Like Tree1Likes
Old 06-17-2013, 03:44 PM   #5506
Typeone's Avatar
Trader Rating: 30 (100%+)
Also do anybody know where I can get some setup sheets for 17.5 just to get a starting point.
Typeone is offline   Reply With Quote
Old 06-17-2013, 07:06 PM   #5507
I got most of my info here
http://www.teamtrf.com/index.php/set...gory/34-trf417 and here http://www.petitrc.com/reglages/tami...miyaTRF417.htm
ic-racer is offline   Reply With Quote
Old 06-18-2013, 02:26 AM   #5508
NItrox416's Avatar
Hi guys,
these weekend I manage to reach the third position in the starting grid at our local track race, but due to a slow and old motor, I don't succed in manteining the place. I notice that with the temperatures raising the handling of my car go worsening. The pace of the morning (40 deg asphalt) was very fast 13.6 (I do also the second fastest lap in 13.4) but at midday and after (more than 50 deg) I only managed to do a pace of 14sec.
What I should do in this situation?
this is my set up.
NItrox416 is offline   Reply With Quote
Old 06-18-2013, 04:14 AM   #5509
CraigM's Avatar
Trader Rating: 34 (100%+)
Originally Posted by NItrox416 View Post
Hi guys,
this is my set up.
Did the grip increase or decrease as the track got hotter? And what changed with the car, did it start to push more or did it overheat tyres?
www.facebook.com/mcpheerc
CraigM is offline   Reply With Quote
Old 06-18-2013, 08:58 AM   #5510
NItrox416's Avatar
It's hard to say, maybe it started to overheating tires because the car wasn't bad to drive, however it wasn't as faster as before, and it was noticed by all other driver but in a less stronger way than me.
But I'm sure that the tires wasn't whistlling as in the earlier runs, maybe a decreased grip situation?
Some said that they had solved the problem changing additive from lrp carpet 2 to tire tweak.
Old 06-18-2013, 03:39 PM   #5511
Typeone's Avatar
I have a LRP X12 17.5 people say those motors can withstand heat sorry if I keep asking about FD but I don't want to burn my motor so I'm thinking 5.0 ill be running 103 spur and 40 pinion (5.01fd) or 100/39(4.99fd) or should I start at a FD of 4.0, ill appreciate the help thanks.
Old 06-18-2013, 05:03 PM   #5512
Brokin Racing's Avatar
Trader Rating: 68 (100%+)
Not true, LRP are excellent, I still have one motor (21.5) which we got in 2010, is still competitive & has been up to 110deg (when we ran turbo)
Xray - LRP - PF - Futaba -
Brokin Racing is offline   Reply With Quote
Old 06-18-2013, 05:19 PM   #5513
Typeone's Avatar
Any suggestions on final drive 4.0-??
Old 06-18-2013, 08:01 PM   #5514
Super Moderator
Grizzbob's Avatar
It really depends alot on the layout you're racing on. If your track is really small & tight, then I might lean more towards a 5.0 FDR, but(at least on the track at Mike's Hobby Shop in the Dallas area) on medium sized one, with a good flow to them, I'll gear closer to a 4.0, maybe even a tick more if the temps are ok. I'd say if you just not sure about your layout, then try something like a 4.5 FDR, & for the first run keep a CLOSE eye on the motor temp(maybe pull off the track every minute or two & check the motor with a temp gun). If it's staying plenty cool enough & you need more top end, then start to go to a bigger pinion(just take your time & go up one tooth at a time & retest it on track each time). Remember, each track is different, & not all drivers need exactly the same thing, so just go about it carefully & be patient till you find what works best for your situation....
Bob Seay
Tamiya TRF417, TA05v.2, TRF211XM, M-05ver.2R, XRAY X12, Associated B5m Factory Lite
Go Pokes!!!
Grizzbob is offline   Reply With Quote
Old 06-18-2013, 08:27 PM   #5515
If it's blinky, 4.0 should be safe, and you may need to go down from there.
If boosted, nevermind.
-Mike
Old 06-19-2013, 02:50 PM   #5516
CraigM's Avatar
Additive may help, but I'd probably try harder shock and diff oil. The shock oil will look aft the tyres more, as will a softer spring.
Old 06-19-2013, 04:53 PM   #5517
OnRDPassion's Avatar
Trader Rating: 54 (100%+)
I know I have been as low as a 3.7 on my car. Again all depends on the track. I always think a 4.0 is a great starting point and then gear up or down according to where you think you may be loosing a little on the comp.
Jay Williams
Xray RX8 2014
RC America - Protoform Racing - KO Propo USA - Kevco Racing / Picco EDO Modified - Byrons Fuels
OnRDPassion is offline   Reply With Quote
Old 06-20-2013, 06:13 AM   #5518
NItrox416's Avatar
Any suggestions?
Old 06-20-2013, 06:38 AM   #5519
narcotiks's Avatar
Any suggestions?
It could be your motor fading from the increased track temp... LRP motors don't work too well when the track is already at 50 degrees.
Did you notice any changes in the tyres, did they come unglued?
Can you make any other comments on how the car was different when the track temp came up?
narcotiks is offline   Reply With Quote
Old 06-20-2013, 06:58 AM   #5520
RC MARKET's Avatar
TRF Gear Diff Putty
RC MARKET is offline   Reply With Quote
Saudi Arabia RC Club grizzle Manila Racers 6558 01-06-2017 08:50 AM
Tamiya TRF415 JDM_DOHC_SiR Electric On-Road 21094 03-10-2016 11:02 AM
Tamiya TRF416 / TRF416WE / TRF416X academygaz Electric On-Road 10619 01-01-2015 03:36 PM
Tamiya TA05 IFS rcforum Electric On-Road 1132 12-18-2014 05:19 AM
"Ask" Jilles Groskamp Tamiya 416 & 417, Team Orion Motors JGH Electric On-Road 1996 05-27-2014 06:28 AM
