Like Tree1Likes
Old 12-04-2012, 01:12 PM   #4351
CraigM's Avatar
Trader Rating: 34 (100%+)
Originally Posted by scytherat View Post
How did you find that smokem 417mx chassis craig, very tempted to get one and a servo mount for my car (i race on astro carpet)
The smokem is good, very very similar to the new chassis. I think with the new top deck it will feel almost the same as the new car.
Originally Posted by NItrox416 View Post
Hi Craig,
excuse me do you try the new car with the old shocks?
only the new clamp are 0.5 mm higher or also the whole bulkhead is 0.5mm higher ?
How much they have rise the motor mount?
Sorry for the questions but I'm worry about because I have just buy the 417X.
Thank you.
I haven't tried the old shocks on the new car, or the new shocks on the old car, yet. The clamps are the same but the bulkhead is 0.5mm higher so I assume the diffs are too. I haven't checked if the motor itself is higher, I'll check tonight.
I tried the old car with all the bulkheads lifted 0.5mm last night and I really liked it on our med grip asphalt track. It had more grip but corner speed was still good.
www.facebook.com/mcpheerc
CraigM is offline   Reply With Quote
Old 12-04-2012, 11:55 PM   #4352
Sith Lord's Avatar
Trader Rating: 21 (100%+)
Default Shock Oil
How do you know what oil comes in the new V5 kit? The manual lists the part number, which is a discontinued item (3 pack of 200, 300, 400 oil). Or just the fact that it is yellow tells you it is 400 (noted on your set up shet, Craig)
Cheers
Tamiya XV-01 Rally :: Tamiya FAV 2011 :: Proline Pro2 SCB
Sith Lord is offline   Reply With Quote
Old 12-05-2012, 12:09 AM   #4353
CraigM's Avatar
Cheers
53443, soft oil set:
200 - Red
300 - Orange
400 - Yellow
I did make a mistake on that sheet, the kit diff oil is 900
Old 12-05-2012, 01:04 AM   #4354
Sith Lord's Avatar
200 - Red
300 - Orange
400 - Yellow
Yeah, found that on Tamiya's website. So do Tamiya not make any other yellow oils?
Nearly finished the build. My first TRF. Pretty impressed by the way it's all going together. Rear arms were binding a little. Swapped out a 1mm shim to a 0.5 and she's all good again. Can't wait to get this thing on the road (well, rug in my case)
Old 12-05-2012, 01:34 AM   #4355
CraigM's Avatar
Now that you've built it...
http://tchub.wordpress.com/2012/07/0...-build-part-1/
http://tchub.wordpress.com/2012/07/0...-build-part-2/
http://tchub.wordpress.com/2012/07/0...-build-part-3/
http://tchub.wordpress.com/2012/07/0...-build-part-4/
http://tchub.wordpress.com/2012/07/1...-build-part-5/
Old 12-05-2012, 01:39 AM   #4356
Sith Lord's Avatar
One step ahead of you there Craig. Should have thanked you personally and acknowledged some of your tips, but yep, already read most of your write ups Great job!
Old 12-05-2012, 01:54 AM   #4357
CraigM's Avatar
Any time. I recommend you pick up some 0.75mm shims for the suspension arms, I think with 0.5mm instead of the 1mm there will be too much slop
Will you be running your car at the new Kambah track? The track looks really great, I can't wait to come down and have a run
Old 12-05-2012, 02:05 AM   #4358
Sith Lord's Avatar
Yeah, probably a little too much play. I'll dig around in my kitbox, otherwise pick some up from the LHS. Only one more meet at Kambah before the new year. The guys have been pounding through the work -curbs, etc. It's coming along nicely. Will definately get out there in the new year. See you at the Titles in March, if not before.
Old 12-05-2012, 03:30 AM   #4359
Sith Lord's Avatar
Cheers
Or I could just read the manual! It tells me there. Doh!!..... Oh well.
Old 12-05-2012, 12:53 PM   #4360
NItrox416's Avatar
Thank you very much Craig,
I am waiting anxiously for your tests.
NItrox416 is offline   Reply With Quote
Old 12-05-2012, 01:54 PM   #4361
Jochim_18's Avatar
Anyone here tried jiles mod on his 417X at worlds? He raise up the top deck and put a plate on the motor mount Left and right side so that the tope deck is not srewed in the motor mount to give more flex on the car.
I did the modification on my 417x but I haven't actually tried running the car yet.
Localrcracing.com - Your premiere source of Radio controlled Racing in central California.
Visaliahobbies.com * SkyRC * casterracingparts.com
Old 12-05-2012, 02:36 PM   #4362
Anyone got a picture of the new top deck next to a 417x one
scytherat is offline   Reply With Quote
Old 12-05-2012, 02:52 PM   #4363
CraigM's Avatar
That was Kenneth's car not Jilles
http://kentech.blogs.se
Old 12-05-2012, 03:06 PM   #4364
Jochim_18's Avatar
How's the car handles? I assume to generate more mechanical grip?
Old 12-06-2012, 01:47 AM   #4365
Sith Lord's Avatar
Default Battery stops
I don't think I'm loving the battery stops on the V5. I'm guessing tape will hold the battery in, but there's nothing (apart from tape) stopping the battery sliding in towards the belt at the rear. There appears to be no carbon/aluminium mounts available like on the earlier 417's.
Any tips/solutions? Or just tape?
Saudi Arabia RC Club grizzle Manila Racers 6558 01-06-2017 08:50 AM
Tamiya TRF415 JDM_DOHC_SiR Electric On-Road 21094 03-10-2016 11:02 AM
Tamiya TRF416 / TRF416WE / TRF416X academygaz Electric On-Road 10619 01-01-2015 03:36 PM
Tamiya TA05 IFS rcforum Electric On-Road 1132 12-18-2014 05:19 AM
"Ask" Jilles Groskamp Tamiya 416 & 417, Team Orion Motors JGH Electric On-Road 1996 05-27-2014 06:28 AM
