Old 01-17-2013, 07:26 AM   #4591
Trader Rating: 18 (100%+)
Riddle me this fellow 417er's...
I have been racing the original 417 for about 2 years in a 17.5 blinky class. The track I run at requires around a 4.0 fdr. Because of this high gearing, the motor tends to get pretty hot after a normal race. I have always had to run a fan on the motor.
I bought the 417v5 and have raced 3 friday night club races now. I have not had to use a fan. The same exact motor, speedo, battery, fdr, body, etc. My motor always comes off at around 145 degrees.
I actually had a acer ceramic bearing set on the original 417, and found nothing binding in the drive train to explain the motor running hot. If anything, I would think the new 417v5 would make the motor run hot before the belts and bearings got broke in.
I'm not complaining, just can't figure out why this is happening. Any thoughts?
TamiyaMatt84 is offline   Reply With Quote
Old 01-17-2013, 07:54 AM   #4592
OnRDPassion's Avatar
Trader Rating: 54 (100%+)
Originally Posted by Taman View Post
Just got my 417V5 built, any suggestions for an blinky mode 17.5T motor on a med grip asphalt track? I've built the car as per the kit instructions. I've seen the Japanese drivers setup sheets on petite rc, are they a good starting point? Thanks
I built my car as per the kit manual and ran it last weekend for the first time on similar track conditions, except the track temp was super cold. The kit setup was awesome! I only really ended up going to a slightly stiffer spring in the front and then moved the rear shock position in one hole.
Jay Williams
Xray RX8 2014
RC America - Protoform Racing - KO Propo USA - Kevco Racing / Picco EDO Modified - Byrons Fuels
OnRDPassion is offline   Reply With Quote
Old 01-17-2013, 11:58 AM   #4593
NItrox416's Avatar
Do you check the weight of the two cars?
NItrox416 is offline   Reply With Quote
Old 01-17-2013, 12:01 PM   #4594
NItrox416's Avatar
Hi guys,
somebody knows when tamiya will release the new parts of trf417v5 in particular the new upper e lower deck as option for the standard 417x.
Old 01-17-2013, 10:16 PM   #4595
Stryder's Avatar
is it possible to upgrade the 417 to the v5? bought the CSO world edition conversion but after reading previous posts, some said the bulkheads are slightly higher. Do any of you know exactly how many mm it is?
Stryder is offline   Reply With Quote
Old 01-17-2013, 10:59 PM   #4596
RL.2002's Avatar
+1
the passion of the slide when taking the corner....
http://www.penabai-rcdrifter.blogspot.com/
Kyosho TF-5 drift spec powered by Ezrun 35A + 9t
Tamiya TRF-416X, Tamiya TRF-417
Hobbywing Xerun 120A, Xerun 3.5t, Team Orion 11.5t, Xerun 5.5t
RL.2002 is offline   Reply With Quote
Old 01-18-2013, 01:08 AM   #4597
I think u have to raise the bulkheads buy 0,5 mm to have the same high on the 417x as the 417v5
Cp Grafix is offline   Reply With Quote
Old 01-18-2013, 01:42 AM   #4598
CraigM's Avatar
Trader Rating: 34 (100%+)
CSO is not real carbon, it's softer than the 417x bottom deck. The 417V5 lower deck is stiffer than both.
Bulkheads are 0.5mm higher on the V5 and the top deck is an additional 0.5mm higher - the top deck cannot be shimmed up on a normal 417 because the centre shaft will move vertically
I have a 417X with the bulkheads shimmed, it's good but nowhere near as direct as the V5.
www.facebook.com/mcpheerc
CraigM is offline   Reply With Quote
Old 01-18-2013, 01:58 AM   #4599
setanborneo's Avatar
where i can get video for rebound setting for 417V5 aeration shock?
i have problem to setting shock rebound, temporarily i use full rebound for my v5 shock
Tamiya 417 V5 - Tamiya M05 Pro
Kyosho MP9 TKI3 - OS Engine - AKA - ByronFuels - Futaba
setanborneo is offline   Reply With Quote
Old 01-18-2013, 02:59 AM   #4600
Anyone ran the V5 stock set-up on carpet? Whats it like?
As an aside, I've got my 417 running really well carpet with rubber tyres in Blinky 17.5. I will post the set-up soon.
http://www.theRcRacer.com/
TRF419, TBEvo6, TT02, VDF, TRF501x, TRF201, TRF101, Mi5, X-Ray T4-13, BD7 2014, A700 Evo, WR-02G
Qatmix is offline   Reply With Quote
Old 01-18-2013, 04:44 AM   #4601
Chris Furman's Avatar
Trader Rating: 112 (100%+)
It runs well... For high traction carpet... Found that I needed stiffer springs, thick sway bar, adjust roll center to correct traction roll.
Chris Furman is offline   Reply With Quote
Old 01-18-2013, 06:51 AM   #4602
SS LS1's Avatar
Trader Rating: 23 (100%+)
Like Chris said the V5 works very good on carpet with the new shocks. Our track is bumpy low to med grip carpet so needed to run softer springs, stock sways and it is better than the 417x so far. (only been running for 2 weeks)
Tamiya 417v7 Sedan, ___ Tamiya 417v7 USGT, ___ CEFEX EVO w/ 417 suspension VTA
Exotex TA06 Pro CS Drifting, ___ Tamiya 417v5 (sold)
AE SC10 4x4
AE SC10 AE B4.11
SS LS1 is offline   Reply With Quote
Old 01-18-2013, 07:04 AM   #4603
SS LS1's Avatar
Originally Posted by CraigM View Post
Bulkheads are 0.5mm higher on the V5 and the top deck is an additional 0.5mm higher - the top deck cannot be shimmed up on a normal 417 because the centre shaft will move vertically.
Craig, I understand the center shaft would move vertically if you just used plain 0.5mm washer spacers but why not use a long shim to bridge over the top of the the center shaft to prevent that from happening? I'm thinking a .05mm anti squat suspension shim plate trimmed and drilled to fit (just over the center shaft, washers everywhere else). Any reason that would not work?
AE SC10 4x4
AE SC10 AE B4.11
Old 01-18-2013, 08:19 AM   #4604
RC MARKET's Avatar
Some TRF417V5 spare parts on the way now !!
Tamiya TRF417-ta-13454880.jpg   Tamiya TRF417-ta-11424473.jpg   Tamiya TRF417-ta-13454872.jpg   Tamiya TRF417-ta-13454876.jpg
RC MARKET is offline   Reply With Quote
Old 01-18-2013, 02:16 PM   #4605
CraigM's Avatar
That would work but I think you'd need to use all 4 screws in the motor mount. I'm sure you could work something out, but I can't see it making enough difference to be worth the effort
Any news on the driveshaft blades? Not that mine are at all worn
Saudi Arabia RC Club grizzle Manila Racers 6558 01-06-2017 09:50 AM
Tamiya TRF415 JDM_DOHC_SiR Electric On-Road 21094 03-10-2016 12:02 PM
Tamiya TRF416 / TRF416WE / TRF416X academygaz Electric On-Road 10619 01-01-2015 04:36 PM
Tamiya TA05 IFS rcforum Electric On-Road 1132 12-18-2014 06:19 AM
"Ask" Jilles Groskamp Tamiya 416 & 417, Team Orion Motors JGH Electric On-Road 1996 05-27-2014 07:28 AM
SEO by vBSEO 3.5.0
