Like Tree1Likes
Old 10-17-2012, 05:41 PM   #4066
Originally Posted by jedi View Post
Will the CSO floating servo mount fit the regular 417? Thanks
Yes and no. The servo sits far forward, and just hits the steeringpost. You can resolve this by sanding the tabs on the servo. The mount can only be secured with 2 of the 3 screws, which is fine on asphalt. I have noticed that on carpet the servo shift when you hit the border, so I have removed it for the carpet season
napoleon1981 is offline   Reply With Quote
Old 10-18-2012, 02:54 AM   #4067
CraigM's Avatar
Trader Rating: 34 (100%+)
If anyone is looking for some good value bearings, the arena economic rubber sealed bearings from rc market are awesome. $11 for bearings for the whole car apart from the centre shaft and they are as smooth and long lasting as all but the best ceramics
First time I tried it on asphalt it moved about so I chucked it in the bin straight away
www.facebook.com/mcpheerc
CraigM is offline   Reply With Quote
Old 10-18-2012, 03:11 AM   #4068
MrRolla's Avatar
Trader Rating: 29 (100%+)
Hey craig,
Did you get the grease out of them then re oil or just install them? I have some sitting in my pitbox waiting to be used.
MrRolla is offline   Reply With Quote
Old 10-18-2012, 03:32 AM   #4069
mingnon's Avatar
Great to know, have 3 sets in the pit bag, wasnt sure about them, will put off getting the more expensive ones now
---------------------------SMA The Home of GREAT Racing------------------------------
mingnon is offline   Reply With Quote
Old 10-18-2012, 04:02 AM   #4070
Starteur's Avatar
Good morning guys,
I put dbl-joints up front on my 416X, they are 44mm since then I keep breaking those plastic blades in the outdrives, should I change to 46mm bones for my dbl joints?
Ride it like you stole it!!!!!!
Tamiya TRF417V5 SEDAN Racer - Tamiya 416X VTA Racer - Tamiya TRF 416X USGT Racer -Tamiya M05 V2 PRO Racer -Tamiya F-104X1 Formula 1 Racer.
Starteur is offline   Reply With Quote
Old 10-18-2012, 05:35 AM   #4071
RL.2002's Avatar
Originally Posted by Starteur View Post
Good morning guys,
change to spring steel outdrive
the passion of the slide when taking the corner....
http://www.penabai-rcdrifter.blogspot.com/
Kyosho TF-5 drift spec powered by Ezrun 35A + 9t
Tamiya TRF-416X, Tamiya TRF-417
Hobbywing Xerun 120A, Xerun 3.5t, Team Orion 11.5t, Xerun 5.5t
RL.2002 is offline   Reply With Quote
Old 10-18-2012, 07:54 AM   #4072
DaveG28's Avatar
Trader Rating: 62 (100%+)
Hi guys,
Drivetrain wise other than the new gear diff outdrives it looks like the new V5 package is the same as the 417X?
If so, what driveshaft upgrades are required/desirable, I remember my last trf came with Ali front driveshafts that needed swapping to (longer?) steel ones, are the double joint cardan ones now the "top spec" option? Theta r snot standard are they? What length front and rear are required?
Viper ESC's ~ Xpert Servo's ~ Sanwa Radio
DaveG28 is offline   Reply With Quote
Old 10-18-2012, 08:19 AM   #4073
Anybody see any chassis pics of Marc's car from last weekend?
shaggy1 is offline   Reply With Quote
Old 10-18-2012, 09:47 AM   #4074
I spoke to him at the ETS rd1 in Germany and his car was the "old" 417x. I couldnīt see any new option parts. He said it is the same car from the ETS race in Poland.
-no86- is offline   Reply With Quote
Old 10-18-2012, 02:04 PM   #4075
CraigM's Avatar
Originally Posted by MrRolla View Post
Hey craig,
Nope i just run them. They feel a bit heavy until the seal is broken in
Originally Posted by DaveG28 View Post
Hi guys,
The new car comes with 44mm DCJs front and 44mm alu unis rear, so no need to change anything
Old 10-18-2012, 02:50 PM   #4076
Thanks for the quick response, don't suppose you noticed whether he was running the split mounts or the solid suspension mounts on his car, the setup sheet is a little confusing in that respect.
Old 10-18-2012, 04:03 PM   #4077
Starteur's Avatar
Part no please?
Old 10-18-2012, 04:07 PM   #4078
Trader Rating: 17 (100%+)
I 100% agree!!!!!! those bearings have been awesome.......no problems!
SANWA / TEAM ORION / PRO-LINE / PRO-SPEC / P1 BRAND / PROTOFORM / ACTIVRC
I'm not a Business man, but I'm the Bizzness man!!!
Sean Williams is offline   Reply With Quote
Old 10-18-2012, 09:05 PM   #4079
RL.2002's Avatar
Part no please?
i'm using tuneup - steel spool cup for trf416/417. the part number was TU-416-02
Old 10-18-2012, 09:16 PM   #4080
Yokomo_Ant3's Avatar
Out of all of the spool cups ive seen/tried, the new Roche ones are the best. The new ones are longer so there are no issues with the 44mm driveshafts. The Arena ones are also good, and great value as they come with 4 slots in each
Antoni Caretti
Team Yokomo - Racing Performer - Sweep Racing
Yokomo_Ant3 is offline   Reply With Quote
Saudi Arabia RC Club grizzle Manila Racers 6558 01-06-2017 08:50 AM
Tamiya TRF415 JDM_DOHC_SiR Electric On-Road 21094 03-10-2016 11:02 AM
Tamiya TRF416 / TRF416WE / TRF416X academygaz Electric On-Road 10619 01-01-2015 03:36 PM
Tamiya TA05 IFS rcforum Electric On-Road 1132 12-18-2014 05:19 AM
"Ask" Jilles Groskamp Tamiya 416 & 417, Team Orion Motors JGH Electric On-Road 1996 05-27-2014 06:28 AM
