Old 02-06-2013, 12:44 PM   #4696
I use Xenon spur gears with my 417X, and have found that they are thinner in the centre section than the Tamiya spurs, and using the kit blue spacer alone isn't quite enough to prevent the spur from having a little side to side 'wobble'. I just bought another kit spacer (mine was from RCMarket http://rcmarket.com.hk/product_info....ducts_id=10301), put that on the opposite side of the spur, and that cured the wobble. I haven't seen the Panaracer spacer, but presume that will do exactly the same job.
Toon is offline   Reply With Quote
Old 02-07-2013, 01:09 AM   #4697
Sith Lord's Avatar
Trader Rating: 21 (100%+)
Originally Posted by CraigM View Post
ok I'm with you now, the panaracer spacer is larger so I assume the gear is thinner.
Gotcha. either that or as Toon says, use a second Kit spacer. I must have been lucky with my spurs so far.
Tamiya XV-01 Rally :: Tamiya FAV 2011 :: Proline Pro2 SCB
Sith Lord is offline   Reply With Quote
Old 02-07-2013, 01:15 AM   #4698
Sith Lord's Avatar
Now for an actual problem I have. First run the other night, it went really well (in 17.5 Blinky) with the kit settings but then developed a weird noise, possibly like bad gear mesh. Tonight I have a real close look and listen - sounds like the rear diff - pulled the diff apart and it had NO oil. Kit oil had all leaked out. It seems to be a fairly easy diff to build. Did I miss something basic. The seal still seems flat and in one piece. Did I just not get those 4 little screws clamped down hard enough?
Old 02-07-2013, 06:32 AM   #4699
timmay langdell's Avatar
has anyone got marc's or viktor's carpet set up from round 2 of ets???
timmay langdell is offline   Reply With Quote
Old 02-07-2013, 12:46 PM   #4700
CraigM's Avatar
Trader Rating: 34 (100%+)
I don't think they were very happy with their cars at ETS but Viktor's winning setup from the charity race in Scandiano is posted on his blog
http://wilck.se/setups-trf417x/
www.facebook.com/mcpheerc
CraigM is offline   Reply With Quote
Old 02-08-2013, 10:52 AM   #4701
Questions?? 84179 TAMIYA TRF417 Center One-Way Set
can i use 84179 TAMIYA TRF417 Center One-Way Set 0n trf416
ipanmina is offline   Reply With Quote
Old 02-08-2013, 01:30 PM   #4702
Nope, it will not fit on the 416.
http://www.theRcRacer.com/
TRF419, TBEvo6, TT02, VDF, TRF501x, TRF201, TRF101, Mi5, X-Ray T4-13, BD7 2014, A700 Evo, WR-02G
Qatmix is offline   Reply With Quote
Old 02-08-2013, 04:33 PM   #4703
Quantra's Avatar
There are a couple of ways people tend to build the diff to get it leak free.
Here is one method: http://www.petitrc.com/reglages/tami...DiffalaMcPhee/
I do not use this method. I follow the video from Jilles Groskamp but use the TDX smart shim and Kyosho P5 o-rings. I also use AE green slime on the o-rings and paper gasket. Since building them like this I have 4 leak free diffs =]
JK video: http://www.youtube.com/watch?v=m_DhcfcO8dI
TDX smart shim: http://www.facebook.com/media/set/?s...0947622&type=3
Kyosho p5 o-ring: http://rcmarket.com.hk/product_info....oducts_id=9011
Vince Coleman
Quantra is offline   Reply With Quote
Old 02-08-2013, 06:52 PM   #4704
Trader Rating: 114 (100%+)
I have a one time run TRF417v5... Run indoor carpet... Local track closed..
Anyone interested? USA shipping only. Please send me PM.
Chris Furman is offline   Reply With Quote
Old 02-09-2013, 02:05 AM   #4705
Sith Lord's Avatar
Thanks Quantra. I'll remember those.
I may have found my diff 'noise' issue too. Not ashamed to say, maybe a learning experience for others too. Let's just say I'll double check the thickness of the shims I use next time Rebuild tonight. Test tomorrow. Hopefully that was the source of my leak too.
Old 02-09-2013, 08:05 AM   #4706
Unhappy
do you know what is the best centre pulley for trf416
Old 02-10-2013, 07:27 PM   #4707
Johnn27's Avatar
Trader Rating: 67 (100%+)
Default Metal bevel gears
Anyone switch over to the metal bevel gears? Building now and considering putting them in as I build.
Johnn27 is online now   Reply With Quote
Old 02-10-2013, 08:29 PM   #4708
Dusttt's Avatar
Trader Rating: 118 (100%+)
About to pick a v5 up and will be running blinky 17.5. What spurs fit the car? Also are there any "must" upgrades or is the car pretty much ready to go?
"Whiskey Tango Foxtrot"
Dusttt is offline   Reply With Quote
Old 02-10-2013, 10:06 PM   #4709
CraigM's Avatar
Yeah I reckon they're awesome. Haven't touched my diff since building it with metal gears, TDX shims, and kyosho o-rings. It's finally the diff we all wanted
Old 02-10-2013, 11:25 PM   #4710
nolo148's Avatar
where can i get some TDX shims?
nolo148 is offline   Reply With Quote
Saudi Arabia RC Club grizzle Manila Racers 6558 01-06-2017 08:50 AM
Tamiya TRF415 JDM_DOHC_SiR Electric On-Road 21094 03-10-2016 11:02 AM
Tamiya TRF416 / TRF416WE / TRF416X academygaz Electric On-Road 10619 01-01-2015 03:36 PM
Tamiya TA05 IFS rcforum Electric On-Road 1132 12-18-2014 05:19 AM
"Ask" Jilles Groskamp Tamiya 416 & 417, Team Orion Motors JGH Electric On-Road 1996 05-27-2014 06:28 AM
