Old 01-04-2011, 07:40 AM   #526
Chris Furman's Avatar
Trader Rating: 112 (100%+)
Originally Posted by RL.2002 View Post
where u got the set up sheet??
www.teamtrf.com
Chris Furman is offline   Reply With Quote
Old 01-04-2011, 08:46 AM   #527
RL.2002's Avatar
Originally Posted by Chris Furman View Post
TRF417 setup sheet not yet at their site...
the passion of the slide when taking the corner....
http://www.penabai-rcdrifter.blogspot.com/
Kyosho TF-5 drift spec powered by Ezrun 35A + 9t
Tamiya TRF-416X, Tamiya TRF-417
Hobbywing Xerun 120A, Xerun 3.5t, Team Orion 11.5t, Xerun 5.5t
RL.2002 is offline   Reply With Quote
Old 01-04-2011, 08:54 AM   #528
Here you go...
http://www.petitrc.com/reglages/tami...SetupSheet.pdf
Old 01-04-2011, 09:03 AM   #529
syndr0me's Avatar
Trader Rating: 32 (100%+)
Maybe if you want a setup sheet for a TRF201.
Team TRF indeed. What a joke that site is.
syndr0me is offline   Reply With Quote
Old 01-04-2011, 09:18 AM   #530
RL.2002's Avatar
already got it. thankz
Old 01-05-2011, 12:31 AM   #531
syndr0me's Avatar
Finally got a chance to drive the 417 tonight. It's late and I'm tired, so here's quick/dirty report.
With my 416X, my fastest lap on our current layout was a 11.39. I did that twice, and both times seemed a little bit like a fluke. It was more typical to have laps in the 11.7 range, with 11.5 being pretty great.
With the 417, I was able to beat that lap on the 5th pack with an 11.31. In earlier packs, however, I did several more 11.39's, and lots of 11.4's. On average, my laps hovered in the 11.5 to 11.6 range.
Some of this is subjective, since the track felt a little different tonight. Honestly, it felt worse, but sometimes our best laps come when the track seems a little sketchy. My early impression is that the car is easier to go consistently fast with.
I put my 416X setup on there, and the only change was that my inner camber links were 1mm lower since the bulkheads are apparently higher on the 417. The car felt quite similar to my 416X, and definitely drives like a Tamiya, if you know what I mean. I found that it was more stable in long, sweeping turns, and I felt like I could push it a little harder and carry more speed in those sections. It also initiates very quickly, so much so that it took some getting used to. It seems to transition a little faster in tight sections as well. The only thing I didn't like was that the car felt like it wanted to keep turning at the end of a turn rather than straighten out. It was easy to drive around that, but it's something I'll probably try to address with setup, though I don't know where to start for that.
This was on a 98'x42' carpet track running "boosted" 17.5. I had my 416X setup with a 5.5, and I was slower than my 417, but that's not surprising. I'm not much of a mod driver, and the current layout has a lot of short sections in the infield.
Old 01-05-2011, 06:39 AM   #532
teinvall's Avatar
Send a message via MSN to teinvall
Does anyone know how the ackerman spacers on the 417 correspond to the 416?
teinvall is offline   Reply With Quote
Old 01-05-2011, 07:42 AM   #533
Trader Rating: 45 (100%+)
Try a little more angle in the rear camber links. It will help it square up faster and get rid of that rear steer feeling.
Apex is offline   Reply With Quote
Old 01-05-2011, 08:15 AM   #534
Opinions?
Is this car more, less, or same durability as 416/we/x?
J.Lee is offline   Reply With Quote
Old 01-05-2011, 08:20 AM   #535
Originally Posted by J.Lee View Post
Opinions?
Hey John,
Just as durable, maybe a hint more. It uses the same suspension parts, but the motor mount is a huge one-piece of aluminum. I really do like the new drive axles.
Old 01-05-2011, 11:07 AM   #536
Hey John,
Thanks for the reply Chris. I remember seeing your car on the course and was very impressed by you and your car's handling. Yeah the motor mount looks like a great upgrade too, but I wish they would have made it like the 416x; where the mount wholes was on the bottom center, too, instead just the west and east wing where the west is hard to get to because of the spur.
Old 01-05-2011, 12:08 PM   #537
jonest's Avatar
I find the east / west screw hole on the motor mount is easier compared to the previous design but perhaps it's individual preference.
jonest is offline   Reply With Quote
Old 01-05-2011, 12:18 PM   #538
Its actually not that bad at all.. I use these gears. Marc was looking at ordering them at the store, but has not received any to date.
http://www.nexusracing.com/index.php?cPath=145_321_322
all you need to do is drill two 3mm holes and you are all set. They work great.
Old 01-05-2011, 06:27 PM   #539
TryHard's Avatar
Hey John,
I'd agree with that too. Only obvious thing that hasn't been rectifed (although can be solved with the purchase of one pair of dogbones) is the using 46mm steel driveshafts on the front.. and maybe split 1C front block.
Otherwise, new diff keeps out the dirt better, steering uses less spacers (in answer to the other Q on ackerman spacers. 3mm on the 7 = 5mm on the 6 I believe, will check tonight), Centre pulleys are solid metal, and everything else is standard tamiya..
Was speaking to a friend yesterday who made the commet that this car seems to slot together better than the 6 did, and I have to say I agree with him on this point... the build was very easy, no fiddling with the fit of parts etc.
@ Syndrome - measured the bulkhead caps, the camber link positions are only 0.5mm higher on the 7... so 4.5mm on the 7 = 5mm on the 6
Old 01-06-2011, 02:19 AM   #540
Send a message via MSN to WinDarK83
Hi, What is the reference of 46mm steel driveshafts ?¿
And to use 46mm instead of 44mm?
Andrés Glez.
www.agonl83.blogspot.com
WinDarK83 is offline   Reply With Quote
Saudi Arabia RC Club grizzle Manila Racers 6558 01-06-2017 09:50 AM
Tamiya TRF415 JDM_DOHC_SiR Electric On-Road 21094 03-10-2016 12:02 PM
Tamiya TRF416 / TRF416WE / TRF416X academygaz Electric On-Road 10619 01-01-2015 04:36 PM
Tamiya TA05 IFS rcforum Electric On-Road 1132 12-18-2014 06:19 AM
"Ask" Jilles Groskamp Tamiya 416 & 417, Team Orion Motors JGH Electric On-Road 1996 05-27-2014 07:28 AM
SEO by vBSEO 3.5.0
