Like Tree1Likes
Old 02-26-2013, 09:55 PM   #4786
Originally Posted by Yokomo_Ant3 View Post
What a great race TITC was this year! The level of racing was even higher this year, and track conditions changed so much throughout the event, it was very hard to adapt the setup to what the track was doing. Pretty happy I made the B main again, had 2 crappy finals after being taken out in both after good starts! Nevertheless the car was really good, my setup should hopefully be on Petit soon I used all standard parts on my car, only used normal TRF dampers not aeration. I tested low shock towers and shocks but liked the standard parts better
If anyone has any questions please ask
Cheers,
Antoni
Dear Ant,
Few Question:
Any setup sheet for reference; Front blocks & rear blocks set up?
Is it a super high traction track?
Tires wear & tear condition after each heat?
Tks & Rgds.
MIKA is offline   Reply With Quote
Old 02-27-2013, 01:38 AM   #4787
Yokomo_Ant3's Avatar
Trader Rating: 29 (100%+)
Originally Posted by MIKA View Post
Dear Ant,
Few Question:
Tks & Rgds.
I ran B-C front blocks, XA-C rear blocks. Track was crazy grip at night, but during the event the track grip decreased during the event as there was less cars going around. My tyre wear was pretty good, but we only had to do 2-3 runs on the tyres. I was using LRP Carpet or Mighty Gripper as additive
Antoni Caretti
Team Yokomo - Racing Performer - Sweep Racing
Yokomo_Ant3 is offline   Reply With Quote
Old 02-27-2013, 02:54 AM   #4788
Cheers,
Antoni
which low shock towers and shocks did you used? iīve been thinking about this modification too, but i didnīt get the right shocks so far
-no86- is offline   Reply With Quote
Old 02-27-2013, 03:10 AM   #4789
I have tested a few so far, a company here in Australia, Bazerk Rc make them. They are 6mm lower than standard ones. We are using Tamiya Mini shocks with them, I have also tested Xray shocks but didnt like these as much.
My setup is here: http://www.petitrc.com/reglages/tami...2013012324.pdf
Cheers
Antoni Caretti
Old 02-27-2013, 03:13 AM   #4790
chrisk's Avatar
Trader Rating: 32 (100%+)
Ant, well done at TITC, what does the lower shock tower and running the shorter shocks do for the car setup wise?
TAMIYA - SMOKEM - REEDY
smaracing.org
chrisk is offline   Reply With Quote
Old 02-27-2013, 03:22 AM   #4791
CraigM's Avatar
Trader Rating: 34 (100%+)
Cheers
That's wild, did you try higher RCs at all?
www.facebook.com/mcpheerc
CraigM is offline   Reply With Quote
Old 02-27-2013, 05:30 AM   #4792
With the lower shock towers the car sits much flatter on the track, it reacts a little faster on direction change but lap times seem to be quite similar. I think its all track dependant, but also its hard to 100% compare as we use short springs with them.
We did try, but I felt more comfortable using what I did. The factory boys used different setups with their proto car
P.S Forgot to menton I dremeled the front of the top deck for more flex!
Antoni Caretti
Old 02-27-2013, 05:43 AM   #4793
narcotiks's Avatar
interesting setup!
What made you know the car needed more front flex? Ive been trying to figure out chassis flex, i thought you guys would run a stiff car on such a high grip track?
Did you run v5 bulkheads or x bulkheads shimmed up for more flex?
narcotiks is offline   Reply With Quote
Old 02-27-2013, 05:59 PM   #4794
Originally Posted by narcotiks View Post
interesting setup!
The car was too bitey, as in it was steering too hard into the corners, making traction roll even more of an isuue. When I cut the top deck, the front flex's first so it takes away some of that bite. From what I have seen, on high grip more flex is better. A lot of other cars where using thinner top decks etc. I ran kit bulkheads
Antoni Caretti
Old 02-28-2013, 02:23 AM   #4795
Was it bitey with the low towers? I have also made some low towers for my 417 but have yet to try them out.
http://www.theRcRacer.com/
TRF419, TBEvo6, TT02, VDF, TRF501x, TRF201, TRF101, Mi5, X-Ray T4-13, BD7 2014, A700 Evo, WR-02G
Qatmix is offline   Reply With Quote
Old 02-28-2013, 02:25 AM   #4796
where are you cutting the top deck? any photos.....
Smartypants is offline   Reply With Quote
Old 02-28-2013, 10:28 AM   #4797
Hi Antoni,
iīve got a few questions on your setup. What was the effect using 7000er oil in your gear diff?
did u remove these screws?
thanks
Stefano
Old 02-28-2013, 12:41 PM   #4798
does anyone know what new parts the TRF factory boys testet? On pictures i saw a new upper and lower deck and these parts are from raceberry. but i saw a picture with yokomo parts also. has somebody more informations?
Old 02-28-2013, 03:36 PM   #4799
i keep seeing the raceberry parts, is there a link to there site or anything? i cant find anything
theagentorange is offline   Reply With Quote
Old 02-28-2013, 08:37 PM   #4800
Will get a photo when I can, pretty much cut a slit down the centre to the screw hole.
Hi Antoni,
Attachment 1037545
thanks
Stefano
The rear diff gave the car more drive out of the corner and more corner speed, but also makes the car MUCH harder to drive. It seemed to suit that track, others where using up to 20k rear diffs. That is correct with how I ran the top deck, just to make the flex a bit softer.
Cheers
Antoni Caretti
Saudi Arabia RC Club grizzle Manila Racers 6558 01-06-2017 08:50 AM
Tamiya TRF415 JDM_DOHC_SiR Electric On-Road 21094 03-10-2016 11:02 AM
Tamiya TRF416 / TRF416WE / TRF416X academygaz Electric On-Road 10619 01-01-2015 03:36 PM
Tamiya TA05 IFS rcforum Electric On-Road 1132 12-18-2014 05:19 AM
"Ask" Jilles Groskamp Tamiya 416 & 417, Team Orion Motors JGH Electric On-Road 1996 05-27-2014 06:28 AM
