Old 11-02-2012, 05:50 PM   #4171
ATLASCOPCO's Avatar
Originally Posted by Quantra View Post
Big thank you to everyone who offered me advice on getting my car to bite. Had another go today and things were much better. I started with my old set up but just stood the shocks up to hole 3 F+R. Car was really like driving on ice. I lowered camber links by 1mm, felt some more side bite but car was rotating like mad. Went up to #1000 in the rear diff and the car started rotating nicely but was still a bit slidey. Put the thinner top deck on and the car became much more to my liking, really digging in and not sliding in the corners at all unless I carried too much speed on entry. Car was a little slow on exit so went to 2.5 rear toe and it was all good. Last final had a bit of fun and put a front one way in. Quite good with the one way so long as everything was going to plan, as soon as I made a mistake and had to correct something the one way was not so fun!
Important thing is I'm leaving the rostrum with a smile again =D Big race this Sunday so let's hope I can keep the car handling sweetly.
If you look from the top of the wishbone so you can see where the holes are on both sides then hole 1 is the furthest out (closest to the wheel) and 4 is the most inward (closest to centre). The holes alternate from side to side, so the side with the furthest out hole has hole 1 and 3 and the other side is 2 and 4. If you look on a set up sheet then the diagram is arranged so that hole 1 looks further out than hole 2. HiH.
Thank you
XRAY T4 2014
HOBBYWING V3.1
HOBBYWING MOTORS
ATLASCOPCO is offline   Reply With Quote
Old 11-03-2012, 10:03 AM   #4172
Send a message via MSN to Bigger Brother
Originally Posted by kentech View Post
54309 TA06 Stabilizer Set
Comes as a set:
http://www.tamiyausa.com/product/ite...oduct-id=54309
The 417 set is: 84208 TRF417 Stabilizer Rod Set
Thanks!!
Oli Meggitt | London, UK
.:. Essex Winter Series .:. CML Racing .:. ToniSport .:. Zen Racing .:. Moorespeed RC .:. OTM Racing .:. RC Racing TV .:. RIDE R/C Scoreboards
Bigger Brother is offline   Reply With Quote
Old 11-03-2012, 03:40 PM   #4173
NItrox416's Avatar
Originally Posted by Yokomo_Ant3 View Post
TA06 sway bars give us finer increments, so 1.1, 1.3, 1.5mm options I have used 1.3 front and 1.1 rear on some tracks but generally the kit sway bars work best
Thank you very much, now all is clear
NItrox416 is offline   Reply With Quote
Old 11-04-2012, 10:27 AM   #4174
LIUK82's Avatar
Default problem with spur gear
having to use a 87 T spur gear mod 48 / 17 T pinion mod48 with 3.5T motor to have 9.92 final gear ratio to have a low temperature of 70°C in small track the spur gear touch in the Center Bulkhead Tamiya 13454762 TRF417 when the chassis flexes and smash it
I thought of cutting the Center Bulkhead Tamiya 13454762 TRF417 1piece so the spur gear can't touch and use the 417 chassis with 417X top deck and separated suspension block, if i use the 417 top deck and 1 piece suspension block at fr and rf i can limit the flex
I can solve the problem so?
anyone has tried to mount 3.5T motor on the first 417 with center bulkhead 1piece?
LIUK82 is offline   Reply With Quote
Old 11-04-2012, 10:43 PM   #4175
narcotiks's Avatar
Anyone know where i can buy the kyosho orings for the gear diff? Cant seem to find them anywhere!
narcotiks is offline   Reply With Quote
Old 11-05-2012, 12:54 AM   #4176
CraigM's Avatar
Trader Rating: 34 (100%+)
try amain, that's where I got mine
www.facebook.com/mcpheerc
CraigM is offline   Reply With Quote
Old 11-05-2012, 02:15 AM   #4177
PDR
PDR's Avatar
Trader Rating: 30 (100%+)
These guys had some in stock (not too many though), last time I checked:
http://www.familyland.com.au/index.p...oducts_id=5687
T4 | X1 | Multiple Kids
2011 Slowest Winner - 21.5 Muchmore Masters & NSW State Titles Demo Class
Making an A Main at a Scotty Ernst event. Awesome. Scotty calling you first in A1. Priceless
PDR is offline   Reply With Quote
Old 11-05-2012, 02:26 AM   #4178
chrisk's Avatar
Trader Rating: 32 (100%+)
Market dont have any I tried today, I might jump on them at Chester hill Phil, thanks
TAMIYA - SMOKEM - REEDY
smaracing.org
chrisk is offline   Reply With Quote
Old 11-05-2012, 08:24 AM   #4179
NItrox416's Avatar
Did somebody test in a asphalt track the difference between smokem fx and mx?
Old 11-05-2012, 08:43 AM   #4180
artwork's Avatar
Trader Rating: 56 (100%+)
Incase anyone is looking for a great 417 with tons of parts...Here is mine for sale:
FS: Tamiya 417 with tons of parts
Xray | Hudy | Sanwa | R1 Wurks | Avid | Protoform | Proline | 2mm Designs
artwork is offline   Reply With Quote
Old 11-05-2012, 03:31 PM   #4181
I'm racing 17.5 blinky at the weekend. Anyone have a good starting FDR for a 417? will a 80t spur fit in the car? Or will I need a bigger spur?
http://www.theRcRacer.com/
TRF419, TBEvo6, TT02, VDF, TRF501x, TRF201, TRF101, Mi5, X-Ray T4-13, BD7 2014, A700 Evo, WR-02G
Qatmix is offline   Reply With Quote
Old 11-05-2012, 05:03 PM   #4182
What pitch are you using? If 64 pitch its too small. I run a 96 spur with 4.8 pinion most of the time. FDR is about 3.8 with that ratio. I run a fixed timing motor in blinky that is quite torquie. FDRs around 4 is what you are aiming for as a starting point.
napoleon1981 is offline   Reply With Quote
Old 11-05-2012, 11:34 PM   #4183
I am using 64 pitch. I just wonder if an 80t spur and 40t pinion would fit. Or should I go for a 90 and 45t etc
Old 11-06-2012, 01:13 AM   #4184
i would go for 90 or even a bigger spur.
I run 96 on mine and it works just fine, I thínk 80 is just too small.
Cp Grafix is offline   Reply With Quote
Old 11-06-2012, 03:07 AM   #4185
Jochim_18's Avatar
80 tooth spur gear is to small it will not mesh... 88 tooth is the smallest one spur gear you can you to have a proper gear mesh...
Localrcracing.com - Your premiere source of Radio controlled Racing in central California.
Visaliahobbies.com * SkyRC * casterracingparts.com
Saudi Arabia RC Club grizzle Manila Racers 6558 01-06-2017 08:50 AM
Tamiya TRF415 JDM_DOHC_SiR Electric On-Road 21094 03-10-2016 11:02 AM
Tamiya TRF416 / TRF416WE / TRF416X academygaz Electric On-Road 10619 01-01-2015 03:36 PM
Tamiya TA05 IFS rcforum Electric On-Road 1132 12-18-2014 05:19 AM
"Ask" Jilles Groskamp Tamiya 416 & 417, Team Orion Motors JGH Electric On-Road 1996 05-27-2014 06:28 AM
