Like Tree1Likes
Old 01-06-2013, 01:38 PM   #4531
CraigM's Avatar
Trader Rating: 34 (100%+)
Originally Posted by narcotiks View Post
Since they arent seperately avaliable yet, which top deck out of the "x" , 417, and 417 with cut front brace would be the most appropriate replacement until the v5 top decks are released ?
Good question, I think maybe the original 417 deck with the rear cut
Originally Posted by NItrox416 View Post
Hi Graig
Thank you for the reply. But with which chassis did you try it? The 417x original one?
Yes original 417x
www.facebook.com/mcpheerc
CraigM is offline   Reply With Quote
Old 01-06-2013, 04:47 PM   #4532
Hi guys,
I just bought a used Tamiya TRF 417X from a friend, the car feels amazing and I love it.
But I have one question, would it be possible to fit the V5 servo mount on the 417X? I wanna know if it could physicaly fit under the top deck? Forget about the extra holes on the chassis, I can take care of the drilling....
I know Smokem makes one for the 417X but I wanna use the car for TCS races in Canada and I wan't the car to be all Tamiya.
Thank you very much in advance for your time.
stidanielt09 is offline   Reply With Quote
Old 01-06-2013, 04:48 PM   #4533
Trader Rating: 114 (100%+)
Originally Posted by stidanielt09 View Post
Hi guys,
You running indoor carpet or outdoor? if indoor, keep the servo the way it is.
Chris Furman is offline   Reply With Quote
Old 01-06-2013, 04:56 PM   #4534
Thanks for fast answering
Old 01-07-2013, 02:09 AM   #4535
narcotiks's Avatar
Thanks Craig ill try it out
narcotiks is offline   Reply With Quote
Old 01-07-2013, 05:39 AM   #4536
Trader Rating: 18 (100%+)
It depends on the traction level. A lot of indoor carpet "club" tracks have low to medium grip carpet. At my local track the carpet is low grip and the new servo holder made a pretty significant difference in low speed cornering.
TamiyaMatt84 is offline   Reply With Quote
Old 01-07-2013, 06:33 AM   #4537
NItrox416's Avatar
Hi, in what way it help in low speed corners?
thanks for reply.
@Craig: Thankyou
NItrox416 is offline   Reply With Quote
Old 01-08-2013, 09:52 AM   #4538
LOL... You are right.. I was thinking of my area I guess. Most of our indoor carpet tracks are high bite, sometimes very high bite.
Old 01-08-2013, 09:57 AM   #4539
thanks for reply.
@Craig: Thankyou
If the track is "low bite" it frees up additional flex to the chassis. BUT, there are other things that you can do, springs, roll center, sways that will make a greater difference than a servo mount. If you are at the limit of your car setup, then I would try the servo mount last.
Old 01-08-2013, 01:59 PM   #4540
OnRDPassion's Avatar
Trader Rating: 54 (100%+)
Boom just ordered my 417 V5. Can't wait to get it and try it out!
OnRDPassion is offline   Reply With Quote
Old 01-08-2013, 08:50 PM   #4541
i am runnung a 417x..... can the new servo mount (v5) use in the 417x lower deck?
grauco is offline   Reply With Quote
Old 01-08-2013, 11:44 PM   #4542
VooDooPH's Avatar
Send a message via Yahoo to VooDooPH
not a direct fit...
[TRF418][TB-04Pro][FF-03Pro][M-05v2][TRF102][F-104 WGP][TT-01R TypeE]
[Cross CF-01'08][Yokomo R12][Team C TC02Evo][Team C T8E v3]
VooDooPH is offline   Reply With Quote
Old 01-08-2013, 11:45 PM   #4543
I think u have to make a hole for the tap on the servo mount, however its not round so i might be hard to make it fit proberly.
Cp Grafix is offline   Reply With Quote
Old 01-09-2013, 10:37 AM   #4544
The mount looks cool, but I promise you. It won't make the car faster around the track. Basically what I'm saying is don't worry about it. Shoe goo it if your worried about equal flex. That will save even more weight.
Juan Aveytia is offline   Reply With Quote
Old 01-09-2013, 05:14 PM   #4545
Default loose off power suddenly
Currently have this issue suddenly on my 417x.
My car tends to loose off power. Running on a low traction asphalt.
Box set up with minimum changes. just out of sudden it's so loose.
following set up is what i did to make the car handle well.
box set up for WB except front upper camber link 2mm spacer, rear upper camber link 4mm. toe out 2.5 degree. Ackerman 1mm spacer. droop front 4 and rear 5.
I find that howcome the car handles so differently hence I revert back to box set up but the car handles the same.
Currently car set up is "box set up", what i only change is front inner block 1b, front upper camber link with 3mm spacer. Front toe out 1degree. camber 1degree front and rear 1degree. droop front 6 rear 5
Spool in front and 1000wt for the rear. Running on ride spring front yellow and rear white
The car is still very loose off power compared to last time
Wonder for RCA is it ok to run such a difference on the upper camber link. and ackerman. Or I shld as long as the car handles well, differences doesn't matter.
Trackie is offline   Reply With Quote
Saudi Arabia RC Club grizzle Manila Racers 6558 01-06-2017 08:50 AM
Tamiya TRF415 JDM_DOHC_SiR Electric On-Road 21094 03-10-2016 11:02 AM
Tamiya TRF416 / TRF416WE / TRF416X academygaz Electric On-Road 10619 01-01-2015 03:36 PM
Tamiya TA05 IFS rcforum Electric On-Road 1132 12-18-2014 05:19 AM
"Ask" Jilles Groskamp Tamiya 416 & 417, Team Orion Motors JGH Electric On-Road 1996 05-27-2014 06:28 AM
