Like Tree1Likes
Old 11-09-2012, 07:44 PM   #4201
rosko's Avatar
Wow this car come sdecked out! I want this or the bd7....decisions decisions
rosko is offline   Reply With Quote
Old 11-09-2012, 11:14 PM   #4202
OnRDPassion's Avatar
Trader Rating: 54 (100%+)
wow that is one good looking car. Don't know if I want the t4 or the 417 now. Decisions, decisions!
OnRDPassion is offline   Reply With Quote
Old 11-10-2012, 07:21 AM   #4203
jedi's Avatar
Where can we pre-order this new car?
It's better to be lucky than to be good......when it comes to getting a clean run in qualifying!
jedi is offline   Reply With Quote
Old 11-10-2012, 07:24 AM   #4204
transplantlife's Avatar
Trader Rating: 43 (98%+)
If your in the US here http://www.speedtechhobbies.com/inde...roduct_id=2637
IM A SURVIOR OF A DOUBLE ORGAN TRANSPLANT KIDNEY/PANCREAS...PLEASE BE A ORGAN DONOR TO GIVE LIFE TO OTHERS!!
transplantlife is offline   Reply With Quote
Old 11-11-2012, 02:23 AM   #4205
spacendeman's Avatar
Send a message via MSN to spacendeman
Hi all,
I have an second hand tamiya 417x. Now I was busy with the car and noticed that the screws in the geardiff are a little worn out.
Now I am looking for some new screws but couldn't find it at rc mart. Can someone help me find some screws? And does spec r screws also fit in the tamiya geardiff?
Thanks in advance!
spacendeman is offline   Reply With Quote
Old 11-11-2012, 05:33 AM   #4206
Fabricio's Avatar
Send a message via MSN to Fabricio Send a message via Skype™ to Fabricio
Need 1 or 2 upper deck for the 417, cannot find it anywhere.
regards.
ARC R10 - ORCA - SANWA - EPIC
Fabricio is offline   Reply With Quote
Old 11-12-2012, 03:23 PM   #4207
I was wondering how many people are running a 417 on carpet. I just pre-ordered one but I am starting to see there are quite a few reviews saying the 417 is garbage on carpet and the 416 is better. I will be running half of the time on asphalt and the other half running on carpet.
Any feedback would be appreciated. Thank you!
Old 11-12-2012, 03:31 PM   #4208
Yokomo_Ant3's Avatar
Trader Rating: 29 (100%+)
The car will be fine and more than capable on both surfaces. Its hard to say how the new car will go however as to my knoledge no one has run it on carpet. Marc proved at the last ETS the car does work on carpet, although this was with a 2.5mm chassis and normal shocks. I would say at the next ets round they will be using the new car
Antoni Caretti
Team Yokomo - Racing Performer - Sweep Racing
Yokomo_Ant3 is offline   Reply With Quote
Old 11-12-2012, 03:31 PM   #4209
Originally Posted by spacendeman View Post
Hi all,
Thanks in advance!
Buy a new gear diff case, the screws come with that
Antoni Caretti
Old 11-12-2012, 10:02 PM   #4210
Ultraspeed84's Avatar
Trader Rating: 45 (100%+)
How good is the 417 on carpet? compared to t4 and bd7?
yokomo yz-2
Ultraspeed84 is offline   Reply With Quote
Old 11-12-2012, 10:08 PM   #4211
303slowdown's Avatar
Trader Rating: 21 (100%+)
It just as good
Ryan Borgheiinck
303slowdown is offline   Reply With Quote
Old 11-12-2012, 11:49 PM   #4212
At our club the 417 (original) is great on carpet. I've won the A final a fair few times. We don't cut the original mount, and run a gear diff up front. It was a little more difficult to find a good set-up over the 416we but once sorted it is sweet.
http://www.theRcRacer.com/
TRF419, TBEvo6, TT02, VDF, TRF501x, TRF201, TRF101, Mi5, X-Ray T4-13, BD7 2014, A700 Evo, WR-02G
Qatmix is offline   Reply With Quote
Old 11-13-2012, 12:02 AM   #4213
Hmm... I only ran the 416x on pavement but this car will straight up be fore carpet.. Does this car have a ton of steering built into it? and are you guys running HB springs on the car? when i watch a video of the trf417 looks like it does not rotate as good as say the BD7 does? Also where are all the US guys getting parts from and ordering the car from?
yokomo yz-2
Old 11-13-2012, 02:01 AM   #4214
The 417 rotates a lot.. Thats the main issue, the car wants to throw its back end out more than the 416. On carpet that makes it a bit of a bugger to get settled.
I initially ran foams, the car was a nightmare compared to the Ta05ms (the best foam car since the original 415). But I eventually got it sorted and it was superb. We have now gone on to rubbers and I then had to dial more steering back into the car (Foams needed it dialed way back due to the amount of grip). The car rotates really well now.
This weekend I was at a regional style event, and considering I'm not the best driver in the world I managed 2nd in my class and got the fastest race time and laptime of the day with my 417.
Spares are easy to get, although in nearly 2 years of racing the 417 I have only broken a handful of cheap parts (C-hubs, Uprights) and replaced the suspension arms after a year just as they were starting to get a little loose. About 30 spares in that time is testament to Tamiya durability.
Really unless you are a worlds style driver all these top cars are good, its more about the colour of aluminium you like.
Old 11-13-2012, 07:01 AM   #4215
Bad-Andy's Avatar
I'll also agree that the 417 does great on the rug. I started with Art Scrimo's 2011 IIC setup and have stiffened up the front suspension a bit (HB Gold Spring and 650cst oil) to gain rear traction. Also adding a .5mm shim under the rear of the front suspension mounts calms down the front end a lot. I'm no great driver either but my best lap time was on par with our typ fast guys time with his BD7.
As fars as spares here in the US either Speedtech or TQRacing are my go to sources.
Bad-Andy is offline   Reply With Quote
Saudi Arabia RC Club grizzle Manila Racers 6558 01-06-2017 08:50 AM
Tamiya TRF415 JDM_DOHC_SiR Electric On-Road 21094 03-10-2016 11:02 AM
Tamiya TRF416 / TRF416WE / TRF416X academygaz Electric On-Road 10619 01-01-2015 03:36 PM
Tamiya TA05 IFS rcforum Electric On-Road 1132 12-18-2014 05:19 AM
"Ask" Jilles Groskamp Tamiya 416 & 417, Team Orion Motors JGH Electric On-Road 1996 05-27-2014 06:28 AM
