Old 04-17-2013, 08:01 AM   #5101
skyball's Avatar
Originally Posted by Skiddins View Post
If you look at the photo's of the soft and harder versions of the chassis, The standard kit version (harder) has a much finer weave of carbon fibre. The softer version has a much less dense weave and looks more like the ETS photo of Wilck's car.
My conversion kit arrived today. I ordered the soft version. If you look at it, you'll see, that the weave is indeed less dense, but in my case it also is "the other way around", don't know how to describe it better...
BTW, when I talked to Toni Reinhard, he told me that he also prefers the soft chassis, but Marc seems to like the hard chassis better. Marc also uses the 417X bulkheads, well...
Christian
[Sanwa M12][Awesomatix A800][Ronalds Yoke BD-7 2014][Roche P12 2016][Asso RC12R5.2][VBC LightningFXM]
skyball is offline   Reply With Quote
Old 04-17-2013, 03:38 PM   #5102
G4ZZ4's Avatar
Originally Posted by Smartypants View Post
What springs are you running on your mini shocks? as tamiya mini springs are quite alot softer than the TC equivalents.
I have only got the tamiya ones what would you suggest? I was thinking RIDE blue around.
cheers Garry
YOKOMO BD7, 21.5 boosted M11x
S2H bodies
G4ZZ4 is offline   Reply With Quote
Old 04-17-2013, 11:34 PM   #5103
Not sure if this was mentioned already but there are a few nice bits and pieces on the way from Tamiya....
42254 TRF Aeration Damper for Touring Car
42247 TRF Gear Diff Putty
51535 TRF417V5 Diff Joint (L・R)
51536 TRF417V5 Swing Shaft Cap
mr lee is offline   Reply With Quote
Old 04-18-2013, 12:17 AM   #5104
narcotiks's Avatar
Details would be nice
narcotiks is offline   Reply With Quote
Old 04-18-2013, 12:29 AM   #5105
They are coming soon items, seen on the Tamiyablog.
Expect a few months to pass before seeing them at the online shops!
Old 04-18-2013, 11:25 AM   #5106
Default 416X has arrived
Just received conformation that my 416X has been delivered!!! Can't wait to get home from work to start drooling!!!!!
jstarr300 is offline   Reply With Quote
Old 04-18-2013, 11:23 PM   #5107
Yokomo_Ant3's Avatar
Trader Rating: 29 (100%+)
Get some of the T4 springs, 2.5, 2.7, 2.3-2.6 and 2.5-2.8 The T-Shox short springs are also good
Antoni Caretti
Team Schumacher - Team Scorpion - Sweep Racing - Bezerk RC - Adelaide RC
Yokomo_Ant3 is offline   Reply With Quote
Old 04-20-2013, 09:32 PM   #5108
Dusttt's Avatar
Trader Rating: 118 (100%+)
So I am used to using blocks to set droop. I dont see block set ups on any sheets. What is a good starting point for bumpy and loose with this car (V5) droop wise?
"Whiskey Tango Foxtrot"
Dusttt is offline   Reply With Quote
Old 04-21-2013, 01:27 AM   #5109
I hav a setup on my 417x that im pretty happy with at the moment. The one thing i would like from the car is a little more mid corner steering while on power or neutral power. Can anyone suggest some settings that i can play around with To achieve this. I dont mind loosing a little rear end grip
scytherat is offline   Reply With Quote
Old 04-21-2013, 02:17 AM   #5110
narcotiks's Avatar
What front blocks are you running? And your droop front and rear?
You could add some front arm sweep, less front droop (higher number on blocks) more rear droop (lower number on blocks) or lower the front roll center
Old 04-21-2013, 05:57 AM   #5111
I run 1c front front, 1c split front rear. Droop is 6 front 5 rear.
Think il give the roll centre a go 1st as thats nice and quick to do.
Old 04-21-2013, 06:17 AM   #5112
narcotiks's Avatar
Given your current droop I'd try the roll center first, and definately try the 1b split front rear block. If your running the steering brace id take that off too.
Old 04-21-2013, 05:19 PM   #5113
OnRDPassion's Avatar
Trader Rating: 54 (100%+)
So I am installing the new raceberry kit and was wondering if anyone is having any issues with pinion / spur gear mixes. I am trying to run a 50 t pinion with 101 spur gear and I cannot because the pinion gear hits the new support peice in front of the motor mount. Any suggestions?
Jay Williams
Xray RX8 2014
RC America - Protoform Racing - KO Propo USA - Kevco Racing / Picco EDO Modified - Byrons Fuels
OnRDPassion is offline   Reply With Quote
Old 04-21-2013, 06:59 PM   #5114
veecee's Avatar
Trader Rating: 34 (100%+)
Run smaller spurs and pinions to get the same gearing.
SMOKEM --- HIRO SEIKO --- YOKOMO
veecee is offline   Reply With Quote
Old 04-21-2013, 08:57 PM   #5115
Racing4Evo's Avatar
Send a message via AIM to Racing4Evo
Yes, you need a smaller spur. A repackaged Panaracer 96T is what Yokomo and HPI sell.
With the 96T spur, the biggest pinion you can fit is 49T which should give you and FDR of 3.62:1, that should be about close to max gearing on any track anyway.
Racing4Evo is offline   Reply With Quote
Saudi Arabia RC Club grizzle Manila Racers 6558 01-06-2017 08:50 AM
Tamiya TRF415 JDM_DOHC_SiR Electric On-Road 21094 03-10-2016 11:02 AM
Tamiya TRF416 / TRF416WE / TRF416X academygaz Electric On-Road 10619 01-01-2015 03:36 PM
Tamiya TA05 IFS rcforum Electric On-Road 1132 12-18-2014 05:19 AM
"Ask" Jilles Groskamp Tamiya 416 & 417, Team Orion Motors JGH Electric On-Road 1996 05-27-2014 06:28 AM
