Old 01-30-2013, 12:16 PM   #4666
Just wondering guys what are the best trf shocks for on road at the moment, the real options I think are the black ones or ul?ones but u tamiya guys know best, obviously the v5 ones is just have different tops
thanks J
Jampot is offline   Reply With Quote
Old 01-30-2013, 02:17 PM   #4667
CraigM's Avatar
Trader Rating: 34 (100%+)
Originally Posted by scytherat View Post
can someone explain to me how arm sweep affects the handling of the car. I currently run 1c 1c on the front but noticed that alot of people are running 1c 1b andf wondered how this affects the car
Less initial steering, more steering mid to exit
www.facebook.com/mcpheerc
CraigM is offline   Reply With Quote
Old 01-30-2013, 04:35 PM   #4668
Just looked again the black ones or worlds ones I think are the only 2 available now new. Opinions or other options apreciated thanks again J
Old 01-31-2013, 02:48 AM   #4669
Quick 417V5 comparison to the 417X
http://tamiyatorg.blogspot.com/2013/...omparison.html
torg is offline   Reply With Quote
Old 01-31-2013, 04:37 AM   #4670
CraigM's Avatar
Originally Posted by torg View Post
Thats so cool its not even funny, awesome job!
One other thing is the difference in setup. V5 is 0.75mm narrower at the blocks and has another 1mm of Ackerman plus 1mm less front wheelbase
Old 01-31-2013, 11:16 AM   #4671
So, now that the V5 kit is in the hands of a few guys, I am wondering about something that I am sure others will want to know as well, will the V5 lower deck fit onto a 417X?
I have a standard 417X, and was thinking about getting a Smokem 417MX chassis for it, as I race exclusively on carpet, and want to try a stiffer chassis. If the V5 lower deck (and servo mount) is a direct fit, then I will look at that option instead, as I have seem them available as individual items now from Hong Kong. The only concern that I have, is that I've seen a comment stating that the V5 motor mount raises the motor slightly higher than the X mount does, and so the cutout/groove under the motor isn't as deep on the V5 Lower deck as it is on the X.
So would the V5 lower deck work on an X, without causing motor clearance issues, and without having to also change the top deck/motor mount/lower bulkheads as well?
Toon is offline   Reply With Quote
Old 01-31-2013, 12:42 PM   #4672
RC MARKET's Avatar
Some TRF417V5 Spare parts arrived
Tamiya TRF417-ta-13404011.jpg   Tamiya TRF417-ta-13404012.jpg   Tamiya TRF417-ta-13404013.jpg   Tamiya TRF417-ta-13404014.jpg
RC MARKET is offline   Reply With Quote
Old 01-31-2013, 12:46 PM   #4673
Im quite sure that you can use the lower deck on a 417X. Still remember to use the new servo mount also. Im using the smokem mx chassis on high traction carpet at the moment and i like it. not faster than the standart 417 chassis but more easy and directly to drive.
if theres a mistake please correct me
-no86- is offline   Reply With Quote
Old 01-31-2013, 10:23 PM   #4674
nolo148's Avatar
Would changing the front sway bar to soft from medium help with reducing under steer? Running a 417x on medium grip carpet.
nolo148 is offline   Reply With Quote
Old 02-01-2013, 05:27 AM   #4675
I would look at either softening the front spring or moving the shock in one position towards the centre before changing the sway bar.
http://www.theRcRacer.com/
TRF419, TBEvo6, TT02, VDF, TRF501x, TRF201, TRF101, Mi5, X-Ray T4-13, BD7 2014, A700 Evo, WR-02G
Qatmix is offline   Reply With Quote
Old 02-01-2013, 07:32 AM   #4676
NItrox416's Avatar
I don't think you will have some issues with motor, because in the Jilles' topic, somebody ask if the motor had been raised up and he replied that the motor height is unchanged, just the center pulley is 1 mm higher.
NItrox416 is offline   Reply With Quote
Old 02-01-2013, 05:21 PM   #4677
narcotiks's Avatar
This is what he said 'The V5 motormount is 1mm higher then the 417X but the motor position is same as 417X. At the Worlds we ran 1mm higher motor position. The key pins under the motormount are for less tweak .'
can someone clarify if the ride reds and blues are softer than HPI silver springs(silver colour) ?
narcotiks is offline   Reply With Quote
Old 02-01-2013, 06:28 PM   #4678
CraigM's Avatar
Red harder/blue softer. The reds are very similar spring rate but feel quite different on track to the HPIs
Old 02-02-2013, 08:09 PM   #4679
narcotiks's Avatar
I was running allot of droop and more front droop than rear to get the grip i wanted with the HPI silvers. Tried the ride blues with less droop all round and it was better, but neglected to try the reds, i'll give them a try. Thanks
Old 02-03-2013, 09:38 AM   #4680
NItrox416's Avatar
Hi guys,
I was thinking to convert my x to v5, and when I was considering the lower deck. About it I work out two possibilities:
1) new tamiya lower deck with trf floating servo mount
2) smokem 417mx with 417ctr smokem floating servo mount
Which one would you suggest me?
thanks fo help
Saudi Arabia RC Club grizzle Manila Racers 6558 01-06-2017 09:50 AM
Tamiya TRF415 JDM_DOHC_SiR Electric On-Road 21094 03-10-2016 12:02 PM
Tamiya TRF416 / TRF416WE / TRF416X academygaz Electric On-Road 10619 01-01-2015 04:36 PM
Tamiya TA05 IFS rcforum Electric On-Road 1132 12-18-2014 06:19 AM
"Ask" Jilles Groskamp Tamiya 416 & 417, Team Orion Motors JGH Electric On-Road 1996 05-27-2014 07:28 AM
SEO by vBSEO 3.5.0
