Old 05-25-2013, 08:40 AM   #5386
As someone mentioned shocks, can the plastic bits that we drill be bought seperatly as mine are getting worn Where the balls go into them
scytherat is offline   Reply With Quote
Old 05-25-2013, 09:44 AM   #5387
turd ferguson's Avatar
Send a message via AIM to turd ferguson
Originally Posted by scytherat View Post
As someone mentioned shocks, can the plastic bits that we drill be bought separately as mine are getting worn Where the balls go into them
For the "Works" shocks:
It's part of the parts tree. ITEM# 53334 RC Low Friction Damper V Parts - (Damper Collar) MSRP $5.75
TrakPower, Speed Passion USA, Pro-line, Stickit1 Racing, LiveRC.com
turd ferguson is offline   Reply With Quote
Old 05-25-2013, 09:11 PM   #5388
Dusttt's Avatar
Trader Rating: 118 (100%+)
selling my V5 if anyone is interested
Tamiya 417v5 Premium Package ++
"Whiskey Tango Foxtrot"
Dusttt is offline   Reply With Quote
Old 05-25-2013, 11:31 PM   #5389
StickyFingaz's Avatar
Trader Rating: 12 (88%+)
Notes from the Reedy Touring Car Race of Champions.
Rheinard looks to be unstoppable. Only other car looking like they belong in his league are Wilck and Krapp running Kyosho. They continue to use the Raceberry chassis, with Kiyo along their sides for support.
In open Mod Ethan Erichinger is the current pacesetter running an Xray. Andrew Hardman mechanic turned rent-a-ride driver (and former Tamiya guru) Corey Whiteman is right there with him using a back-up Hardman-owned Xray. Tamiya drivers McPhee, Williams and myself all have 1 solid round of qualifying, but are looking to capture the elusive 2nd solid run to solidify ourselves into the A-main, and bump someone out of the top 10.
13.5; Stellfue, Cortes (both AE), and Caroli have dominated the qualifying the rounds and the race is shaping up to be a triple A-main battle among themselves, with Erchinger dropping out to concentrate on Mod.
The talk of the 17.5 class has been of the Awesomatix duo of Austin Brumblay and Aaron Young. Many are speculating on the advantages their shaft-driven drivetrain in the slower horsepower class provide. Kyle Bergstrom, who to the best of my knowledge, is piloting a Hacker-powered Top Photon, is also showing good pace.
One last round of qualifying tomorrow, with mains to follow!
Team Tamiya/TRF - Team KO PROPO - NorCal Hobbies
StickyFingaz is offline   Reply With Quote
Old 05-26-2013, 07:42 PM   #5390
Very frustrated trying to gear my TRF417. Where to get a spur gear smaller than 111T? Looks like Tamiya only make 113 and 111T for the TRF417. I'm trying to gear this for 17.5 blinky class. The biggest pinion I can get in there is about 42 tooth which gives a ratio of 5.146.
I have searched Tower Hobby and RC Mart (and the internet in general) but can't find any smaller spur gears that indicate they would fit a TRF417. Any suggestions for a USA source of smaller spur gears? Should I be searching for TRF416 or something else that fits? Are all touring car spur gears the same?
ic-racer is offline   Reply With Quote
Old 05-26-2013, 08:00 PM   #5391
tiko's Avatar
Trader Rating: 35 (100%+)
Send a message via Yahoo to tiko
Here you go this is what I have on my car it works great.
http://www3.towerhobbies.com/cgi-bin...&I=LXBRAP&P=SM
tiko is offline   Reply With Quote
Old 05-26-2013, 08:06 PM   #5392
Awesome, thanks for the reply!
Old 05-26-2013, 08:25 PM   #5393
Dragobrat's Avatar
Hi, I run 64pitch, i have a collection of - Robinson racing, kawada, TRF and xenon panaracer.
"To cut a long story short" - if you look at the direct center shaft[tamiya 3454765] the side which drives the front belt- the two pins can be removed[or ground away] so that you are just relying on the two pins from the rear belt side. And you could fit any brand spur gear which is available on the market. and still have a reliable center drive.
If you want to keep the 4x pins[2x each side] then you could get robinson racing spurs[just need to make 2x holes in the new spur gear,i just use body reamer] I have found them to be quite decent, i havent chewed any out yet.
To have some of the panaracer spur gear spacers is advisable as well because most of the spur gears vary in thickness [re;getting the e-clip sitting nice on the direct drive unit]. cheers.
Dragobrat is offline   Reply With Quote
Old 05-26-2013, 09:53 PM   #5394
Trader Rating: 24 (100%+)
You can also try this site too. I have a 90T on mine for 17.5 Blinky Class.
http://www.speedtechhobbies.com/inde...roduct_id=2309
JoeyE is offline   Reply With Quote
Old 05-26-2013, 11:16 PM   #5395
Trader Rating: 27 (100%+)
So I'm considering switching back to a 417 (v5) a from a T4 so I can take advantage of the local Tamiya track here in SoCal and try something new. I like the T4 especially since it handled great out of the box with minor changes. I'll be running asphalt mostly, and I've studied this thread and notoced those raceberry conversions are popular. I also noticed that the new shocks have some mixed reviews. So I have a couple questions..
1) If I wanted to go back to the old style shocks, do I have to buy the whole new shock set or can I simply buy bladders and different caps?
2) How is the stock v5 chassis? Is the raceberry that big of a deal just for some club racing on medium/high grip asphalt?
3) How does the car compare to the T4? I do feel the xray is made of high quality but I never had complaints with my other Tamiyas.
I'd love to try this car but after reading some stuff on here I'm a bit skeptical. But it's hard to pass on a car that wins so many races!
RC.Jon22 is offline   Reply With Quote
Old 05-26-2013, 11:46 PM   #5396
narcotiks's Avatar
1) You would need to buy a new set of std shocks, the aeration dampers have a different thread up top for the aeration cap.
2) The stock v5 is awesome! The raceberry is even better! That being said, you don't need the raceberry to be fast with the v5 and make it work well.
3) I've never driven a T4 but I did have a t3 12, the v5 was better for me but its personal preference. For club racing you could have your v5 and t4 at the same pace. As far as quality they are pretty similar
If you want to switch back to tamiya, you wont be dissapointed!!!
narcotiks is offline   Reply With Quote
Old 05-27-2013, 06:43 AM   #5397
The Version 2 Supalite spur gears are designed to fit ALL modern touring cars, including the TRF 417
Quote from the site. This is perfect! Thanks for the link.
Old 05-27-2013, 05:41 PM   #5398
Potoczak's Avatar
Trader Rating: 109 (100%+)
Ok, it seems like tamiya knows what they have to do to the 417 with the raceberry conversion. So when can we expect the 418 or new parts??
Pete Potoczak
Home entertainment specialist
Secure Technologies/ www.stiworldwide.com
Potoczak is offline   Reply With Quote
Old 05-27-2013, 05:48 PM   #5399
Just curious how the carpet guys scrub in new tires to get rid of the shine and center rubber seem? Done a search but not much info.
rayrush is offline   Reply With Quote
Old 05-27-2013, 05:57 PM   #5400
Autocratic's Avatar
Trader Rating: 26 (100%+)
I just shave the mold release line and clean with motor spray.
Thanks to my sponsors for 2015!
XFactory RC | Proline Racing | Fantom Racing | Avid RC | Speed Passion USA | Factory1 | Hy-Traction Juice | Mike's Hobby Shop
Autocratic is offline   Reply With Quote
Saudi Arabia RC Club grizzle Manila Racers 6558 01-06-2017 08:50 AM
Tamiya TRF415 JDM_DOHC_SiR Electric On-Road 21094 03-10-2016 11:02 AM
Tamiya TRF416 / TRF416WE / TRF416X academygaz Electric On-Road 10619 01-01-2015 03:36 PM
Tamiya TA05 IFS rcforum Electric On-Road 1132 12-18-2014 05:19 AM
"Ask" Jilles Groskamp Tamiya 416 & 417, Team Orion Motors JGH Electric On-Road 1996 05-27-2014 06:28 AM
