Old 01-14-2013, 01:02 PM   #4576
2-Bad's Avatar
Trader Rating: 24 (100%+)
Originally Posted by G4ZZ4 View Post
Hi guys just remembered. To take the movement out of the shocker piston is to bend e-clip a little.
Or you may want to consider using a 0.1mm x 3mm shim under the shock piston to remove any play... Red RC Pro Tips with Jilles Groskamp - Part 1
Yokomo * G Force * Sanwa * SMC * ProSpec
2-Bad is offline   Reply With Quote
Old 01-14-2013, 01:15 PM   #4577
G-kenny's Avatar
Im selling my Tamiya 417x Inc hop-ups and spare if any one is intrested.
See here for details
http://www.oople.com/forums/showthre...907#post732907
G-kenny is offline   Reply With Quote
Old 01-14-2013, 03:28 PM   #4578
I'd highly recommend the spacer. I haven't tried bending the e-clip on my Tamiya shocks, but on my Schumacher shocks it would tend to make the piston sit crooked. With the spacer, it stays nice and flat.
-Mike
Old 01-14-2013, 03:35 PM   #4579
meccanico's Avatar
here my set up modified class for medium grip carpet
meccanico is offline   Reply With Quote
Old 01-14-2013, 04:16 PM   #4580
G4ZZ4's Avatar
-Mike
Yes i never thought of that thank you
cheers Garry
YOKOMO BD7, 21.5 boosted M11x
S2H bodies
G4ZZ4 is offline   Reply With Quote
Old 01-15-2013, 11:51 AM   #4581
Trader Rating: 40 (100%+)
Not sure where to post this but does what is a good set of Tamiya touring spring to get? There are so many different set out there and I just not sure. I'm new to Tamiya cars.
Does anyone know the different rate between the Tamiya springs?
v_squared is offline   Reply With Quote
Old 01-15-2013, 12:26 PM   #4582
Trader Rating: 114 (100%+)
Tamiya
Spring Rating [lb/in]
Purple 22.72
Gray 20.91
White Short 17.24
Blue Short 15.27
White 14.82
Blue 14.08
Yellow 13.33
Red Short 13.24
Yellow Short 12.90
Red 11.86
Chris Furman is offline   Reply With Quote
Old 01-15-2013, 01:19 PM   #4583
Thank you Chris.
Old 01-16-2013, 12:04 AM   #4584
Originally Posted by Chris Furman View Post
Tamiya
Purple 22.72
Gray 20.91
White Short 17.24
Blue Short 15.27
White 14.82
Blue 14.08
Yellow 13.33
Red Short 13.24
Yellow Short 12.90
Red 11.86
Whats the deal with the "Short" Springs? Are they actually shorter than the regular ones? If so what purpose does it serve?
Glarke is offline   Reply With Quote
Old 01-16-2013, 09:44 AM   #4585
SS LS1's Avatar
Trader Rating: 23 (100%+)
I may be wrong but I believe the TC cars use the regular springs and the "SHORT" springs are indeed shorter in length and used on the MINI cars with their smaller shocks.
SS LS1 is offline   Reply With Quote
Old 01-16-2013, 09:47 AM   #4586
Fuzzi0n's Avatar
I'm pretty sure that's their intended use. They're not a lot shorter and you can use them on normal shocks no problem which will give you a few more options on spring rate.
Spec-R S1, Schumacher CAT SX3 S1
Fuzzi0n is offline   Reply With Quote
Old 01-16-2013, 11:56 PM   #4587
Taman's Avatar
Trader Rating: 64 (100%+)
Just got my 417V5 built, any suggestions for an blinky mode 17.5T motor on a med grip asphalt track? I've built the car as per the kit instructions. I've seen the Japanese drivers setup sheets on petite rc, are they a good starting point? Thanks
Toms 84C, Nissan R91CP, Porsche 956, TRF 417 V5.
Taman is offline   Reply With Quote
Old 01-17-2013, 02:50 AM   #4588
Sith Lord's Avatar
Trader Rating: 21 (100%+)
Hi all. I'm just stocking up on some spares that I may need when I start racing the 417v5 - Are there any aftermarket suppliers that I shouldl stay away from? Most parts will be Tamiya, but one thing I can't find at the moment are the suspension balls:
Tamiya: http://www.rcmart.com/tamiya-53709-f...l-p-28915.html
Can I use the CSO ones instead: http://rcmarket.com.hk/product_info....ducts_id=13141
Cheers
Tamiya XV-01 Rally :: Tamiya FAV 2011 :: Proline Pro2 SCB
Sith Lord is offline   Reply With Quote
Old 01-17-2013, 02:55 AM   #4589
kentech's Avatar
Cheers
Better use Tamiya #50994 if you can't find the fluorine ones.
50994 5mm Suspension Ball
For these parts I would stay away from other manufacturers.
kentech.wordpress.com
kentech is offline   Reply With Quote
Old 01-17-2013, 03:06 AM   #4590
Sith Lord's Avatar
That was my thought. Thanks for your quick reply !
Saudi Arabia RC Club grizzle Manila Racers 6558 01-06-2017 08:50 AM
Tamiya TRF415 JDM_DOHC_SiR Electric On-Road 21094 03-10-2016 11:02 AM
Tamiya TRF416 / TRF416WE / TRF416X academygaz Electric On-Road 10619 01-01-2015 03:36 PM
Tamiya TA05 IFS rcforum Electric On-Road 1132 12-18-2014 05:19 AM
"Ask" Jilles Groskamp Tamiya 416 & 417, Team Orion Motors JGH Electric On-Road 1996 05-27-2014 06:28 AM
