Old 12-21-2012, 12:18 AM   #4456
setanborneo's Avatar
finisihing build v5, but still confuse where the best place to placing old AMB personal transponder
Tamiya 417 V5 - Tamiya M05 Pro
Kyosho MP9 TKI3 - OS Engine - AKA - ByronFuels - Futaba
setanborneo is offline   Reply With Quote
Old 12-21-2012, 01:42 AM   #4457
VooDooPH's Avatar
Trader Rating: 18 (100%+)
Send a message via Yahoo to VooDooPH
on the bumper
[TRF418][TB-04Pro][FF-03Pro][M-05v2][TRF102][F-104 WGP][TT-01R TypeE]
[Cross CF-01'08][Yokomo R12][Team C TC02Evo][Team C T8E v3]
VooDooPH is offline   Reply With Quote
Old 12-21-2012, 02:03 AM   #4458
Sith Lord's Avatar
Trader Rating: 21 (100%+)
Mine fits flat on the chassis behind the servo (using Futaba low profile and Tekin ESC)
Tamiya XV-01 Rally :: Tamiya FAV 2011 :: Proline Pro2 SCB
Sith Lord is offline   Reply With Quote
Old 12-21-2012, 04:39 AM   #4459
kentech's Avatar
Originally Posted by hanulec View Post
i see some new stuff -- but it doesn't look like the aerator shocks yet. do you know the part number? thx!
Aeration dampers are not available as a set (at least not yet, there is no such product or part# released) so you need to buy the parts separately if you want them. The only new parts though are the cylinders (#9804672) and (#9804671) Ball connector nuts.
The rest are old parts; i.e. from the std TRF dampers and TRF buggy dampers.
If you would want to convert std. TRF dampers you'd need:
51280 Cylinder caps
9804672 Cylinders
9804291 O-rings
9805779 2x5mm Cap screws
9804671 Ball connector nut (for mounting to tower, but the easy and already available part to use here is the #54205, which is the same part but with different coating)
That should be all that's different.
kentech.wordpress.com
kentech is offline   Reply With Quote
Old 12-21-2012, 05:07 PM   #4460
Can anyone confirm the part number for the plastic part of the TRF damper caps? I see a couple things on Speedtech that look right, but I'm not sure which.
There's this one:
http://www.speedtechhobbies.com/inde...product_id=198
And this one:
http://www.speedtechhobbies.com/inde...product_id=382
-Mike
Old 12-21-2012, 05:32 PM   #4461
superspeed's Avatar
low friction v parts tree
superspeed is offline   Reply With Quote
Old 12-21-2012, 05:34 PM   #4462
superspeed's Avatar
there are plenty of room to mount the transponder, the more forward you can place the better when across the finish line side by side
Old 12-21-2012, 06:07 PM   #4463
Tamiya have listed the dampers as a set some time ago. Something like special damper set. I'm out but the part no is on the tamiya site (Japan)
51280 Cylinder caps
9804672 Cylinders
9804291 O-rings
http://www.theRcRacer.com/
TRF419, TBEvo6, TT02, VDF, TRF501x, TRF201, TRF101, Mi5, X-Ray T4-13, BD7 2014, A700 Evo, WR-02G
Qatmix is offline   Reply With Quote
Old 12-22-2012, 03:24 AM   #4464
kentech's Avatar
If you mean this; 84317 TRF Special Damper Works Edition, then it's not the aeration dampers.
The above limited edition set is normal TRF dampers but with HL cylinders, x-rings and alu spring retainer.
Old 12-22-2012, 07:00 PM   #4465
narcotiks's Avatar
has anyone ever or is it known to run more droop in the front than the rear?
narcotiks is offline   Reply With Quote
Old 12-22-2012, 08:44 PM   #4466
i have a question,what would be causing the rear belt on a 417x to wear out quick??wrong tension?,bad belts??hes on the standard belts and has replaced rear one many times appreciate any help
thanks
tamiya-2012nz is offline   Reply With Quote
Old 12-22-2012, 10:22 PM   #4467
VooDooPH's Avatar
just wanted to share... i tried installing the CSO floating servo mount on my kit... since my lower deck was from Exotek which had slotted servo mount screws, the CSO unit would tweak no matter how hard i tighten the screws.
Quick solution: i drilled a 2.5mm hole in line with the 2 screw holes, reamed it out a bit so its just slightly smaller than 3mm, screwed in a grub screw through the hole and the 3rd screw hole on the unit...
it works. tried it out last night and even while running though the corner dots and a couple of turn-tuttle crashes, the servo didn't tweak.
Old 12-22-2012, 10:29 PM   #4468
Kevin K's Avatar
Trader Rating: 32 (100%+)
Send a message via AIM to Kevin K Send a message via Yahoo to Kevin K
http://www.rc-mushroom.com/product_i...damper-p-25961
Here is a picture of the shock kit.
2013 USVTA World Champion of the World
MOTIV RC presents the Midwest All-Star Carpet Series....14th year running 2016/17!!!
USVTA National Championship....check it out!!!
Im only responsible for what I say NOT what you understand.
Kevin K is offline   Reply With Quote
Old 12-23-2012, 03:12 AM   #4469
2-Bad's Avatar
Trader Rating: 24 (100%+)
Narc,
On my 417X it seem to love 4mm Frt, 5mm Rr droop... So yes!
thanks
NZ,
I never had trouble with belt wear until I replaced the center pulley one day and I started chew up belts every meeting. I couldn't see anything wrong with the new ones (but there must have been) and I changed back to the old pulley and all was good again.
If your tension is correct then I'd suggest you look at replacing your pulleys...
Yokomo * G Force * Sanwa * SMC * ProSpec
2-Bad is offline   Reply With Quote
Old 12-23-2012, 04:47 PM   #4470
ATLASCOPCO's Avatar
Can someone give me a part number for rear upright on a 417
Many thanks
XRAY T4 2014
HOBBYWING V3.1
HOBBYWING MOTORS
ATLASCOPCO is offline   Reply With Quote
Saudi Arabia RC Club grizzle Manila Racers 6558 01-06-2017 09:50 AM
Tamiya TRF415 JDM_DOHC_SiR Electric On-Road 21094 03-10-2016 12:02 PM
Tamiya TRF416 / TRF416WE / TRF416X academygaz Electric On-Road 10619 01-01-2015 04:36 PM
Tamiya TA05 IFS rcforum Electric On-Road 1132 12-18-2014 06:19 AM
"Ask" Jilles Groskamp Tamiya 416 & 417, Team Orion Motors JGH Electric On-Road 1996 05-27-2014 07:28 AM
SEO by vBSEO 3.5.0
