Old 12-31-2010, 05:03 AM   #496
TryHard's Avatar
Originally Posted by carborush View Post
having the same issue on my chassis :
on one arm, tightening the screws like normal, movement is a bit more restricted in the suspention arm
how exactly did you solve this ? i put shims like in the manual... did you just add 1 suspension mount spacer (BA35) orso... ?
won't this affect the cars handling ?
i'll post some pictures lateron showing the savox 1257 rubbing issue
(solved it with cutterknife, sanding paper and some ellbow grease I got like 0,001 cm. to spare now, but no more rubbing...)
mabey the local racer reffered to in previous post has a different savox ? my savox lowprofile 1251 fits with room to spare...)
You have made sure you've got a 0.7 and a 0.1 in the steering, and not a 0.5 and 0.1 shim? subtle difference between the two, but enough to make it bind up!
EDIT - See your problem is with the suspension arm. If it's binding when you tighten the screws up, then the just remove a small amount of material from the wishbone at the hinge pin end. Just run it lightly up and down some sandpaper to free it up.
The spacers should be used anyway, as the car (well the 416 and 415) seem to work best with them in, certainly in the rear.
Old 12-31-2010, 07:35 AM   #497
carborush's Avatar
thanks, ill bring out the sandingpaper again then
does anybody know where to buy the spec-r gear diff ?
can't seem to find any shops that have them in stock?
(can only find the tamiya +20$ one in stock)
carborush is offline   Reply With Quote
Old 12-31-2010, 07:57 AM   #498
stitchy's Avatar
Spec.R Gear Diff Set for the TRF416/417 in stock now!
On a different note, I was able to fit a small Kimbrough (black) spur gear by adding two holes with a body reamer. Not nearly as scary as I thought it would be. They even provide "circles" to guide you:
I'll try to post pics later!
Speedtechhobbies.com
stitchy is offline   Reply With Quote
Old 12-31-2010, 11:23 AM   #499
syndr0me's Avatar
Trader Rating: 32 (100%+)
HKS Hobby (in the US) has them as well.
http://store.hkshobby.com/product_in...oducts_id=7204
syndr0me is offline   Reply With Quote
Old 01-01-2011, 11:02 AM   #500
EDWARD2003's Avatar
Default Carpet setup
What are people doing for indoor carpet setups? Is anyone using the stock kit setup i.e 40 wt shock oil, sway bars, roll centers? If so are what changes are you making?? Has anyone transferred their old 416X setups over to the 417??
Sorry for all the silly questions it's been a long time since I've raced a Tamiya sedan so it would be awesome if anyone could provide setup information.
Cheers.
Edward Pickering
ps. Running APS28R's
EDWARD2003 is offline   Reply With Quote
Old 01-01-2011, 12:14 PM   #501
syndr0me's Avatar
Cheers.
Edward Pickering
I'm hoping to try my 416X setup on the 417 this week if all goes well. I can't imagine it won't transfer pretty well, the cars really don't seem all that different aside from the narrower bulkheads. Most of the updates are convenience/durability related, best I can tell. I sure wish they would have fixed the LiPo hooks so they don't flop around, though.
Old 01-01-2011, 12:52 PM   #502
Tron's Avatar
Trader Rating: 16 (100%+)
Use some shoe goo, they will be nice and stable.
Brett H - M03, TRF417, RM01x
"Slow Sportsman"
Tron is offline   Reply With Quote
Old 01-01-2011, 02:18 PM   #503
If anyone in the uk wants to sell their kit ball diff (because they intend to use a gear diff) please let me know as I am after one.
Cheers
http://www.theRcRacer.com/
TRF419, TBEvo6, TT02, VDF, TRF501x, TRF201, TRF101, Mi5, X-Ray T4-13, BD7 2014, A700 Evo, WR-02G
Qatmix is online now   Reply With Quote
Old 01-01-2011, 02:23 PM   #504
Trader Rating: 114 (100%+)
I don't know how you guys are having issues with the LIPO mounts. I installed per manual and it would take a hammer to move them.
I am also looking for a TRF417 Kit ball diff setup... Anyone want to sell, send me a PM.
Chris Furman is offline   Reply With Quote
Old 01-01-2011, 04:19 PM   #505
syndr0me's Avatar
The front one moves forward after nearly any impact no matter how tight you make it. The screws are too close together. The AE TC6 got it right. Tamiyas solution sucks.
Old 01-01-2011, 06:52 PM   #506
Tron's Avatar
Do any of you use the Tamiya TRF blue o-rings? Item 42137?
I started using them this last time out and my shocks leaked a lot. So after my first rebuild with them I used a 4x0.2mm shim under it and they are better but still leak more than the kit o-ring.
Which o ring does everyone use from MuchMore? Do those also leak? Are the muchmore o-rings worthwhile to use?
"Slow Sportsman"
Old 01-01-2011, 07:13 PM   #507
I use the stock O-Ring.. but before installing.. I let them sit in this lube covered for about 20 minutes and then install them:
http://www.tamiyausa.com/product/ite...oduct-id=42129
they are leak free and super smooth.
Old 01-02-2011, 07:44 AM   #508
TryHard's Avatar
Regarding the carpet setup, Elliott said this to me;
I think kit setup will be good yeah, but we use 4mm rear wheelbase shim, 450 shock oil and if the traction is not super high, 4.5 front camber link shim and 3.5 rear.
Generally on Carpet I prefer to use the ball diff with the Gear diff on Asphalt
Had my first run with the 417 today, gotta say (bar the typical new car niggles), was very impressed... even using completely the wrong tyre for the temperature, and still getting used to driving a 3.5t
Felt very consistent, with a lot of steering, but stable too. Tried a few little things to help the car, and felt all the changes. Ran the ball diff all day (for about 8 runs), and it feels fine still.
Anyway, a few more observations on other bits about the car I've noticed during building.
The bulkhead caps are higher (hence less shims to get the link in the same place), such that you can run the diff/spool in the high position without having to dremel the tops for clearance
The new steering being lower allows for more lock, as the servo horn doesn't hit the steering cross brace as on the 6.
Anyway, certainly become more convinced about the improvements Tam have made on this car. Like I said before, it's in the details
Ed
Old 01-02-2011, 11:24 AM   #509
syndr0me's Avatar
Any idea how much higher?
I've got my 417 built up for boosted 17.5, and ready for testing on Tuesday. The 416X is going to be setup for mod. :-O
Old 01-02-2011, 08:58 PM   #510
TryHard's Avatar
Not measured it (might try to this afternoon when rebuilding), but at a guess I'd say 1mm, given the 1mm less under the camber links versus the 6
Edit - Checked just now, the camber link positions are 0.5mm higher than on the 6, mainly due to more material. The bottom of the bulkhead caps are actually in the same position, they just have more material removed for better clearence if you run the axles in the high position . Top deck however is raised 1mm (a la shimming it like on the 6), and the caps also have more material under the shock towers... details
Ed
Saudi Arabia RC Club grizzle Manila Racers 6558 01-06-2017 08:50 AM
Tamiya TRF415 JDM_DOHC_SiR Electric On-Road 21094 03-10-2016 11:02 AM
Tamiya TRF416 / TRF416WE / TRF416X academygaz Electric On-Road 10619 01-01-2015 03:36 PM
Tamiya TA05 IFS rcforum Electric On-Road 1132 12-18-2014 05:19 AM
"Ask" Jilles Groskamp Tamiya 416 & 417, Team Orion Motors JGH Electric On-Road 1996 05-27-2014 06:28 AM
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
