Old 05-19-2013, 09:59 AM   #5341
Trader Rating: 19 (100%+)
Originally Posted by Potoczak View Post
Well since Rheinhard and the tamiya guys are doing really well with the raceberry conversions, when can we expect tamiya to come out with their own version?? Or will it be the 418??
There was no 418 buzz at at the Hobby Show in Japan.
TEAMORCA.SHOP
MDawson is offline   Reply With Quote
Old 05-19-2013, 10:00 AM   #5342
Originally Posted by syndr0me View Post
Of course, who really knows, apparently the RedRC guy can only be bothered to take pictures of dudes. Not a single chassis in the gallery.
Seems like a norm for the asphalt races. Look back through the galleries and the carpet races seem to have a lot of pit shots.
TEAMORCA.SHOP
Old 05-19-2013, 03:24 PM   #5343
CraigM's Avatar
Trader Rating: 34 (100%+)
Is the v5's gear diff with the new bits available as a single unit?
Now that we've got an outdoor track going, the 417 might be useful.
Going full circle back to tamiya? No updated gear diff set as yet
www.facebook.com/mcpheerc
CraigM is offline   Reply With Quote
Old 05-19-2013, 04:26 PM   #5344
Potoczak's Avatar
Trader Rating: 109 (100%+)
What did they actually change in the v5 diff?? I thought it was only the outdrives to accept the new blades.
Pete Potoczak
Home entertainment specialist
Secure Technologies/ www.stiworldwide.com
Potoczak is offline   Reply With Quote
Old 05-19-2013, 04:28 PM   #5345
Outerdrives, but also the shims and you can install metal gears if you like. Marc Rheinard seems to like the plastic ones tho as they are 9 grams lighter.
napoleon1981 is offline   Reply With Quote
Old 05-19-2013, 07:26 PM   #5346
syndr0me's Avatar
Trader Rating: 32 (100%+)
I actually ran it on the rug last week. It's no T4, but it wasn't bad.
The joy of being a privateer, I suppose, is you can run whatever you want. And then be poor as a result.
syndr0me is offline   Reply With Quote
Old 05-19-2013, 07:42 PM   #5347
Raman's Avatar
Trader Rating: 51 (100%+)
The update to the gear diff set will be: switch back to ball diff.
TRF419X / Pulse 17.5, T.O.P Racing Sabre Mini AWD / Impact 21.5, M06 Pro / Impact 21.5, XV-01 Pro Rallye / Kinetic 17.5
Raman is offline   Reply With Quote
Old 05-20-2013, 04:17 AM   #5348
For carpet with the 417 I prefer a ball diff it calms the rear end down and makes it really consistant.
http://www.theRcRacer.com/
TRF419, TBEvo6, TT02, VDF, TRF501x, TRF201, TRF101, Mi5, X-Ray T4-13, BD7 2014, A700 Evo, WR-02G
Qatmix is offline   Reply With Quote
Old 05-20-2013, 04:41 AM   #5349
whityboy's Avatar
He can do more than that.
http://ets.redrc.net/2013/05/chassis...marc-rheinard/
VBC support team manager EU
whityboy is offline   Reply With Quote
Old 05-20-2013, 10:39 AM   #5350
Super Moderator
Cpt.America's Avatar
Trader Rating: 52 (100%+)
My 417x was unstoppable over the weekend on outdoor asphalt in 17.5. The car was just flawless! Combining my power plant from Fantom racing, and rubber TC tires from RCSpecialties, nobody could keep up. Our tire testing is coming along great, and our cars are getting faster and faster each time on the track.
RCS owner Brett Sisley took 1st in open mod, and I took 1st in 17.5, both running his tires. The 417x really shined, but Brett took open mod in a TC3 of all cars! He also won regionals with that car... Tires are always #1, but Sisley is a monster behind the wheel too... he could probably win with a tyco
A big thanks to my sponsors:
- Fantom Racing - www.fantomracing.com -
- Fusion Graphix- www.fusiongraphix.com -
- RCSpecialties -
Cpt.America is offline   Reply With Quote
Old 05-20-2013, 10:56 AM   #5351
Autocratic's Avatar
Trader Rating: 26 (100%+)
Brandon, care to share your setup? Also, what Apex V2 and gearing did you run? Jeff is getting me a HT version next week when they get in stock to test, but I ran my RPM with HT rotor this past Thursday and it was stupid quick.
Thanks to my sponsors for 2015!
XFactory RC | Proline Racing | Fantom Racing | Avid RC | Speed Passion USA | Factory1 | Hy-Traction Juice | Mike's Hobby Shop
Autocratic is offline   Reply With Quote
Old 05-20-2013, 11:13 AM   #5352
Super Moderator
Id love to! But I don't have a setup sheet ready to post out. I only get to run on-road half of the year (at BEST, depending on weather), so I am still in the mode of shaking off the on-road cob webs, and trying to forget what I know about off-road to make room for on-road stuff!...(this was only my second run of the season) but below is the basics of what I ran. Honestly, by the end of the day, I was having a hard time even finding something about the way the car was driving, that I thought I could improve somehow (but im no pro!). Thank you Tamiya!
Track Type - large outdoor asphalt (140x70 maybe?)
Track Temp - 80-85F
Tire - Yokomo 139GS from RCSpecialties
Body - LTCR
F:
stock piston
400cst oil
Reflex Racing blues
Height - 5.5mm
Droop - 3.5mm
Camber - neg1.5
Toe - 0
RC - middle hole, 2mm shim
R:
stock piston
400cst oil
Reflex Racing silvers
Height - 5.5mm
Droop 3.5mm
Camber - neg2.0
Toe - 3 (stock blocks)
Motor - Fantom APEX1, max endbell timing, 100 spur (wish I had a 98 on me), 51 pinion (FDR 1:3.8)
Battery - Fantom 6500mah 100c
(My apex2 is also on order, should arrive this week, thanks Jeff@Fantom!. I orderd the HT stator, 12.5 HT rotor, works edition)
- RCSpecialties -
Old 05-20-2013, 03:41 PM   #5353
TRF 417 base model with gear diff. (#42200) Having some difficulty understanding the spirngs used on a lot of the setup sheets.
I'm new to carpet. I'm running blinky 17.5 with 42/111 gearing (145 deg F/6min run), spec rubber on what seems to be high grip carpet. I'm set up from the build book wth oil, grease, sway bars, etc from the kit. 5mm ride height (club rules). Mazda6 body. I'm traction rolling all over the place requiring me to go much slower in the corners than everyone else in the class. I have ordered next size stiffer sway bars for each end and the Tamiya colored spring set to increase spring strength front and rear. Any other suggestions or links to setup sheets for similar conditions. Thanks in advance.
ic-racer is offline   Reply With Quote
Old 05-20-2013, 04:32 PM   #5354
I have battled similar issues. For me going harder on springs, swaybars made things way worse, to my surprise as well. What totally transformed my car on carpet were the yokomo springs. Use yokomo pink upfront and the blue in rear.
Also make sure your arms etc are not binding.
You could also glue the sidewalls of your tires if you are desperate, use some super glue.
Widening the car will also help, Use D, D upfront and maybe a XB block in the frontrear.
Old 05-20-2013, 07:10 PM   #5355
Trader Rating: 18 (100%+)
I'm selling my 417v5 with servo and extras for a low price. Look for it in the for sale section!
TamiyaMatt84 is offline   Reply With Quote
Saudi Arabia RC Club grizzle Manila Racers 6558 01-06-2017 08:50 AM
Tamiya TRF415 JDM_DOHC_SiR Electric On-Road 21094 03-10-2016 11:02 AM
Tamiya TRF416 / TRF416WE / TRF416X academygaz Electric On-Road 10619 01-01-2015 03:36 PM
Tamiya TA05 IFS rcforum Electric On-Road 1132 12-18-2014 05:19 AM
"Ask" Jilles Groskamp Tamiya 416 & 417, Team Orion Motors JGH Electric On-Road 1996 05-27-2014 06:28 AM
