Old 05-07-2013, 03:42 AM   #5236
Potoczak's Avatar
Trader Rating: 109 (100%+)
Hey guys looking for a starting setup for my local track with a 417 v5?? Here is a video of a qualifying round. http://m.youtube.com/index?&desktop_...feature=relmfu
We run 17.5 blinky and our tire choices are Solaris hard or jaco blues. Also typlicly the traction is medium to high sometimes a little lower then medium. Thanks for any help.
Pete Potoczak
Home entertainment specialist
Secure Technologies/ www.stiworldwide.com
Potoczak is offline   Reply With Quote
Old 05-07-2013, 07:19 AM   #5237
this might be a silly question, but here goes
the chassis fans people mount behind the motor... are they aimed at the motor blowing air on it, or away from it, pulling air off it?
theagentorange is offline   Reply With Quote
Old 05-07-2013, 07:56 AM   #5238
Autocratic's Avatar
Trader Rating: 26 (100%+)
What 64p spur gears for stock are people using? I drilled out a 96T PRS spur to work with the stock holder but it's not perfect.
Also, will the Yok center shaft holder work with the stock chassis?
Thanks to my sponsors for 2015!
XFactory RC | Proline Racing | Fantom Racing | Avid RC | Speed Passion USA | Factory1 | Hy-Traction Juice | Mike's Hobby Shop
Autocratic is offline   Reply With Quote
Old 05-07-2013, 01:32 PM   #5239
John.C's Avatar
Trader Rating: 36 (100%+)
Will the TRF417V5 one piece servo mount bolt on to the original TRF417X lower deck? Or, are modifications required to make it work.
- Middle River Hobbies - The Track -
John.C is offline   Reply With Quote
Old 05-07-2013, 05:49 PM   #5240
nolo148's Avatar
i ran a 94t yeah racing spur but i preferred the kawada 97t spur, both fit without drilling new holes. Ran them in 17.5t blinky
nolo148 is offline   Reply With Quote
Old 05-07-2013, 07:45 PM   #5241
Super Moderator
Grizzbob's Avatar
I've been using a Panaracer 96 tooth spur & I really like it, fits fine & it's one of the most quiet ones I've ever used(& if you have trouble finding them, look for Yokomo branded ones, theirs ARE Panaracers, even has the Panaracer name molded on them)....
Bob Seay
Tamiya TRF417, TA05v.2, TRF211XM, M-05ver.2R, XRAY X12, Associated B5m Factory Lite
Go Pokes!!!
Grizzbob is offline   Reply With Quote
Old 05-07-2013, 08:36 PM   #5242
Raman's Avatar
Trader Rating: 49 (100%+)
Default Separate Suspension Blocks
The one piece sus blocks have the shims that go underneath them to adjust the roll centre.
What do you use if any on the separate sus blocks?
TRF419X / Pulse 17.5, T.O.P Racing Sabre Mini AWD / Impact 21.5, M06 Pro / Impact 21.5, XV-01 Pro Rallye / Kinetic 17.5
Raman is offline   Reply With Quote
Old 05-07-2013, 09:17 PM   #5243
ngo8's Avatar
Send a message via ICQ to ngo8
You can use these which are 0.5 mm and usually the norm or the 1mm ones or 0.5 mm shims need 2 per block and they are the silver tamiya ones .?
http://rcmarket.com.hk/product_info....b9d516bd82110c
Xray|ORCA|Sanwa|Trinity|KoPropo
ngo8 is offline   Reply With Quote
Old 05-07-2013, 09:31 PM   #5244
Raman's Avatar
Thank you! I thought I had seen those but couldn't find them on Tamiya's site..
Old 05-07-2013, 10:34 PM   #5245
ngo8's Avatar
i think they just came out a couple of weeks ago .....i always go on rcmarket to check out the new tamiya stuff he seems to have it first all the time
Old 05-07-2013, 10:43 PM   #5246
EvilDriver's Avatar
Send a message via AIM to EvilDriver Send a message via Skype™ to EvilDriver
Originally Posted by narcotiks View Post
Is the main advantage of the raceberry compared to v5 the new motor position or the additional rear end flex? Because I've come up with a fairly simple and easy way to get the same rear flex as the raceberry using the TRF motor mount...
can you share the insight , Narcotiks ?
|Xcampus Team Driver |
|Tamiya | TRF | LRP | TEKIN | ORION | Sorex | Futaba| Echologygrafixx |Sweep |
EvilDriver is offline   Reply With Quote
Old 05-07-2013, 11:14 PM   #5247
Raman's Avatar
You're right.. I saw them somewhere along with XV-01 hop ups. That's the only Tamiya build I have done which uses spacer under the inner mounts
Today I was at WCRC with my 416WE and was reviewing Jilles' set ups for high traction, and on all sheets he was using a 1 mm spacer on both inner and outer rear mounts. Back then they didn't run separate mounts, so I started my research.
Old 05-08-2013, 02:22 AM   #5248
Hi, need a pinion to fit the 417 v5. the kit comes with 111t and 113t spur, but im not familiar with the pitch? 0.4? as i am coming from a X-ray t3. Will be running a 17.5 motor
Which tooth size pinion & brand for a mid size carpet track?
Also should i use the 111t or 113t spur?
rayrush is offline   Reply With Quote
Old 05-08-2013, 02:53 AM   #5249
kit spurs are 64dp.
Smartypants is offline   Reply With Quote
Old 05-08-2013, 03:41 AM   #5250
Thanks, so i need 64dp pinion,
What ratio or tooth size should i be looking at for mid size carpet using 17.5 motor?
111t or 113t spur?
Saudi Arabia RC Club grizzle Manila Racers 6558 01-06-2017 08:50 AM
Tamiya TRF415 JDM_DOHC_SiR Electric On-Road 21094 03-10-2016 11:02 AM
Tamiya TRF416 / TRF416WE / TRF416X academygaz Electric On-Road 10619 01-01-2015 03:36 PM
Tamiya TA05 IFS rcforum Electric On-Road 1132 12-18-2014 05:19 AM
"Ask" Jilles Groskamp Tamiya 416 & 417, Team Orion Motors JGH Electric On-Road 1996 05-27-2014 06:28 AM
