see. I play around and made plenty of roll center adjustment to make the car roll more. More ackermann is also needed for more steering.
Old 06-29-2013, 12:23 PM   #5580
Is it any quicker now you have changes the setup? More direct etc?
Saudi Arabia RC Club grizzle Manila Racers 6558 01-06-2017 08:50 AM
Tamiya TRF415 JDM_DOHC_SiR Electric On-Road 21094 03-10-2016 11:02 AM
Tamiya TRF416 / TRF416WE / TRF416X academygaz Electric On-Road 10619 01-01-2015 03:36 PM
Tamiya TA05 IFS rcforum Electric On-Road 1132 12-18-2014 05:19 AM
"Ask" Jilles Groskamp Tamiya 416 & 417, Team Orion Motors JGH Electric On-Road 1996 05-27-2014 06:28 AM
