Tamiya TRF417
#4996
They are the plastic servo mounts that come with the kit, I believe they are on the k parts tree.
#4997
Raceberry rockzzz....
Got the Raceberry Kit few days ago. Yesterday was first practice with it on a medium grip carpet track, because its still snowing here...
As I was unpacking the Kit I was pretty impressed of the workmanship. The Kit is very exact and precise. The Kit can be mounted very well, all parts have a perfect fit.
For those youīre thinking about the internal transmission, itīs 1,85 (37T/20T Yokomo Center Pulley). I drove the car with a 17,5T LRP without power programme and a gear ratio of 4,51 (100/41).
Before using the Kit I was not sure if it will work in Stock (17,5T) too and if it can bring the same results the were shown us in modified on asphalt at ETS and TITC. So I took it to the track...
Just say one word... AWESOME!!!!!
After checking the lap times I saw the I drove directly 3th of a second faster than 4 hours before with the V5. The steering is very sharp and direct... much more than before. All of the drivers were suffering of a loose rear end that day, except of me now... My rear end was, like it has been nailed to the track. I used my standard setup in this round and Iīm pretty sure that it will go a lot faster!!
Big thanks to Tonisport and Raceberry for this evolution step!!!
I very excited how results on asphalt will be and hope I can make a outdoor session in a few weeks. Pray for better weather!!!
Will let you know then...
#4998
Raceberry conversion
I would like to order conversion where can I order one!
#4999
Hi Andreas,
Toni will send out mine tomorrow.
Your results look pretty well on carpet!
If you have a setup sheet...
I want to use mine on asphalt in 2 weeks, if the weather is good.
One question I have: Mine is still an 417X, as I quit the V5 version in favor of the Raceberry kit. Do I have to order the Tamiya V5 servomount? Or can I go with 2 posts ala X?
Toni has restocked the kit everyone can order at the moment, if you give him a mail. Price is 169 without postage.
BR,
Matthias
BR,
Matthias
#5001
You need to buy the V5 servo mount. There is no hole an the chassis is too small to drill a hole in either. The kit comes with 1,5mm shims, the have to be placed between the bulkheads an the upper deck. Keep in mind that the X bulkheads 1mm lower than the V5 ones, so you have to shim 2,5mm.
Havenīt done a setup sheet yet and I need to test a lot before I can give you a working setup.
#5002
#5003
0.5mm under the bulkheads i think. Not sure about between tge top deck and bulkheads
#5005
how full should the front diff with diff putty has someone a picture of it
#5009
I assume the next version will make a nod towards the Raceberry set-up. After seeing one close up they only need to do 20t pulleys and bottom / top deck the motor mount in the kit seems just necessary to run the yokomo pulley holder etc
