Old 02-23-2013, 01:12 AM   #4771
TryHard's Avatar
Originally Posted by scytherat View Post
How are you finding the serpent ed?
On my 417 i keep suffering from lift off over steer, current setup is 120wt diff oil ( just under 1500cst) 2deg rear camber 1deg front camber, 3 deg rear toe, 0 front toe, 6 frt 5 rear droop, 40wt shock oil, tamiya blue white springs hardest of the 2 on front, 1c fr Fr split 1c fr rr, 1xa split rr fr 1e rr rr. Rear camber links 3 under inside and outside, front camber links 4 inside 0 outside, front shock fully upright rears half way.
Any ideas. Thanks
Good, although I've only had the opportunity to get the Eryx on the track once so far... although my TE is also going well too.
Old 02-23-2013, 01:12 AM   #4772
chrisk's Avatar
Trader Rating: 32 (100%+)
No belt tensioner and why the post in the middle? Just for body support ???
TAMIYA - SMOKEM - REEDY
smaracing.org
chrisk is offline   Reply With Quote
Old 02-23-2013, 01:27 AM   #4773
Sith Lord's Avatar
Trader Rating: 21 (100%+)
Originally Posted by chrisk View Post
............ and why the post in the middle? Just for body support ???
I've seen that on a few cars, most recently a TC6. It stops the front of the body deflecting downwards at the high speeds of Mod.
Tamiya XV-01 Rally :: Tamiya FAV 2011 :: Proline Pro2 SCB
Sith Lord is offline   Reply With Quote
Old 02-23-2013, 06:40 AM   #4774
Trader Rating: 19 (100%+)
Originally Posted by TryHard View Post
It's interesting to catch that, someones been lucky with the camera.... It's also interesting that they are testing that configuration. On my current vehicle (Serpent Eryx) we can run both a 417V5 style mount, or the BD7 style mount setup out of the box I found the BD7 style to give more mid-rotation than the V5 setup...
Ed
What's up stranger??!!! Hope you are having fun with the new rides.
TEAMORCA.SHOP
MDawson is offline   Reply With Quote
Old 02-23-2013, 04:37 PM   #4775
CraigM's Avatar
Trader Rating: 34 (100%+)
Ed
The motor looks to be further forward on the development cars so I would expect that to rotate less than the regular setup
Any ideas. Thanks
What surface? You're shock angles are way off, lay the fronts down and stand the rear up.
www.facebook.com/mcpheerc
CraigM is offline   Reply With Quote
Old 02-24-2013, 01:06 AM   #4776
Carpet. Running sorex 32 tires
scytherat is offline   Reply With Quote
Old 02-24-2013, 01:55 AM   #4777
CraigM's Avatar
In that case your springs are fine. Your shock angles alone will cause the car to be very edgy, what wheelbase are you running front and rear?
Old 02-24-2013, 06:21 AM   #4778
I have 3mm spacer infront of front and rear wishbones i think, Dont. Have th car infront of me atm
Old 02-24-2013, 12:45 PM   #4779
John Doucakis's Avatar
Default New parts
I found this pic from Satoshi's car
You may see more in my blog.
JD & RACING
John Doucakis is offline   Reply With Quote
Old 02-24-2013, 01:28 PM   #4780
CraigM's Avatar
Go to 3.5mm in the rear, that really settles things down, and consider the 1.4 rear bar as well. Ackerman also has a big impact on how the car rotates, so if you are running a lot (e.g. 3mm) consider dialling it back
Old 02-25-2013, 06:34 AM   #4781
Brilliant craig thanks for ur help
Old 02-25-2013, 07:31 AM   #4782
Trader Rating: 24 (100%+)
[QUOTE=John Doucakis;11856004]I found this pic from Satoshi's car
JD & RACING
[URL="http://jdandracing.blogspot.com"]
Cool blog (site) John~!
JoeyE is offline   Reply With Quote
Old 02-26-2013, 12:39 AM   #4783
With one batter direct center pulley or one way centre pulley anybody know
ipanmina is offline   Reply With Quote
Old 02-26-2013, 01:44 AM   #4784
[QUOTE=JoeyE;11859441]
JD & RACING
Thanks Joey. I really appreciate it.
John
Old 02-26-2013, 09:14 PM   #4785
Yokomo_Ant3's Avatar
Trader Rating: 29 (100%+)
What a great race TITC was this year! The level of racing was even higher this year, and track conditions changed so much throughout the event, it was very hard to adapt the setup to what the track was doing. Pretty happy I made the B main again, had 2 crappy finals after being taken out in both after good starts! Nevertheless the car was really good, my setup should hopefully be on Petit soon I used all standard parts on my car, only used normal TRF dampers not aeration. I tested low shock towers and shocks but liked the standard parts better
If anyone has any questions please ask
Cheers,
Antoni
Antoni Caretti
Team Schumacher - Team Scorpion - Sweep Racing - Bezerk RC - Adelaide RC
Yokomo_Ant3 is offline   Reply With Quote
Saudi Arabia RC Club grizzle Manila Racers 6558 01-06-2017 08:50 AM
Tamiya TRF415 JDM_DOHC_SiR Electric On-Road 21094 03-10-2016 11:02 AM
Tamiya TRF416 / TRF416WE / TRF416X academygaz Electric On-Road 10619 01-01-2015 03:36 PM
Tamiya TA05 IFS rcforum Electric On-Road 1132 12-18-2014 05:19 AM
"Ask" Jilles Groskamp Tamiya 416 & 417, Team Orion Motors JGH Electric On-Road 1996 05-27-2014 06:28 AM
