Old 01-12-2013, 09:44 PM   #4561
Originally Posted by CraigM View Post
Kit setup is a good starting point for low grip asphalt, but you are better off with HPI or Ride springs
I was thinking 400 front and rear for the shocks and either 900 or 1k for the diff - Seems to be fairly common
What are the advantages of HPI/Ride springs?
+ one more question. The manual has a odd way of giving droop settings so what is a decent starting point for droop?
Glarke is offline   Reply With Quote
Old 01-12-2013, 09:47 PM   #4562
Originally Posted by Racing4Evo View Post
For what car? I haven't driven the new V5 but to answer your question..no, the stock setup is pretty bad for low traction.
This setup is for the original 417 but works for the 417x as well. It works really good, easy to drive and is very close to what I run. It works almost everywhere on asphalt and carpet with only spring and oil changes necessary. I use the stock toe blocks in the rear as opposed to the ones listed on the setup sheet.
http://www.petitrc.com/reglages/tami...tion201112.pdf
Sorry - 417x
Old 01-13-2013, 01:12 AM   #4563
CraigM's Avatar
Trader Rating: 34 (100%+)
Kit is 4mm front and rear for droop, start with maybe 5mm front 4mm rear for low grip and tune from there. You'll have more grip and corner speed with the ride or HPI springs, the tamiya's are mainly used on carpet
www.facebook.com/mcpheerc
CraigM is offline   Reply With Quote
Old 01-13-2013, 07:49 AM   #4564
setanborneo's Avatar
which ride spring for asphalt medium traction grip? i want try
Tamiya 417 V5 - Tamiya M05 Pro
Kyosho MP9 TKI3 - OS Engine - AKA - ByronFuels - Futaba
setanborneo is offline   Reply With Quote
Old 01-13-2013, 08:36 AM   #4565
I like the ride red spring front and rear A LOT.
napoleon1981 is offline   Reply With Quote
Old 01-13-2013, 09:01 AM   #4566
Awesome - Thanks
Old 01-13-2013, 09:36 AM   #4567
nolo148's Avatar
Hi, does anyone have a medium grip carpet setup for the 417x? The track is 4 carpet rolls almost rolled out. I'm running 17.5 blinky.
nolo148 is offline   Reply With Quote
Old 01-13-2013, 10:16 AM   #4568
getting ready to build my v5. I have a bag of Steel Bevel Gears - For TA06 Gear Diff Unit
Item #54428. Good idea, bad idea or doesn't matter. Thinking of running a 10.5 LRP x20 motor. I'm not racing, just an enthusiast. I crash plenty... so reliability is more important to me than speed
torg is offline   Reply With Quote
Old 01-13-2013, 12:58 PM   #4569
CraigM's Avatar
^^^ what he said
I have the full range of both sets from ride and the reds are the only ones I like
Old 01-13-2013, 02:44 PM   #4570
i will try, thanks for both of you
Old 01-13-2013, 06:07 PM   #4571
maxepower's Avatar
Talking RE: gears
I just put the steel beveled gears in my 417X about three race weeks ago and so far working great no issues. I've gone thru about 3 sets of the reinforced plastic gears since the 417X first came out so I was glad when Tamiya fixed this problem. Mostly ran 13.5 and 17.5.
Just my 2$
Tamiya Track Local. 10,000 Watts of power! ($5 donations for gas appreciated)
Proud Father of GT-1 Past Champion!"Hey, I got to go to Japan too!
FF03,TA-05V2 ,EXO-6,TA-07,TRF419,EVO-6
"Tamiya Racer to Infinity and Beyond!"
maxepower is offline   Reply With Quote
Old 01-13-2013, 06:59 PM   #4572
OnRDPassion's Avatar
Trader Rating: 54 (100%+)
Just ran my 417 today and wow what an awesome car. I Tq'ed and won the stock class. Great handling still need to work out a few things but overall very satisfied with it. Can't wait to get to run it on the Tamiya America track!
OnRDPassion is offline   Reply With Quote
Old 01-13-2013, 07:30 PM   #4573
G4ZZ4's Avatar
Hi guys just remembered. To take the movement out of the shocker piston is to bend e-clip a little.
cheers Garry
YOKOMO BD7, 21.5 boosted M11x
S2H bodies
G4ZZ4 is offline   Reply With Quote
Old 01-13-2013, 08:54 PM   #4574
Trader Rating: 26 (100%+)
Is the TAMIYA track open or closed for winter?
Just did up a Ferrari body that I had laying around.
JoeyE is offline   Reply With Quote
Old 01-14-2013, 08:56 AM   #4575
meccanico's Avatar
here my set up for the medium grip carpet of WRC Factory Track
you may also try 300 front and 400 rear damper oil with blue spring front and yellow spring rear
meccanico is offline   Reply With Quote
Saudi Arabia RC Club grizzle Manila Racers 6558 01-06-2017 08:50 AM
Tamiya TRF415 JDM_DOHC_SiR Electric On-Road 21094 03-10-2016 11:02 AM
Tamiya TRF416 / TRF416WE / TRF416X academygaz Electric On-Road 10619 01-01-2015 03:36 PM
Tamiya TA05 IFS rcforum Electric On-Road 1132 12-18-2014 05:19 AM
"Ask" Jilles Groskamp Tamiya 416 & 417, Team Orion Motors JGH Electric On-Road 1996 05-27-2014 06:28 AM
