Old 12-12-2012, 03:31 AM   #4411
I race on carpet during the winter, I find spool have det best forward bit and the lap times back it up.
However its something i going to test again.
Cp Grafix is offline   Reply With Quote
Old 12-12-2012, 03:37 AM   #4412
Sith Lord's Avatar
Trader Rating: 21 (100%+)
Originally Posted by CraigM View Post
Are you running on the carpet track at all? The putty diff up front was much better when I ran there last year. Just smoother and better rotation
That's where I primarily run. Haven't run Kambah yet. My current brand car, I run 200,000 in the front diff and quite like that. Haven't used putty before, but might give it a test.
Tamiya XV-01 Rally :: Tamiya FAV 2011 :: Proline Pro2 SCB
Sith Lord is offline   Reply With Quote
Old 12-12-2012, 07:21 AM   #4413
Erm, when you say putty, what sort of putty do you use? And how do you do it? Also what is the advantage over say a thick oil?
I race on carpet and use gear diffs front and rear, I only have 10k in the front and I beat cars with spools etc. I can understand that a spool is more direct than a ball diff, but a gear diff doenst really slip.
http://www.theRcRacer.com/
TRF419, TBEvo6, TT02, VDF, TRF501x, TRF201, TRF101, Mi5, X-Ray T4-13, BD7 2014, A700 Evo, WR-02G
Qatmix is offline   Reply With Quote
Old 12-12-2012, 08:47 AM   #4414
DaveG28's Avatar
Trader Rating: 54 (100%+)
Hi all,
I'm about to build one of the v5's and am confusing myself regarding outdrives/blades!?
I have ordered the new steel outdrives (and will be running gear diffs front and rear) and am wondering do you run blades with these? If so, will the kit blades fit or will I need the older style blades!?
Finally, if I go with kit outdrives instead, what aftermarket blades would be able to replace the new V5 ones as I believe spares are currently hard to come by of the kit ones?
I assume the difference between Ali and steel gears in the diff by the way is weight/durability?
Viper ESC's ~ Xpert Servo's ~ Sanwa Radio
DaveG28 is offline   Reply With Quote
Old 12-12-2012, 10:01 AM   #4415
kentech's Avatar
Originally Posted by DaveG28 View Post
Hi all,
New steel outdrives only have slots for the driveshaft pins without blades.
I would run the stock new outdrives with the new 3.5mm blades. I believe by the time you have used up the 2 pairs included in the kit spare ones will be available.
There are no oftermarket 3.5mm blades available yet. But other manufacturers have 3.5mm blades on their cars and some of these might fit.
Steel gears are just for durability.
kentech.wordpress.com
kentech is offline   Reply With Quote
Old 12-12-2012, 01:03 PM   #4416
Sith Lord's Avatar
For the front diff I suggest picking up a set of the steel outdrives (#54425). This will let you run the diff without blades which get destroyed quickly up front.
I understand the issue is that we can't use the stock outdrives and 3.5mm blades because we can't buy them. Only the one available in the kit. The only Gear Diff kit available to buy seperately is the one one with the older outdrives, hence the reason to buy the steel outdrives and use no blades. Is that correct?
Old 12-12-2012, 02:06 PM   #4417
CraigM's Avatar
Trader Rating: 34 (100%+)
OK there's a bit of confusion:
I'm told the yokomo blades fit straight on, so you can use them until the tamiya 3.5mm are available
The tamiya steel outdrives take no blade, I would only use them up front where you have DCJs. They will cause some binding if used in the rear.
The old outdrives take the 3mm blade, you can get aftermarket steel versions from roche and arena that will accept the 3mm blade too
I use the ride 70 hardness diff putty. You pack the diff completely with it, which makes a very heavy action, much heavier than even 1 million oil. It makes the car smoother turning in, but a bit less steering coming out.
10k sounds very light, but hey, if it works it works.
www.facebook.com/mcpheerc
CraigM is offline   Reply With Quote
Old 12-12-2012, 03:39 PM   #4418
banquer's Avatar
Hello guys.
Do you know that the sakura zero diferential fits perfect on 417x and it's outdrives are 3,5mm width?
I'd running it last year without any issue and in Andalusian Regionals (The biggest region in south of Spain), I'd win the championship with two victorys and two seconds with this configuration.
Cheers.
http://www.touringelectricoandalucia.es/
http://www.agaerc.com
Tamiya 419
Tamiya TRF 101
MuchMore Fleta Pro - Euro - Fleta 10.5-21.5
Sanwa M12 - RX-471
http://www.agaerc.com/
banquer is offline   Reply With Quote
Old 12-12-2012, 04:11 PM   #4419
spec r already do a 3.5mm blade that fits the tamiya driveshafts. my brother uses them on his 417 after we filed his worn diff outdrives out
scytherat is offline   Reply With Quote
Old 12-12-2012, 07:52 PM   #4420
VooDooPH's Avatar
Trader Rating: 18 (100%+)
Send a message via Yahoo to VooDooPH
Originally Posted by banquer View Post
Hello guys.
Cheers.
yes.. i also use the XRay NT1 metal gears inside my Sakura Gear Diff...
[TRF418][TB-04Pro][FF-03Pro][M-05v2][TRF102][F-104 WGP][TT-01R TypeE]
[Cross CF-01'08][Yokomo R12][Team C TC02Evo][Team C T8E v3]
VooDooPH is offline   Reply With Quote
Old 12-13-2012, 07:08 AM   #4421
Velocitygt's Avatar
Associated TC6 3.5mm blades fit right on and will last forever.
Steel out drives for front diff are preferred to the standard alloy with a blade as in a crash the alloy will spread open.
Cheers
Scorpion Power Systems | Awesomatix | WTF Fans
Velocitygt is offline   Reply With Quote
Old 12-13-2012, 04:24 PM   #4422
CraigM's Avatar
Cheers
Fix your sig
Old 12-13-2012, 06:58 PM   #4423
Velocitygt's Avatar
Apologies
Old 12-15-2012, 08:57 AM   #4424
When does the 417v5 come out on the U.S.?
eman619 is offline   Reply With Quote
Old 12-15-2012, 09:04 AM   #4425
veecee's Avatar
Manual now online http://www.tamiya.com/japan/download.../42240-144.pdf
SMOKEM --- HIRO SEIKO --- YOKOMO
veecee is offline   Reply With Quote
Saudi Arabia RC Club grizzle Manila Racers 6558 01-06-2017 09:50 AM
Tamiya TRF415 JDM_DOHC_SiR Electric On-Road 21094 03-10-2016 12:02 PM
Tamiya TRF416 / TRF416WE / TRF416X academygaz Electric On-Road 10619 01-01-2015 04:36 PM
Tamiya TA05 IFS rcforum Electric On-Road 1132 12-18-2014 06:19 AM
"Ask" Jilles Groskamp Tamiya 416 & 417, Team Orion Motors JGH Electric On-Road 1996 05-27-2014 07:28 AM
SEO by vBSEO 3.5.0
