Like Tree1Likes
Old 01-03-2011, 03:46 AM   #511
Originally Posted by TryHard View Post
Not measured it (might try to this afternoon when rebuilding), but at a guess I'd say 1mm, given the 1mm less under the camber links versus the 6
Edit - Checked just now, the camber link positions are 0.5mm higher than on the 6, mainly due to more material. The bottom of the bulkhead caps are actually in the same position, they just have more material removed for better clearence if you run the axles in the high position . Top deck however is raised 1mm (a la shimming it like on the 6), and the caps also have more material under the shock towers... details
Ed
Did you just run kit set up Ed.
starman is offline   Reply With Quote
Old 01-03-2011, 04:41 AM   #512
TryHard's Avatar
All geometry stuff was kit (so link and shock positions, roll centres etc).
Only changes I made were to use HPI silver springs front and rear, 450wt oil, drilled top cap and only 2mm of rebound (pretty much what I have on the 6).
Think as the traction came up towards the end of the day, should have tried 500wt, and taken back out the 0.5mm I put under the links during the lower traction period.
On the build side, one other thing I noticed (bar the steering drag link...see below), is that if you build the car to the link lengths as described in the manual, you get 1.5 front camber, 2 rear camber, and 0.5 front toe out... which is spot on what I run Thats a definate first for me and a tamiya kit!
Going back to how to get equal steering L-R, whilst I was setting the car up on Saturday, I played around a fair bit with the steering drag link, and servo sub-trim position, and basically ended up with the following. This give pretty much equal steering L-R (looking at my tranny I have both L and R on 94% EPA, even after the on track check).
  1. Remove 2mm from the ball cups in stage 8 of the manual (the ones that are built for the 4.5mm link).
  2. Build the link up so that the total length is 38.5mm (using overall length avoids mis-measurement from the ball cup cutting )
  3. When you get to stage 25, sub-trim out the servo to the right (cant the top of the horn to the centre of the car) to get the steering centred.
I know the above works for me and the servo I'm using (Spektrum S6040), although it maybe slightly different with different servo's, as they don't all have the same spline positions.
If it's slightly out, have a play with the link length and sub trim... but I've noticed on both the 6 and 7 that shorter seems to get the steering more equal.
HiH
Ed
Old 01-03-2011, 08:25 AM   #513
Hi Ed,
can you explaine me the meaning of drilling the cap and how to do it?
Thanks in advance.
jorgesimes is offline   Reply With Quote
Old 01-03-2011, 01:12 PM   #514
Originally Posted by stitchy View Post
Spec.R Gear Diff Set for the TRF416/417 in stock now!
On a different note, I was able to fit a small Kimbrough (black) spur gear by adding two holes with a body reamer. Not nearly as scary as I thought it would be. They even provide "circles" to guide you:
I'll try to post pics later!
Did the same thing a few minutes ago but I found a better way.
Put the new Kimbrough gear on the pulley as it shows in the directions. Now put the Tamiya pulley on over the kimbrough. The studs that go through the small pulley holes align the gears. Now, you can use the Tamiya gear as a drill guide for the two extra holes you need to drill. The big holes on the outside do the same thing so you can make holes to get access to the motor mount screws.
Worked like a charm.
woodys3b is offline   Reply With Quote
Old 01-03-2011, 02:35 PM   #515
jag88's Avatar
Does anyone know of a Tamiya 44mm steel dog bone ?
Thanks.
jag88 is offline   Reply With Quote
Old 01-03-2011, 02:46 PM   #516
PitNamedGordie's Avatar
Send a message via AIM to PitNamedGordie Send a message via Yahoo to PitNamedGordie
Thanks.
Tamiya 54078
http://www.tamiyausa.com/product/ite...oduct-id=54078
I'm not sure where they are in stock...
☆ The Track @ Harbor Hobbies ☆ www.harbor-hobby.net ☆
PitNamedGordie is offline   Reply With Quote
Old 01-03-2011, 02:53 PM   #517
izzyracer's Avatar
Trader Rating: 27 (100%+)
I'm using a 46mm steel for front and it's fine.
Izzy
izzyracer is offline   Reply With Quote
Old 01-03-2011, 02:58 PM   #518
Speedtech has them in stock. Just ordered a set.
http://www.speedtechrc.com/store/ebp...id=967&id=7713
Old 01-03-2011, 03:39 PM   #519
JamesReilly's Avatar
Trader Rating: 57 (100%+)
Thanks.
Marc has them in stock, Barry.
LOL
Tekno RC, Discount RC Store, REDS Racing USA,Reilly Paint ([email protected])
"I'm not normal, just more normal then Finnish guys" - Ilias
JamesReilly is offline   Reply With Quote
Old 01-03-2011, 03:42 PM   #520
jag88's Avatar
LOL
Actually he's waiting on an order. oh well ...
Thanks guys !!
Old 01-03-2011, 04:04 PM   #521
Trader Rating: 114 (100%+)
Thanks guys !!
He has a few coming, but some reserved, like for me! LOL!
Chris Furman is offline   Reply With Quote
Old 01-03-2011, 05:05 PM   #522
Originally Posted by TEAM BURN View Post
HA! i read 32 pages of posts to see if anyone noticed that!! thanks for clearing that up! anyone got a link to a good carpet setup?
Hi
I post my currently 417 carpet set up for 13.5t zero boost (SP Cirtix)
Its nearly the same that i use @ ETS Czech in Nov. with 416X with Xenon Tires
Track Indoor Carpet Small med/high bite
Tires Sorex 28 with JB blue
Front
second hole in on Tower
MM 450 3 hole pistons
5.0mm under camber link in middle hole
Furthest hole on A arm
4mm hex hub .5mm spacer
C front and C rear .8mm Spacer front and 1mm rear
Tam white spring
3mm Ackerman
no bump steer spacer
Droop 6
Arm spacing 3 mm front 1.5mm rear
Stabilzer blue
Camber 1.5
front toe out .5
Rear
middle hole on tower
4mm under camber link middle hole
3mm spacer outside hole rear hub
Tam Blue spring
2nd hole outside on a arm
4mm hex hubs .5mm Spacer
1XA rear front 1E rear 1mm Spacer front and rear
Droop 5
Arm spacing 3mm front 1.5mm rear
Stabilizer yellow
Camber 1.5
3mm rebound in shocks but nothing on top of bladder
Rear Balldiff front Spool both in high position
Body: Mazda Speed 6
Additive: CS high / LRP carpet what you like
Sandro
Stanmarsh is offline   Reply With Quote
Old 01-04-2011, 03:51 AM   #523
Trader Rating: 69 (100%+)
Can you post setup sheet instead? It's a lot easier to visualize.
Thanks.
eComet is offline   Reply With Quote
Old 01-04-2011, 05:17 AM   #524
Hi
attached the Set up sheet...
Sandro
Old 01-04-2011, 06:14 AM   #525
RL.2002's Avatar
Originally Posted by Stanmarsh View Post
Hi
Sandro
where u got the set up sheet??
the passion of the slide when taking the corner....
http://www.penabai-rcdrifter.blogspot.com/
Kyosho TF-5 drift spec powered by Ezrun 35A + 9t
Tamiya TRF-416X, Tamiya TRF-417
Hobbywing Xerun 120A, Xerun 3.5t, Team Orion 11.5t, Xerun 5.5t
RL.2002 is offline   Reply With Quote
Saudi Arabia RC Club grizzle Manila Racers 6558 01-06-2017 08:50 AM
Tamiya TRF415 JDM_DOHC_SiR Electric On-Road 21094 03-10-2016 11:02 AM
Tamiya TRF416 / TRF416WE / TRF416X academygaz Electric On-Road 10619 01-01-2015 03:36 PM
Tamiya TA05 IFS rcforum Electric On-Road 1132 12-18-2014 05:19 AM
"Ask" Jilles Groskamp Tamiya 416 & 417, Team Orion Motors JGH Electric On-Road 1996 05-27-2014 06:28 AM
