Old 05-12-2013, 04:47 PM   #5281
CraigM's Avatar
Trader Rating: 34 (100%+)
Originally Posted by Potoczak View Post
Where can I find the new 3.5mm blades?? Or will blades from another car work??
I think they are being released this month, I'm using yoke ones in the meantime and they are great. AE also work well and are very cheap
www.facebook.com/mcpheerc
CraigM is offline   Reply With Quote
Old 05-12-2013, 04:52 PM   #5282
Potoczak's Avatar
Trader Rating: 109 (100%+)
Great thanks for the info.
Craig have you experimented with the raceberry conversion?? If so what are your thoughts. Looking into it that's why I ask.
Pete Potoczak
Home entertainment specialist
Secure Technologies/ www.stiworldwide.com
Potoczak is offline   Reply With Quote
Old 05-12-2013, 07:02 PM   #5283
Hi, gonna switch to 48 pitch spur and pinion. Does anyone know which 48 spurs will connect straight up without any mod do the 417. I heard the serpent spurs might?
rayrush is offline   Reply With Quote
Old 05-12-2013, 09:45 PM   #5284
CraigM's Avatar
Yes I posted my initial thoughts on the soft chassis a few pages back. Since then I've been testing again with the hard chassis and finding it quite good as well - less grip than the soft chassis but better in high speed corners.
Overall I think the raceberry is a pretty reasonable upgrade, certainly if I had a 417x and was considering a v5 I would probably just save some money and buy the raceberry conversion. If I had a v5 I think I would just wait for whatever tamiya does.
Hope that helps
Old 05-13-2013, 02:57 AM   #5285
Rayrush the spurs that are made for top racing photons fit straight on
scytherat is offline   Reply With Quote
Old 05-13-2013, 03:11 AM   #5286
Serpent ones will fit without modification, that is what I use in my 417
Tamiya - TRF 417V5 - Smokem - Hobbywing V3 - Reedy Sonic 4.5 Mach2
Sanwa M12
iwkyb is offline   Reply With Quote
Old 05-13-2013, 03:29 AM   #5287
silverhkswrx's Avatar
Send a message via AIM to silverhkswrx Send a message via Skype™ to silverhkswrx
Originally Posted by Grizzbob View Post
I've been using a Panaracer 96 tooth spur & I really like it, fits fine & it's one of the most quiet ones I've ever used(& if you have trouble finding them, look for Yokomo branded ones, theirs ARE Panaracers, even has the Panaracer name molded on them)....
Hotbodies are re-branded panaracers also
SpeedPassion 17.5R powered TRF417X
My son owns: Team Associated RC18R2
(RC18B2 converted to a RC18R)
http://www.tamiya.com/english/rc/manuals.htm
silverhkswrx is offline   Reply With Quote
Old 05-13-2013, 07:24 PM   #5288
Thanks everyone for your input!
ok so the serpent of photon spurs will fit straight on.what tooth spur and pinion are you using?
Was thinking 81 spur & 35 pinion
Is it just me or is the v5 over shimmed? the rear swingarms are too tight with the 0.5 spacer so i have left them out and the front i have left out the 1mm spacers.
Just checking is it ok to do so?
Old 05-13-2013, 07:29 PM   #5289
Csaari77's Avatar
You don't want any slop in the arms. If the arms are binding you will need to lightly sand them until the are free. Do not leave shims out it will just make the car inconsistent.
Half-A$$ Racing - Problem solved, problem staying solved!
Awesomatix - Serpent - Tekin - Futaba - Cooper Motorsports.
Csaari77 is offline   Reply With Quote
Old 05-13-2013, 10:00 PM   #5290
CraigM's Avatar
This topic has been covered many times before, don't be afraid to use the thread search function
http://tchub.wordpress.com/2012/07/0...-build-part-2/
Old 05-14-2013, 01:44 AM   #5291
EvilDriver's Avatar
Send a message via AIM to EvilDriver Send a message via Skype™ to EvilDriver
Originally Posted by SS LS1 View Post
I agree and understand what you did, I was just looking to for a quick 10-15 minute change in an attempt to gain some more rear chassis flex the night before our last race of the season. Unfortunately our carpet season is done now until this fall and there is no outdoor on road racing around here so the project is shelved for now.
Somewhere I saw your setup using a suspension block shim to secure the lay-shaft bearings. (good idea) I just did not have the time or the right screw to try that exact setup. So I went with a much thinner spacer on the bulkhead that was close to the thickness of 3M foam based servo tape just to see if the rear flex was affected and it definitely was. Far from ideal I know, but it was just a little experiment to try in pre-race practice that would also be quickly reversible before racing started if I did not like the results. But it worked well and I ran it for the races that day with positive results.
I would like to try a greater spacer for more clearance over the motor mount like you did but I also got to ask how much is really needed to feel a difference? Here are my thoughts.....
While at your pit table you can easily twist your chassis by hand and get a 1/4"+ deflection at the extreme chassis corners. While that same twisting torque generates no where near as much deflection in the center of the chassis where the top deck is moving in relation to the motor mount IMO. What I mean is the measurable chassis flex deflection is greater at the outside edges than close to the center line of the chassis. And I don't think the cornering grip forces generate anywhere near 1/4" chassis corner deflection while racing on the track. Thus how much clearance do we really need between the motor mount and the top deck to make a noticeable difference?
For example look at how little clearance there is between the V5 floating servo setup and the outer edges of the chassis plate where deflection would be the greatest. It is not that much so I would conclude that you would need even less between the motor mount and top deck due to being close to the center line of the chassis. Sound like a reasonable assumption?
This fall I will explore more top deck to motor mount clearance to see if the effects are noticeable on the track. One idea is to use a suspension block shim and rather than put a screw vertical into the mount to secure it would be to bend the end of the shim 90 deg and run a screw horizontal into the mount after drilling and tapping a hole into it. The idea is to have less bulk added to the top of the motor mount so the top deck does not need to be raised up so much causing belt rub interference. I have not really explored this idea yet so it may not work.
One thing to note is that I am trying this on my USGT 417x chassis and bulkheads and not on a V5 chassis. If it proves to work well I will transfer the concept to my other cars.
Not disagreeing with what you are trying, good discussion topic and I appreciate your input on your findings narcotiks.
narcotiks, you did these modifications on The V5 correct ? and SS LS1 you did
these modifications on the 417x ? I'm eager to try it on my V5 the next practice time..
|Xcampus Team Driver |
|Tamiya | TRF | LRP | TEKIN | ORION | Sorex | Futaba| Echologygrafixx |Sweep |
EvilDriver is offline   Reply With Quote
Old 05-14-2013, 07:08 AM   #5292
narcotiks's Avatar
Yeah i did. I raced with this setup on sunday, i was tied up on wether it was actually faster than the stock v5 setup, it had less corner speed and was easier to drive, i did get some good laptimes with it though faster than what i did without the mod. It felt kind of inconsistent, and the high speed change of direction was very sloppy and the car was loose in the rear (not the best way to describe how it felt, but it looked loose) anyway, i made some changes to stabilise the car and give more rear grip. It was better but the car still felt inconsistent. It took a me a few races to get used to the car like this.
I ordered the raceberry last night to give it a try, so hopefully it improves the car further and proves to be a bit more consistent.
narcotiks is offline   Reply With Quote
Old 05-14-2013, 09:53 AM   #5293
StickyFingaz's Avatar
Trader Rating: 12 (88%+)
Race paint scheme ready for the Reedy! Thank you to Eric Albano (aka MiniMod) of Top Notch Paints!
For those of you making the trek out to NorCal, be sure to introduce yourselves so we can swap data, tips, tricks and debrief about the cars. I've got pretty limited wheel time with it (previous seasons I've run AE & XRAY), so I'm open to hearing about everyone's exepriences with the car so far.
My name is Martin Mejia, I'm running Open Mod.
Team Tamiya/TRF - Team KO PROPO - NorCal Hobbies
StickyFingaz is offline   Reply With Quote
Old 05-14-2013, 02:10 PM   #5294
hi i am new on rc tech forum .. i need help with tweak of the trf 417 chassis , i have seen the jg video part 4 of tweak but i dont understand the process of tighteen screws , i mounted like manual and first tight the downbulkheadas put the upperbulkhead then subchasis and towers , can somebody tell how i have to do it ,please the chasis with all mounted is not flat viewing the car towards to me (facing the driver) its litle up in the front right side and litle up in the rear left side i dont understant, i have repeated the mounting pocess lot of times and the problem continues.
thank you very much
Javier Bas is offline   Reply With Quote
Old 05-14-2013, 02:13 PM   #5295
the chassis its flat without tighteen all ,but when i tight the screws have the problem..
thank you..
Saudi Arabia RC Club grizzle Manila Racers 6558 01-06-2017 08:50 AM
Tamiya TRF415 JDM_DOHC_SiR Electric On-Road 21094 03-10-2016 11:02 AM
Tamiya TRF416 / TRF416WE / TRF416X academygaz Electric On-Road 10619 01-01-2015 03:36 PM
Tamiya TA05 IFS rcforum Electric On-Road 1132 12-18-2014 05:19 AM
"Ask" Jilles Groskamp Tamiya 416 & 417, Team Orion Motors JGH Electric On-Road 1996 05-27-2014 06:28 AM
