Old 05-31-2013, 09:50 PM   #5446
I have noticed there is play between the swing shaft and the spool cup. This is not from wear. You can basically rock the wheel back and forward. Is the play normal or should i try using blades. The manual doesnt say to use a blade for the spool cup.
rayrush is offline   Reply With Quote
Old 05-31-2013, 10:51 PM   #5447
94eg!'s Avatar
Trader Rating: 17 (100%+)
Originally Posted by eComet View Post
I have TRF511 with upgrade set. The TRF417 diff is too wide for 511/501/DB01. You need to get TA05/TA06 front ball diff unit instead. But the softer aluminum outdrives will not last and it's a little too short for the universal so it might pop-out on landing.
You can get TA06 steel gear diff set and also the DB01 gear diff outdrives (slightly longer). I run my TRF511 with dual gear diff and double-slipper drive.
Yeah I figured that out on the 417 diff. Oh well.
I just managed to get hold of a 511-upgrade outdrive (only one pair) for my DB01. I was trying to figure out how to build a second one since I still have the crappy half-plastic diff at the front. The TA06 diff sounds interesting, but I would def be worried if they were shorter than the standard ones.
PM me if you are interested in selling your upgrade-set outdrives (since your using gear diffs).
94eg! is offline   Reply With Quote
Old 06-01-2013, 09:34 PM   #5448
Autocratic's Avatar
Trader Rating: 26 (100%+)
What is everyone using to retain their battery?
I'm not liking having just tape and two servo mounts holding the battery in place. What are some other options that fit without doing anything radical or upsetting the chassis flex?
Thanks to my sponsors for 2015!
XFactory RC | Proline Racing | Fantom Racing | Avid RC | Speed Passion USA | Factory1 | Hy-Traction Juice | Mike's Hobby Shop
Autocratic is offline   Reply With Quote
Old 06-01-2013, 10:56 PM   #5449
narcotiks's Avatar
Why are you not happy with the servo mounts and tape? Ive never had a battery come out during a run and ive been running the v5 since january
Only other alternative I can think of are the carbon battery stoppers from the original 417, the 417x holders are too heavy. I think VBC holders work too
narcotiks is offline   Reply With Quote
Old 06-02-2013, 12:48 AM   #5450
Sith Lord's Avatar
Trader Rating: 21 (100%+)
I think we went through about 2 pages of discussion about this not too long ago . I personally don't like using the tape, but as far as performance - it works just fine. Get the proper tape and that battery aint going anywhere. I'm still quite fond of the velcro that Top and Team Magic u.se
Tamiya XV-01 Rally :: Tamiya FAV 2011 :: Proline Pro2 SCB
Sith Lord is offline   Reply With Quote
Old 06-02-2013, 02:36 AM   #5451
alcyon's Avatar
Default Black Gear diff vs White gear diff
Hi 417 fanatics, I have a question about the gear diffs on the market for the 417.
There is a cheaper version Gear diff Unit II which has white casing and single o rings, and a slightly more expensive version with double o rings and black casing.
Which unit is better in terms of reliability and also leaks less ?
http://kawada-alcyon.blogspot.com/
http://superturbooptimamidspecialzx-5.blogspot.com/
kawada sv10 alcyon 3-sanwa mx3x-orca vx v4.1 software-team powers 13.5 motor-turnigy 4200 shorty lipo-savox 1251 servo RIDE RE32
alcyon is offline   Reply With Quote
Old 06-04-2013, 10:52 AM   #5452
Enjoying the 417 v5 on carpet. Feels good out of the box. C hubs are very fragile tho. Broken 2 already. 1 hit was big and the other was not at all.
Old 06-04-2013, 10:55 AM   #5453
Autocratic's Avatar
I should probably clarify.
I like using tape, but I want something to hold the outside of the battery like what the T4 uses.
Old 06-04-2013, 02:29 PM   #5454
Rayrush ta05 ( i believe) c hubs are more flexible
scytherat is offline   Reply With Quote
Old 06-04-2013, 06:47 PM   #5455
thanks skytherat. are they exactly the same shape? Do you have a part no?
Old 06-04-2013, 08:24 PM   #5456
Super Moderator
Grizzbob's Avatar
I believe it's 51293, & yes, they are exactly the same except for the type of plastic used. You can see them here: http://www.speedtechhobbies.com/inde...product_id=803
Bob Seay
Tamiya TRF417, TA05v.2, TRF211XM, M-05ver.2R, XRAY X12
Go Pokes!!!
Grizzbob is offline   Reply With Quote
Old 06-06-2013, 06:57 AM   #5457
thanks grizzbob!
Old 06-06-2013, 10:10 AM   #5458
skyball's Avatar
Default new raceberry topdeck
Hi guys,
I just received my new Raceberry topdeck. It is a new, stronger version, that was just released. On the bill it days "Raceberry TRF417 topdeck 2,6" whatever that means...
As you can see in the picture it's wider in the front part and a bit narrower in the rear part, especially where it splits around the spur gear. And that's exactly how it feels when I bend it. It flexes mostly in the back part.
While Toni couldn't tell me exactly what the expected / felt differences in car behaviour are, he said that "the boys" all use the new topdeck. Well, I'll hopefully try tomorrow...
Christian
[Sanwa M12][Awesomatix A800][Ronalds Yoke BD-7 2014][Roche P12 2016][Asso RC12R5.2][VBC LightningFXM]
skyball is offline   Reply With Quote
Old 06-06-2013, 09:39 PM   #5459
Typeone's Avatar
Trader Rating: 30 (100%+)
3 questions whats the difference between the 417x and 417v5. 2 does the v5 floating servo mount work on the X chassis and 3 what would I need to convert a X to a V5? Thanks
Typeone is offline   Reply With Quote
Old 06-08-2013, 11:26 AM   #5460
NItrox416's Avatar
Hi,
1) new top and lower deck,top deck 1mm higher and bulkhead 0.5mm higher
2)unfortunately no
3)if you want you can also buy the raceberry conversion istead of the original v5 chassis and in addition the trf floating servo mount.
NItrox416 is offline   Reply With Quote
Saudi Arabia RC Club grizzle Manila Racers 6558 01-06-2017 09:50 AM
Tamiya TRF415 JDM_DOHC_SiR Electric On-Road 21094 03-10-2016 12:02 PM
Tamiya TRF416 / TRF416WE / TRF416X academygaz Electric On-Road 10619 01-01-2015 04:36 PM
Tamiya TA05 IFS rcforum Electric On-Road 1132 12-18-2014 06:19 AM
"Ask" Jilles Groskamp Tamiya 416 & 417, Team Orion Motors JGH Electric On-Road 1996 05-27-2014 07:28 AM
SEO by vBSEO 3.5.0
