Like Tree1Likes
Old 12-25-2012, 06:13 PM   #4486
Originally Posted by CraigM View Post
The shocks are quite easy to build, I can put a build guide on my blog if people would like?
Basic steps:
1. Assemble the shocks
2. Fill the body with oil
3. Use a shock pump to get the air out
4. With the piston fully extended, fill the shock to the brim with oil - have it completely full, almost so it's spilling over the sides
5. With the bleeder screw removed, tighten the cap slowly. The bleeder hole with bubble a few times as you screw the cap down
6. Slowly push the piston fully into the body. Oil will spill out of the bleeder hole
7. Screw the bleeder screw in
The shocks should feel smooth and air free. When you pull the piston out it should suck back in to within 1mm of the body. You should be able to fully compress the shock without hydraulic lock at the top - if this happens you need to bleed the shock again.
I found my shocks got bit better with more use, the first couple times I built them I couldn't get them exact but now they are worn in they are much better.
Edit: Lee Martin's explanation of the same thing is about half way down this page http://www.trfracing.co.uk/page_1265187551237.html This is for the buggy shocks but it's all the same
Can the aeration shocks be built with little to no rebound?
mhavlena is offline   Reply With Quote
Old 12-25-2012, 06:42 PM   #4487
mingnon's Avatar
+1 - these shocks are easiest to build, was amazed got them done first time.
Got the V5 built, and ready to run
Thanks for the build blog Craig
---------------------------SMA The Home of GREAT Racing------------------------------
mingnon is offline   Reply With Quote
Old 12-26-2012, 04:46 AM   #4488
Skiddins's Avatar
They are designed to have 'negative rebound' so they will actually pull the rod back into the shock body.
Elliot Harper has been running standard TRF shocks on carpet, not the aeration type.
Xray T4'18, T4'14 (Wet Car)
Xray X12 2018
Xray X1'16
wlrc.co.uk (West London Racing Centre)
RCDisco.co.uk
Skiddins is offline   Reply With Quote
Old 12-26-2012, 05:45 AM   #4489
Johnn27's Avatar
Trader Rating: 71 (100%+)
Thumbs up trf dampers
Does anyone have the part number for the regular trf damper set?
Johnn27 is offline   Reply With Quote
Old 12-26-2012, 07:47 AM   #4490
Pro10noob's Avatar
If i am not mistaken it is 42102.
http://www.ebay.nl/sch/i.html?LH_Pre...w=Tamiya+42102
Regards Roy
l===/o\===l
[_]-###-[_] V-link proto type Pro10,JKMR P235-SE Pro10
P235-VL Pro10 comming soon
Sponsered by me,myself and i :)
Pro10noob is offline   Reply With Quote
Old 12-26-2012, 10:00 AM   #4491
This is a limited edition version of the TC shocks...if you are interested (I picked up a set...just released in Canada a couple of weeks ago):
I can't post links yet but the item number is 84317
It is my first time running the X-ring O-rings...The X-rings are so smooth (and lacking friction) it almost feels like there is no O-ring in the shock.
Cheers
__________________________________________________
Xray T4 '16, Tamiya 417v5, Tamiya M05 pro, Tamiya 501X WE, Losi XXX-SCT, Losi/MIP SCTE, Xray XB808e, Xray XT9e.
zimmie is offline   Reply With Quote
Old 12-26-2012, 07:09 PM   #4492
Originally Posted by tamiya-2012nz View Post
my friend has the 417x and it keeps chewing the gears in the geardiff any fix to this???
Good to see someone else in NZ running the 417's. What class is he running or what turn motor? Has he looked @ Jilles Groskamp's Redrc gear diff building tips on Youtube? It is really helpful as it shows how to sand and shim gear diff gears. There are a some metal gear diff gears available now through HK if all else fails
Cheers
Anthony
anzmania is offline   Reply With Quote
Old 12-28-2012, 12:04 PM   #4493
silverhkswrx's Avatar
Send a message via AIM to silverhkswrx Send a message via Skype™ to silverhkswrx
Originally Posted by Juan Aveytia View Post
Being a sponsored driver I would imagine Tamiya would like their drivers to run the latest and Greatest. Plus, the new chassis won the worlds. Also the newer chassis seems faster from all the reports. Why isn't your sponsor helping you with this decision?
From several reports (and Juan's expertise) the two chassis are 100% interchangeable. If you get the non v5, you just need upper and lower deck and servo mount. (Of course you can get the v5 shock mounts, aeration dampers and dcjs, steel diff gears and other misc items only available on the v5 separately, but you can spend the $170 and just save the headache.)
My recommendation, go with the v5, if you feel you need more flex, buy the reedy race upper and lower deck. I believe everything is interchangeable between the two. I'm sure with you being a team driver, your price can't be beat.
I just want to know when the lower/upper deck and servo mount will be sold separately. For those who have owned the 417x and already bought all the mods.
SpeedPassion 17.5R powered TRF417X
My son owns: Team Associated RC18R2
(RC18B2 converted to a RC18R)
http://www.tamiya.com/english/rc/manuals.htm
silverhkswrx is offline   Reply With Quote
Old 12-28-2012, 12:15 PM   #4494
edit: actually simple solution if you have the old car and want to use the new bottom deck - just space all your bulkheads up by 0.5mm
So just .5 mm spacers when connecting the upper deck to the bulkheads? I personally see this...flexibility(no pun intended) beneficial. When keeping the upper and lower decks closer, the chassis twist will be reduced. The more distance the more twist, right?
I'm trying to apply spacing logic to my non-v5 for more options.
Old 12-28-2012, 12:23 PM   #4495
Robkitetop's Avatar
The Reedy edition lower and upper deck are stiffer then the stock 417x specifically designed for high bite tracks:
Stock = 2.25 mm
Reedy Edtion = 2.5 mm
Just to share the correct information.
Regards,
Robbert
Robkitetop is offline   Reply With Quote
Old 12-28-2012, 12:27 PM   #4496
Stock = 2.25 mm
Regards,
Robbert
Correct. My recommendation was to purchase the v5 and other upper and lower chassis options for additional flex (if needed).
In order of stiffness(if I am not mistaken)is
trf417x
trf417
trf417x reedy
trf417x v5
This is referring to combination of the respective upper and lower decks. Interchanging upper and lower decks can produce different results.
Old 12-28-2012, 07:14 PM   #4497
CraigM's Avatar
Trader Rating: 34 (100%+)
The 2.5mm chassis is stiffer than v5, and no the spacers go between the chassis and the bulkheads - the v5 bulkheads are all different to the X, diffs are 0.5 higher and top deck is 1mm higher
www.facebook.com/mcpheerc
CraigM is offline   Reply With Quote
Old 12-28-2012, 09:19 PM   #4498
VooDooPH's Avatar
Trader Rating: 18 (100%+)
Send a message via Yahoo to VooDooPH
so to get something similar to the v5, .5 shims between the chassis and bulkheads, and another .5mm shims between the bulkheads and top deck?
[TRF418][TB-04Pro][FF-03Pro][M-05v2][TRF102][F-104 WGP][TT-01R TypeE]
[Cross CF-01'08][Yokomo R12][Team C TC02Evo][Team C T8E v3]
VooDooPH is offline   Reply With Quote
Old 12-29-2012, 01:27 AM   #4499
CraigM's Avatar
It's hard to do that because with 0.5mm on top of the motor bulkhead the centre shaft can move up and down. You can either lift the centre bulkheads a full 1mm or not worry about raising the top deck. I tried both ways on my X and preferred 0.5mm under all bulkheads. The V5 still feels much sharper though.
Old 12-29-2012, 04:16 AM   #4500
Stock = 2.25 mm
Regards,
Robbert
Just for your info. The reedy edition had 2.25mm chassis, mine did
http://translate.google.co.uk/transl...ed=0CDwQ7gEwAg
Smartypants is offline   Reply With Quote
Saudi Arabia RC Club grizzle Manila Racers 6558 01-06-2017 08:50 AM
Tamiya TRF415 JDM_DOHC_SiR Electric On-Road 21094 03-10-2016 11:02 AM
Tamiya TRF416 / TRF416WE / TRF416X academygaz Electric On-Road 10619 01-01-2015 03:36 PM
Tamiya TA05 IFS rcforum Electric On-Road 1132 12-18-2014 05:19 AM
"Ask" Jilles Groskamp Tamiya 416 & 417, Team Orion Motors JGH Electric On-Road 1996 05-27-2014 06:28 AM
