Old 02-17-2013, 06:28 PM   #4741
Originally Posted by JGH View Post
Try a harder geardiff oil in the rear! I don't know what you are using now but something like 2K or 3K will be more stable on power out of the corner!
thanks, thats kinda what i was thinking. i'm using 1200 now. im running 10.5t or 4.5t, on a 5 sec/lap track.... start with 2k or go right up to 3k?
theagentorange is offline   Reply With Quote
Old 02-17-2013, 06:49 PM   #4742
CraigM's Avatar
Trader Rating: 34 (100%+)
How is TITC practice going Jilles? Good luck for the racing!
www.facebook.com/mcpheerc
CraigM is offline   Reply With Quote
Old 02-18-2013, 02:39 PM   #4743
Velocitygt's Avatar
Little bird tells me they are using a prototype car with lots of changes! Motor Bulkheads, lower deck, top deck and larger diff pulleys.
Scorpion Power Systems | Awesomatix | WTF Fans
Velocitygt is offline   Reply With Quote
Old 02-19-2013, 02:32 AM   #4744
who is your little bird?
-no86- is offline   Reply With Quote
Old 02-19-2013, 02:41 AM   #4745
That will be the 418 if its got new bulkheads.
The 39t pulleys from the Ta06 can fit on the 417, maybe they are using them?
http://www.theRcRacer.com/
TRF419, TBEvo6, TT02, VDF, TRF501x, TRF201, TRF101, Mi5, X-Ray T4-13, BD7 2014, A700 Evo, WR-02G
Qatmix is offline   Reply With Quote
Old 02-20-2013, 12:13 AM   #4746
CraigM's Avatar
I think they were testing with yokomo parts. I wouldn't read too much into it, 418 is a long way off
Old 02-20-2013, 12:23 AM   #4747
VooDooPH's Avatar
Trader Rating: 18 (100%+)
Send a message via Yahoo to VooDooPH
any "spy shots" from TITC?
[TRF418][TB-04Pro][FF-03Pro][M-05v2][TRF102][F-104 WGP][TT-01R TypeE]
[Cross CF-01'08][Yokomo R12][Team C TC02Evo][Team C T8E v3]
VooDooPH is offline   Reply With Quote
Old 02-20-2013, 04:36 AM   #4748
do you know which parts they tested?
Old 02-20-2013, 05:52 AM   #4749
Ahhhh....my 417x chasis broke at the rear screw sus mount ......(
does any body know i should just get the v5 lower deck or stick to the x chasis.
the x chasis has 2 thickness right? 2.5mm and 2.25mm which is better or just get v5 lower deck?
grauco is offline   Reply With Quote
Old 02-20-2013, 07:49 AM   #4750
nolo148's Avatar
Same thing happened to me to. Are the cso chassis any good?
nolo148 is offline   Reply With Quote
Old 02-20-2013, 01:03 PM   #4751
CraigM's Avatar
X is 2.25. I would just get the V5 chassis, but you'll need the servo mount as well because there is no outside servo hole. Grab the V5 top deck too
No
Old 02-20-2013, 02:19 PM   #4752
i tryed the smokem mx chassis on carpet and liked the driving style. in my opinion a great choise. last weekend i used the new v5 chassis, servo mount and upper deck. same laptimes but it feels better, more easy to drive and so more constantly. uve got the choise
Greeting
Old 02-20-2013, 11:25 PM   #4753
skyball's Avatar
+1...
I'm currently using the smokem mx with the smokem servo mount and the tamiya v5 upper deck and it's feeling great. Can't really compare it to the original v5 chassis though, since I never tried it.
The advantage of the smokem chassis is that you can still use the 417X servo mount (2 part). So if you want to replace the chassis only, you can go for the smokem.
Christian
[Sanwa M12][Awesomatix A800][Ronalds Yoke BD-7 2014][Roche P12 2016][Asso RC12R5.2][VBC LightningFXM]
skyball is offline   Reply With Quote
Old 02-21-2013, 04:00 AM   #4754
Lightbulb
[QUOTE=CraigM;11840441]X is 2.25. I would just get the V5 chassis, but you'll need the servo mount as well because there is no outside servo hole. Grab the V5 top deck too
Thats a good idea..lower deck USD85, upper deck USD20, Servo mount USD30.
Hemmmm
How about Front and rear damper stay? any diffrence or advice should i get too
Front damper USD13.20 Rear damper stay USD15.40..
and walla...i got a V5...
advisable or not advisable?... help guys...
Old 02-21-2013, 06:02 AM   #4755
spacendeman's Avatar
Send a message via MSN to spacendeman
[QUOTE=grauco;11843232]
Hemmmm
Don't know about the damper stay.. but if you want a complete V5 I also thought that you should buy new bulkheads as they are 0.5 or 1.0mm higher then the X ones.. But please someone correct me if I'm wrong.
spacendeman is offline   Reply With Quote
Saudi Arabia RC Club grizzle Manila Racers 6558 01-06-2017 08:50 AM
Tamiya TRF415 JDM_DOHC_SiR Electric On-Road 21094 03-10-2016 11:02 AM
Tamiya TRF416 / TRF416WE / TRF416X academygaz Electric On-Road 10619 01-01-2015 03:36 PM
Tamiya TA05 IFS rcforum Electric On-Road 1132 12-18-2014 05:19 AM
"Ask" Jilles Groskamp Tamiya 416 & 417, Team Orion Motors JGH Electric On-Road 1996 05-27-2014 06:28 AM
