Like Tree1Likes
Old 05-27-2013, 07:07 PM   #5401
Dragobrat's Avatar
I must be missing something here, because if the photo which is on the part description is accurate it shouldnt fit the 417 4-pin design, normally the 6 hole centre spur gears won't fit without modifying them.
Originally Posted by JoeyE View Post
You can also try this site too. I have a 90T on mine for 17.5 Blinky Class.
http://www.speedtechhobbies.com/inde...roduct_id=2309
Originally Posted by ic-racer View Post
Quote from the site. This is perfect! Thanks for the link.
Dragobrat is offline   Reply With Quote
Old 05-27-2013, 07:25 PM   #5402
Watch the video; the picture seems to show the older version. The gear in the video has many holes to fit 'just about any touring car chassis' and it is shown with the Tamiya 4-pole gear adapter in place.
ic-racer is offline   Reply With Quote
Old 05-27-2013, 09:01 PM   #5403
Dragobrat's Avatar
OK great thanks. And they have the full selection of sizes too.
Old 05-28-2013, 12:26 AM   #5404
roger999's Avatar
Default chassis 417 for 416
Guys, have an 416we and just wondering can i change chassis plate for 417 plate? Will all the parts fit on it with no problem or do i need to replace something? I think upper plate will need to use fron 417 as well...?
facebook.com/rogergrafix
roger999 is offline   Reply With Quote
Old 05-28-2013, 12:38 AM   #5405
Pro10noob's Avatar
Don't think so.
Why not buy the Exotek chassis kit?
Then you have a lipo chassis with better flex then the original chassis.
If you can get your hand on the original lipo kit from Tamiya, that would even better.
Used to run that against a 417(no X) and i got the 416X with lipo kit faster then the 417.
Regards Roy
l===/o\===l
[_]-###-[_] V-link proto type Pro10,JKMR P235-SE Pro10
P235-VL Pro10 comming soon
Sponsered by me,myself and i :)
Pro10noob is offline   Reply With Quote
Old 05-28-2013, 12:59 AM   #5406
roger999's Avatar
Originally Posted by Pro10noob View Post
Don't think so.
Regards Roy
Where can i buy the Exotec? Is that for 416 or 417? Cannot find it on Exotec web site.
Old 05-28-2013, 01:03 AM   #5407
Pro10noob's Avatar
Bugger
They don't sell it any more
Search e-bay or perhaps in the for sale section.
Regards Roy
l===/o\===l
Old 05-28-2013, 01:08 AM   #5408
Pro10noob's Avatar
Perhaps this is something to consider?------> http://www.ebay.nl/itm/Tamiya-TRF416...item2a2d4ec4f2
l===/o\===l
Old 05-28-2013, 01:33 AM   #5409
roger999's Avatar
No thanks...
So what is different in 416 and 417, i inow they are very similar.... maybe would be posiible to change few parts and make it 417 and fit than 417 chassis playe and top deck or even exotex 417 or smokem?
Old 05-28-2013, 01:41 AM   #5410
Pro10noob's Avatar
Where do i start.......Bulkheads,shocktowers,belt,motormount, chassis,topdeck,spurgear adaptor and the bulkheads are closer to each other.
Ballpark is, better buy a 417 then try to convert your 416 to something that can't.
Best thing you can do is if you want all your parts from the WE to be used, buy a 416X or 416WE with lipo chassis.
I sold mine beginning of this year.
It was in mint condition and with enough parts to build a second car
regards Roy
l===/o\===l
Old 05-28-2013, 01:47 AM   #5411
C van der Hagen's Avatar
Originally Posted by C van der Hagen View Post
I have a used raceberry set for sale.
PM if you are interested.
Still for sale.
C van der Hagen is offline   Reply With Quote
Old 05-28-2013, 02:01 AM   #5412
Skiddins's Avatar
Originally Posted by rayrush View Post
Just curious how the carpet guys scrub in new tires to get rid of the shine and center rubber seem? Done a search but not much info.
Most people use a Tyre Sander;
This spins the tyres up, then you use a small piece of sandpaper to removed the mold line in the centre.
The shine shouldn't matter, just clean and use the additive.
Xray T4'18, T4'14 (Wet Car)
Xray X12 2018
Xray X1'16
wlrc.co.uk (West London Racing Centre)
RCDisco.co.uk
Skiddins is offline   Reply With Quote
Old 05-28-2013, 02:11 AM   #5413
roger999's Avatar
regards Roy
Ah thanks. Yeah, it doesnt make any sense. Will find chassis plate maybe Smokem or Exotec for 416. Thanks again.
Old 05-28-2013, 02:57 AM   #5414
Some new developments of the TRF417 include a new motor position, increased motor mount rigidity, an improved secondary gear ratio reduction, optimized chassis layout, re-designed steering linkage, and extra durable ball diffs. All these new changes allow the machine handle superbly while cornering. Also loaded on the TRF417 is an assortment of proven parts seen on the TRF416X such as short reversible suspension arms and uprights with 1050 ball bearings which help reduce friction loss experienced when cornering. In addition, the TRF417 comes with identical front and rear bulkheads and is compatible with a wide variety of TRF parts. Come and try the high performance and superb cornering handling performance of the TRF417.
TongDaWei is offline   Reply With Quote
Old 05-28-2013, 03:39 AM   #5415
roger999's Avatar
Thanks.
Saudi Arabia RC Club grizzle Manila Racers 6558 01-06-2017 08:50 AM
Tamiya TRF415 JDM_DOHC_SiR Electric On-Road 21094 03-10-2016 11:02 AM
Tamiya TRF416 / TRF416WE / TRF416X academygaz Electric On-Road 10619 01-01-2015 03:36 PM
Tamiya TA05 IFS rcforum Electric On-Road 1132 12-18-2014 05:19 AM
"Ask" Jilles Groskamp Tamiya 416 & 417, Team Orion Motors JGH Electric On-Road 1996 05-27-2014 06:28 AM
