Old 04-12-2013, 08:45 PM   #5071
narcotiks's Avatar
Originally Posted by Sith Lord View Post
If I'm explaining it right, I can't seem to get enough droop using the v5 Aeration shocks running foam tyres. Currently my foams a around 55-56mm compared to regular rubbers at 64 or so.
Are the regular old style TRF shocks longer and therefore give me the ability to get more droop?
Im pretty sure the shocks are very similar in length. Since the ride height is changed by about 8mm im sure that has some effect on the droop
Only other thing I can think of is for the front, the c-hub hits the arm before the droop screw hits the chassis, that happened to me at the start with the v5 so I sanded the arms and It fixed it...
narcotiks is offline   Reply With Quote
Old 04-13-2013, 02:10 AM   #5072
CraigM's Avatar
Trader Rating: 34 (100%+)
Default Raceberry
Good day of testing today, low grip asphalt again but this time with the soft raceberry chassis mounted - big improvement! Overall grip was similar to the V5 but the car was far more agile and easier to drive on the limit. There's a lot more to come with some setup work, I sort of feel like I'm starting from square 1 again with a new car
www.facebook.com/mcpheerc
CraigM is offline   Reply With Quote
Old 04-13-2013, 05:39 AM   #5073
SS LS1's Avatar
Trader Rating: 23 (100%+)
Craig, you are running that chassis on a 417x with the bulkheads shimmed up correct?
Tamiya 417v7 Sedan, ___ Tamiya 417v7 USGT, ___ CEFEX EVO w/ 417 suspension VTA
Exotex TA06 Pro CS Drifting, ___ Tamiya 417v5 (sold)
AE SC10 4x4
AE SC10 AE B4.11
SS LS1 is offline   Reply With Quote
Old 04-13-2013, 01:50 PM   #5074
Raman's Avatar
Trader Rating: 49 (100%+)
For West Coast RC, what weight diff oil do most of you run in the rear? 1000?
TRF419X / Pulse 17.5, T.O.P Racing Sabre Mini AWD / Impact 21.5, M06 Pro / Impact 21.5, XV-01 Pro Rallye / Kinetic 17.5
Raman is offline   Reply With Quote
Old 04-13-2013, 02:23 PM   #5075
CraigM's Avatar
yes I converted one of my x's
Old 04-13-2013, 02:35 PM   #5076
Sith Lord's Avatar
Trader Rating: 21 (100%+)
Thanks for your thoughts Narcotiks. Does anyone have both shocks handy to measure, so I can rule in or out this option for me?
Cheers
Tamiya XV-01 Rally :: Tamiya FAV 2011 :: Proline Pro2 SCB
Sith Lord is offline   Reply With Quote
Old 04-13-2013, 05:13 PM   #5077
CraigM's Avatar
Aeration and HL shocks are the same length
Old 04-13-2013, 05:38 PM   #5078
Trader Rating: 24 (100%+)
@CraigM...
Sorry but I am sure that you covered this already. This is about the Raceberry chassis set. How many mm raise for the front and rear bulkheads? How many mm for the top deck.
Thanks~!
JoeyE is offline   Reply With Quote
Old 04-13-2013, 06:51 PM   #5079
CraigM's Avatar
Originally Posted by JoeyE View Post
@CraigM...
Thanks~!
0.5mm under the bulkheads and 2mm under the top deck for 417X bulkheads
Nothing under the bulkheads and 1.5mm under the top deck for 417V5 bulkheads
My friend pointed out yesterday that with the X bulkheads you could cut up an old top deck to use instead of the 2mm shims. I might give it a go later today
Old 04-14-2013, 08:42 AM   #5080
Cool thanks~! Need to order a few 0.5 shims. The kit came with 2mm for the top deck.
Old 04-14-2013, 12:23 PM   #5081
Is the new gearing now 1.85?
Old 04-14-2013, 12:36 PM   #5082
ruebiracer's Avatar
Craig, I could also feel the car being more agile today.
Coming from the X, I only had at the moment the stiffer Raceberry chassis, but even with that my car was a lot easier to drive for me (compared to the X spec)!
I could manage to win my local championship race today, on quite difficult conditions. In the morning it was partly raining, with getting dry in the late afternoon. Car was a little pushing into some tight corners, as some of you also noticed, but despite of that still very agile in the quick chicanes. This made it easy to drive on the partly wet track, great.
Only problem I had was on the Yokomo pulley: One side plate did pop off, and was loose after one run. Cannot say way, the belt stayed still on.
Im very keen on the soft chassis now for the next races!
BR,
Matthias
www.TTSC-Racing.de
www.mst-estenfeld.de/der-loeffler-cup
ruebiracer is offline   Reply With Quote
Old 04-15-2013, 04:54 AM   #5083
Hi guys, having a trf417v5, will a full hudy setup station be useful or do i just need gauge, etc. what are the most useful tool/s needed for tuning this car?
dingsky is offline   Reply With Quote
Old 04-15-2013, 06:58 PM   #5084
Default 416x diffs
Hi guys, question for anyone about the diffs!!! I am in process of building my 416x and I am wanting to know if the ball diff that is for the rear is interchangeable with the spool in front? The reason for my ? Is that I currently have a TA-05 running gear diffs front and rear and really like how it drives! So I have purchased the TRF gear diff for my 416 to run in rear and will eventually like to get one for front but until I purchase it I was thinking I could run the ball diff in front. I have never ran a spool and don't know what to expect with it on carpet! Thanks for your help
jstarr300 is offline   Reply With Quote
Old 04-15-2013, 11:10 PM   #5085
Yes they are interchangeable!
mr lee is offline   Reply With Quote
Saudi Arabia RC Club grizzle Manila Racers 6558 01-06-2017 08:50 AM
Tamiya TRF415 JDM_DOHC_SiR Electric On-Road 21094 03-10-2016 11:02 AM
Tamiya TRF416 / TRF416WE / TRF416X academygaz Electric On-Road 10619 01-01-2015 03:36 PM
Tamiya TA05 IFS rcforum Electric On-Road 1132 12-18-2014 05:19 AM
"Ask" Jilles Groskamp Tamiya 416 & 417, Team Orion Motors JGH Electric On-Road 1996 05-27-2014 06:28 AM
