Old 04-08-2013, 03:49 AM   #5041
CraigM's Avatar
Trader Rating: 34 (100%+)
Originally Posted by JoeyE View Post
I placed an order for the Raceberry kit. Do you also need to raise the front bulkhead and top deck too?
Yes exactly the same as the rear
Originally Posted by Jochim_18 View Post
You can't beat tamiya and yokomo together in one chassis you can't beat that..
A little while back I was thinking of changing to yoke but I have waaaay to many spare parts to change brands. Raceberry is best of both worlds
www.facebook.com/mcpheerc
CraigM is offline   Reply With Quote
Old 04-08-2013, 04:33 AM   #5042
Dont you mean Tamiya and Yokomo and Serpent lol
I saw a few running yesterday (UK) the feeling about the conversion is very mixed! some were even changing back to their original V5 chassis and noticing an improvement (low grip outdoor asphalt). Only testing and more time will tell if its any good.
Smartypants is offline   Reply With Quote
Old 04-08-2013, 08:16 AM   #5043
If you are referring to the Brca Clubmans yesterday then yes. I think i will be changing back to the V5 chassis, was a little disappointed to be honest. Been reading about the raceberry and heard a lot of good things, but my trouble was corner speed, what ever I tried just couldn't get more corner speed out of it. Has anyone else had troubles with the cornering speed ?
Big Dave 1984 is offline   Reply With Quote
Old 04-09-2013, 12:28 AM   #5044
timmay langdell's Avatar
With my raceberry it have me sooooooooooo much push into corners had to nearly stop car to get it in.
Changed back to kit chassis got steering back and 8 seconds faster in Bach to back runs.
But then looking at viktors car at ets it looked like it pushes into corners.
Was expecting good things but was disappointed to say the least!!
timmay langdell is offline   Reply With Quote
Old 04-09-2013, 12:59 AM   #5045
how often does tamiya update their 417 versions? are they due for a newer version than the v5?
rayrush is offline   Reply With Quote
Old 04-09-2013, 01:13 AM   #5046
Usually about one a year (dec time) but the V5 looks like a good base to start as it has the latest DCJ's diffs and spool.
Also are people running the aerated shocks indoors? How are you finding them?
http://www.theRcRacer.com/
TRF419, TBEvo6, TT02, VDF, TRF501x, TRF201, TRF101, Mi5, X-Ray T4-13, BD7 2014, A700 Evo, WR-02G
Qatmix is offline   Reply With Quote
Old 04-09-2013, 02:44 AM   #5047
C van der Hagen's Avatar
Default New spare parts
51535 TRF417V5 Diff Joint (L・R)
51536 TRF417V5 Swing Shaft Cap
C van der Hagen is offline   Reply With Quote
Old 04-09-2013, 02:44 PM   #5048
CraigM's Avatar
What setups did you run?
Old 04-10-2013, 12:29 AM   #5049
Started with viktors ets set up
Old 04-10-2013, 01:21 AM   #5050
The Gran Canaria racetrack with the Ride 34 tire was extreme low grip.
Do you run also the Ride 34 tire on a low grip surface?
Old 04-10-2013, 03:19 AM   #5051
No we use the sorex 32 brca control tyre. Wlrc was low grip aswell.
Old 04-10-2013, 03:42 AM   #5052
The raceberry chassis generates more rear grip compared to the V5 chassis.
Try to use less toe-in (2.0-2.5), a thicker (1.2mm) rear swaybar and harder springs (HPI silver) when using the sorex tyre.
Do you use a setscrew or a countersunkscrew at the lower side of the centerpost?
I tested the raceberry set last weekend at the Apeldoorn track both with the ride 34 and the sorex tyre. Both tires require a complete different set-up.
Old 04-10-2013, 06:16 AM   #5053
Not tried it on ride tyres, but did do the changes you mentioned.
Old 04-10-2013, 06:53 AM   #5054
Thing is any of the so called low grip tracks are much higher than anything in the uk. They are also flat which I don't think any track really is over here.
Craig Morgan - Tamiya 417
Slick990 is offline   Reply With Quote
Old 04-10-2013, 10:21 AM   #5055
What tire was faster in the end?
napoleon1981 is offline   Reply With Quote
Saudi Arabia RC Club grizzle Manila Racers 6558 01-06-2017 08:50 AM
Tamiya TRF415 JDM_DOHC_SiR Electric On-Road 21094 03-10-2016 11:02 AM
Tamiya TRF416 / TRF416WE / TRF416X academygaz Electric On-Road 10619 01-01-2015 03:36 PM
Tamiya TA05 IFS rcforum Electric On-Road 1132 12-18-2014 05:19 AM
"Ask" Jilles Groskamp Tamiya 416 & 417, Team Orion Motors JGH Electric On-Road 1996 05-27-2014 06:28 AM
