Old 05-04-2013, 07:15 AM   #5221
Trader Rating: 17 (100%+)
Originally Posted by rayrush View Post
I decided on the v5 because its the latest version
Used to have a xray t3 but just didn't feel right for me. Come from a Tao5 v2 before that which I loved.
Not a fan of using tape for the Lipo. I've seen You can get tamiys
Lipo mount holders. Why would using a Lipo mount cause tweak?
Tape allows the chassis to flex evenly and hold the battery in its place even in a good crash. People who choose to use the battery hold downs usually crank them down and tweak the chassis. This also does not let the chassis flex as well.
429racer is offline   Reply With Quote
Old 05-04-2013, 04:31 PM   #5222
so with the tape do you still need the battery stops on either end?
If so, don't the battery stops not allow the chassis to flex also once the battery is between them?
i used to put a very thin layer of foam between the holder & lipo in my old car so it still had a little play. is that ok?
rayrush is offline   Reply With Quote
Old 05-05-2013, 12:43 AM   #5223
Adjust the screw in one of the battery stops so when a battery is inserted there is around 1.5mm of play to allow the chassis to flex as it should, believe me with tape and the holders the lipo won't be going anywhere
Smartypants is offline   Reply With Quote
Old 05-05-2013, 01:31 PM   #5224
a lot of people mention the RIDE springs, am i better off just buying a couple of pairs, or are they available somewhere as a set? i run both carpet and asphalt
theagentorange is offline   Reply With Quote
Old 05-05-2013, 04:55 PM   #5225
Autocratic's Avatar
Trader Rating: 26 (100%+)
What's a good starting setup for low/Med traction carpet small track 12sec laps
Thanks to my sponsors for 2015!
XFactory RC | Proline Racing | Fantom Racing | Avid RC | Speed Passion USA | Factory1 | Hy-Traction Juice | Mike's Hobby Shop
Autocratic is offline   Reply With Quote
Old 05-05-2013, 06:51 PM   #5226
setanborneo's Avatar
try this setup buddy
use Sorex 40 Tyre too
Tamiya 417 V5 - Tamiya M05 Pro
Kyosho MP9 TKI3 - OS Engine - AKA - ByronFuels - Futaba
setanborneo is offline   Reply With Quote
Old 05-06-2013, 04:06 AM   #5227
CraigM's Avatar
Trader Rating: 34 (100%+)
I have both full sets of ride but I've never used half of the rates, you're best to just get the reds. Ride/HPI springs are only for asphalt, use yoke springs for carpet
www.facebook.com/mcpheerc
CraigM is offline   Reply With Quote
Old 05-06-2013, 12:17 PM   #5228
StickyFingaz's Avatar
Trader Rating: 12 (88%+)
Guys,
I just built my new 417 v5 recently and am having issues with the gear diff. I've stripped out three (3) sets of gears and I can't quite figure out what to do. I've shimmed it a bunch, not used shims... whatever I do still results in me getting around for a few laps before I hear the dreaded clicking.
Someone recently connected me to the video that Jilles put up explaining how he builds it, so when my gears arrive I will build it this way (with the sanding and shimming of the two main gears). I run modified (4.5) so the stress is a little higher, but still, a kit of this quality should have a gear diff that holds up.
Does anybody have any secrets to tips/tricks to building a bullet-proof gear diff?
Wish me luck on my 4th attempt!
Team Tamiya/TRF - Team KO PROPO - NorCal Hobbies
StickyFingaz is offline   Reply With Quote
Old 05-06-2013, 01:24 PM   #5229
Dusttt's Avatar
Trader Rating: 118 (100%+)
Originally Posted by StickyFingaz View Post
Guys,
http://www.speedtechhobbies.com/inde...roduct_id=4058
might help
"Whiskey Tango Foxtrot"
Dusttt is offline   Reply With Quote
Old 05-06-2013, 02:57 PM   #5230
CraigM's Avatar
Guys,
Your shims have coned. Get TDX shims and make sure the diff screws are tight enough. I run the plastic gears with 4.5 with no issues.
Old 05-06-2013, 05:02 PM   #5231
Craig, where do you get TDX shims from? Also, Sticky, can you post the link to that build video?
DOTMAN is offline   Reply With Quote
Old 05-06-2013, 10:54 PM   #5232
entitymugenmtx's Avatar
Trader Rating: 81 (100%+)
Send a message via AIM to entitymugenmtx
http://www.youtube.com/watch?v=m_DhcfcO8dI
SPONSORS.....MY CHECKBOOK....
entitymugenmtx is offline   Reply With Quote
Old 05-07-2013, 02:00 AM   #5233
Hi, looking to get 4 lipos for my 417 v5. I have used smc in the past but would like your input on whats recommended by you guys?
I have seen these http://www.rcmart.com/intellect-iphw...l?cPath=52_973
Any thoughts?
Old 05-07-2013, 02:31 AM   #5234
Any thoughts?
Great lipos you wont have any issues with them. Some people prefer the bullet connector versions over the deans but that's personal opinion.
HTH's
Old 05-07-2013, 02:33 AM   #5235
Trader Rating: 69 (100%+)
Guys,
You can also get the steel bevel gear set 54428 on top of the shims.
Ultimate GT Series
eComet is offline   Reply With Quote
Saudi Arabia RC Club grizzle Manila Racers 6558 01-06-2017 08:50 AM
Tamiya TRF415 JDM_DOHC_SiR Electric On-Road 21094 03-10-2016 11:02 AM
Tamiya TRF416 / TRF416WE / TRF416X academygaz Electric On-Road 10619 01-01-2015 03:36 PM
Tamiya TA05 IFS rcforum Electric On-Road 1132 12-18-2014 05:19 AM
"Ask" Jilles Groskamp Tamiya 416 & 417, Team Orion Motors JGH Electric On-Road 1996 05-27-2014 06:28 AM
