Old 04-03-2013, 01:54 PM   #5011
Good job I just changed mine out on my bd7 for hpi silver (blacks) all round.
Mi4cxl is offline   Reply With Quote
Old 04-03-2013, 05:49 PM   #5012
Nuno Gancho's Avatar
have you notice that the old HPI spring say silver gold are softer then the new springs silver gold in black!!
Nuno Gancho is offline   Reply With Quote
Old 04-03-2013, 06:59 PM   #5013
narcotiks's Avatar
Yeah, I generally switch between silver silvers and black silvers... I was lucky enough to track down 2 full sets of silvers and one set of golds
narcotiks is offline   Reply With Quote
Old 04-04-2013, 01:17 AM   #5014
tmomedrano's Avatar
anyone tried SPEC-R springs? swap them with my silver blacks... seemed identical with the 2.7 springs. 2.5 identical to hpi blues the difference is they got 2.8 and 2.6 which are in between..
[ Team Maxx Traxx ] http://iloveporrc.blogspot.com/ * http://timmedrano.com
tmomedrano is offline   Reply With Quote
Old 04-04-2013, 09:12 PM   #5015
Send a message via Skype™ to JordanC
Hi Guys,
Sorry if this is a little off topic, but Scotty Ernst is holding an AOC championship (ala ETS) and one round is being held in my home town, Melbourne Australia. I thought I would post the link to the discussion should anyone be interested in a holiday down under
2013 ASIAN ONROAD CHAMPIONSHIPS PRESENTED BY SCOTTY ERNST
http://www.aocrc.com/
Sorry for the hijack
Cheers,
Jordan
JordanC is offline   Reply With Quote
Old 04-04-2013, 10:15 PM   #5016
nolo148's Avatar
Is there an improvement with putting .5mm shims under the bulkheads? Also is it all the bulkheads including the motor mounts? It's for the 417x
nolo148 is offline   Reply With Quote
Old 04-05-2013, 03:04 AM   #5017
I haven't tried raising the bulk heads up. So I have no idea of the affect in the car when doing this. But to answer your Other question. You would have to raise everything up. So everything will line up properly.
Juan Aveytia is offline   Reply With Quote
Old 04-05-2013, 09:54 AM   #5018
ruebiracer's Avatar
Originally Posted by CraigM View Post
For the raceberry you need to raise the original 417 bulkheads 0.5mm and use 2.5mm shims under the top deck. Or just buy a set of the new F/R bulkheads - you're spending all that coin anyway
As I bought my 417X in used condition, its much cheaper for me with the raceberry kit. I dont care about the old bulkheads, shims are cheaper.
Biggest invest was the V5 servomount, which you need.
As I unpacked the kit today, Im pretty impressed on the quality, too.
Although Im a big Tamiya fan since childhood, it feels good to have some german engineering on the car at the moment.
I hope it gives me some potential on the track. At the moment there are too many X-rays and hotbodies in my finals.
Br,
Matthias
www.TTSC-Racing.de
www.mst-estenfeld.de/der-loeffler-cup
ruebiracer is offline   Reply With Quote
Old 04-05-2013, 10:18 AM   #5019
Hi, considering getting a 417 v5. coming from a xray t3. just a few questions.
Is it good out of the box for carpet?
is the build good or does it require extra shimming?
does it come with strong out drives?
Is there any extra parts besides spares that are recommended to have during the build?
Thank you for any responses. I have been reading thru but too much info, so if i can get someone to sum up my questions i appreciate it.
rayrush is offline   Reply With Quote
Old 04-05-2013, 02:05 PM   #5020
Anyone know where the V5 blades are in stock?
Craig Morgan - Tamiya 417
Slick990 is offline   Reply With Quote
Old 04-05-2013, 04:14 PM   #5021
narcotiks's Avatar
I dont know, im sure someone can answer that. I run ashpault.
The build is awesome, the manual tells you where you need to shim, just the suspention arms need maybe 0.2 mm less or you sand them 0.1 each side so it can move freely in the blocks.
It comes with steel front outdrives and aluminium rear outdrives. They are strong. If your looking for spares I recommend the arena outdrives for the front.
The v5 comes with all the extras that you would otherwise want. Dcj front, steel outdrives etc.. only thing I could mention would be the ball studs that go into the toe block, they are aluminium and bend easily in crashes, the fluorine or hard hex balls are better.
For the build you'll also need a few drill bitts for the c-hub and toe block (manual tells you)
As far as spares, belts, c-hubs, rear toe blocks, knuckles and arms(standard spares). I'd also recommend picking up some suspention blocks (spares) as the solid blocks can bend.
If your moving from xray and are seriously considering a tamiya, I wouldn't think twice, its a much better car. Be wear though that the tamiya is not as strong as the xray in the sense that it will tweak allot easier in a crash, so after every race if you have a huge hit, you'll need to de tweak the car where you might not have had to with the xray.
Good luck
I haven't seen them anywhere but I do know that they are released...
You can use the associated blades they are the same size and are strong.
Old 04-05-2013, 06:51 PM   #5022
Thank you for your detailed reply narcotics. The xray is very durable!
How do you de tweak the car?
Old 04-05-2013, 08:12 PM   #5023
narcotiks's Avatar
No worries
Loosen the top deck and shock towers etc to remove tweak ( you can usually feel the car un tweaking, it kind of pushes back against your driver, it's hard to explain unless you feel it)
You should do that with any car after a crash though.
I moved from xray to tamiya and would never look back for a second hahah
Old 04-05-2013, 09:04 PM   #5024
exactly why are your reasons why you moved from xray to Tamiya??
I am thinking about it because i just couldn't get the xray feeling right for me.
Old 04-05-2013, 09:22 PM   #5025
narcotiks's Avatar
I was running the t3 12 and it just wasn't responding the way I wanted it too and I didnt know too much about car setup at the time. I was getting tired of the xray and wamted to try something different, i was looking at different cars mostly the yokom, tamiya and the awesomatix. Then an opportunity to buy a 417x with spares and a good setup appeared, so I took it, ran that for a little while and then bought a v5. Since then ive learnt allot about car setup and the tamiya and my car is working really well at the moment, way better than the xray could be.
Saudi Arabia RC Club grizzle Manila Racers 6558 01-06-2017 08:50 AM
Tamiya TRF415 JDM_DOHC_SiR Electric On-Road 21094 03-10-2016 11:02 AM
Tamiya TRF416 / TRF416WE / TRF416X academygaz Electric On-Road 10619 01-01-2015 03:36 PM
Tamiya TA05 IFS rcforum Electric On-Road 1132 12-18-2014 05:19 AM
"Ask" Jilles Groskamp Tamiya 416 & 417, Team Orion Motors JGH Electric On-Road 1996 05-27-2014 06:28 AM
