Old 05-29-2013, 04:42 PM   #5431
mxgregg's Avatar
Trader Rating: 32 (100%+)
Originally Posted by JoeyE View Post
I will tell you that you will not be disappointed with this kit. Especially for $399.
I'm sure I won't I was just wondering what the differences are
CRG Road Rebel stock moto 125
Birel Q31 Briggs LO 206
mxgregg is offline   Reply With Quote
Old 05-29-2013, 10:27 PM   #5432
94eg!'s Avatar
Trader Rating: 17 (100%+)
Perhaps you could have looked on TamiyaUSA.com?
42184 TRF417
42200 TRF417 w/ Gear Diff Unit (this is the $400 on-sale version)
At the 2011 Thailand International R/C Touring Car Championship (TITC) held in February, TRF (Tamiya Racing Factory) drivers raced their TRF417's with a new Gear Differential Unit installed in the car. Tamiya now offers the TRF417 with this unit as a standard option part included with this new spec version of the TRF 417.
42205 TRF417X
This is the latest spec TRF 417 machine. The main enhancements incorporate subtle revisions. A newly-designed lower deck offers improved chassis flexibility for better low-speed traction. The previous one-piece motor mount has been replaced with a three-piece type to allow further adjustment of chassis' flexibility by linking them together. The thickness of the front and rear damper stays have been increased to 3.5mm and other new developments include a new upper deck, metal battery holders which serve as counterweights, and low-height kingpins. Front direct coupling and rear gear diff unit (Item 42197 TRF417 Gear Differential Unit II) are included in this latest spec version
42240 TRF417V5
The MACH Circuit in Heemstede, the Netherlands played host to the seventh biennial IFMAR ISTC World Championships from July 26th-28th. Of course, Tamiya Racing Factory (TRF) was in the thick of the action and when all was said and done, TRF driver Jilles Groskamp and his TRF417X was crowned the champion. Not only was this Tamiya's third consecutive victory at this prestigious event, it also brought its total IFMAR touring car title count to five (2002, 2004, 2008, 2010, 2012). The TRF417WX edition kit brings enhancements used during the world championship to customers around the world who choose to race the best touring car platform on the planet.
Newly designed carbon fiber upper (2.0mm thick) and lower (2.25mm thick) decks feature refined shapes to provide optimum roll flexibility.
Newly-designed one-piece aluminum servo mount is secured to the chassis by one side (inner side) only so as to not jeopardize chassis flexibility.
Newly-designed aeration dampers help maximize traction.
Front and rear carbon fiber damper stays (3.5mm thick) have redefined damper attachment positions.
Front direct coupling is equipped with steel cup joints and coupled with Double-Cardan drive shafts to provide efficient, smooth power transfer.
Rear gear differential features steel diff joints and swing shaft protectors.
94eg! is offline   Reply With Quote
Old 05-30-2013, 06:26 AM   #5433
Does anyone use drag brake?
rayrush is offline   Reply With Quote
Old 05-30-2013, 10:21 AM   #5434
roger999's Avatar
Yes, i use 6-10, depends what track and surface.
r o g e r g r a f i x . c o m
facebook.com/rogergrafix
roger999 is offline   Reply With Quote
Old 05-30-2013, 11:16 AM   #5435
I depends a lot on the track and the motor that im running. I try to run without it most of the time. Sometimes a bit of drag brake is nice to gain a bit of off-power steering if you need it. On tight tracks I try to run without it, so the cars rolls a little better through the tight corners, especially in blinky 17.5
napoleon1981 is offline   Reply With Quote
Old 05-30-2013, 09:07 PM   #5436
Trader Rating: 22 (100%+)
8% drag brake on my ride.
JoeyE is offline   Reply With Quote
Old 05-31-2013, 04:01 AM   #5437
Very nice!
Old 05-31-2013, 08:48 AM   #5438
OnRDPassion's Avatar
Trader Rating: 54 (100%+)
Clean car! I run 0 drag break when running 17.5. When running mod I am between 5-10 dependent on the track.
Jay Williams
Xray RX8 2014
RC America - Protoform Racing - KO Propo USA - Kevco Racing / Picco EDO Modified - Byrons Fuels
OnRDPassion is offline   Reply With Quote
Old 05-31-2013, 03:02 PM   #5439
94eg!'s Avatar
Can anyone with a caliper and a spare 417 ball-diff do me a favor? I need to know the width between the two inner bearing seats of an assembled diff, as well as the overall width. I REALLY want to see if these outdrives will fit into a 511/501/DB01.
Old 05-31-2013, 03:16 PM   #5440
Skitee's Avatar
26mm between the bearings and 56mm total width end to end.
Xray T4 2017 ~ ORCA Vritra VX3 ~ Motiv RC 4.5
Xray T4 2017 ~ ORCA Vritra VX3 ~ R1 Wurks 13.5
Xray X12 2016 ~ ORCA Vritra VX3 ~ Orca TX 4.5
POWERED BY SPEEDZONE USA
Skitee is offline   Reply With Quote
Old 05-31-2013, 03:47 PM   #5441
Very nice!
Thanks, I'll have to take pictures with better lighting.
Old 05-31-2013, 03:48 PM   #5442
Thanks~
Old 05-31-2013, 04:05 PM   #5443
94eg!'s Avatar
THANKS!!! You da man!!!
Old 05-31-2013, 04:18 PM   #5444
How tight is your belts ?
I play one step looser than the manual front and rear .
How the belt affect the driving behavior ?
Akita is offline   Reply With Quote
Old 05-31-2013, 07:16 PM   #5445
Trader Rating: 69 (100%+)
I have TRF511 with upgrade set. The TRF417 diff is too wide for 511/501/DB01. You need to get TA05/TA06 front ball diff unit instead. But the softer aluminum outdrives will not last and it's a little too short for the universal so it might pop-out on landing.
You can get TA06 steel gear diff set and also the DB01 gear diff outdrives (slightly longer). I run my TRF511 with dual gear diff and double-slipper drive.
Ultimate GT Series
eComet is offline   Reply With Quote
Saudi Arabia RC Club grizzle Manila Racers 6558 01-06-2017 09:50 AM
Tamiya TRF415 JDM_DOHC_SiR Electric On-Road 21094 03-10-2016 12:02 PM
Tamiya TRF416 / TRF416WE / TRF416X academygaz Electric On-Road 10619 01-01-2015 04:36 PM
Tamiya TA05 IFS rcforum Electric On-Road 1132 12-18-2014 06:19 AM
"Ask" Jilles Groskamp Tamiya 416 & 417, Team Orion Motors JGH Electric On-Road 1996 05-27-2014 07:28 AM
SEO by vBSEO 3.5.0
