Old 10-15-2012, 12:56 AM   #4036
skyball's Avatar
Originally Posted by Yokomo_Ant3 View Post
I did, the first 2 runs The 2.5mm was just that much better
I'm also thinking about getting the reedy chassis for the carpet season. On the other hand there's a new chassis by Tamiya themselves right around the corner (for the new 417 V5 version or whatever it will be called), which is also supposed to be stiffer.
Does anyone have some comparison information on those 2 chassis variants? I'd prefer facts of course, but am also interested in thoughts...
Christian
skyball is offline   Reply With Quote
Old 10-15-2012, 01:33 AM   #4037
CraigM's Avatar
Trader Rating: 34 (100%+)
Christian
The 2.5 will still be the pick for carpet until a 2.5mm version of the new chassis is released. Not sure why it's being called the reedy chassis, Viktors setup sheet says 2mm deck and his chassis had no holes
www.facebook.com/mcpheerc
CraigM is offline   Reply With Quote
Old 10-15-2012, 02:35 AM   #4038
kool guys.
I have found another that is a 72t designed properly for the 417.
See I need to get a 4.0 ratio for VTA racing down here and that is why the questions.
New to all this so it a learning process
nivola is offline   Reply With Quote
Old 10-15-2012, 03:02 AM   #4039
I use the 2,25 with zero cuts on carpet, it almost have to much traction.
The car drives really great, I just have to learn to control it
Cp Grafix is offline   Reply With Quote
Old 10-15-2012, 04:27 AM   #4040
Are you saying that you are using the new WX chassis?
mhavlena is offline   Reply With Quote
Old 10-15-2012, 04:29 AM   #4041
I experienced the same confusion!?
Old 10-16-2012, 01:29 AM   #4042
Questions??
oops srry the chassis is CSO-racing.
Unlike othes I don't have problem with the deck, mine has some thickness allover 2,25 mm.
My car is balanced too,
LF 320 RF 318
LR 350 RF 352
Car weight is 1350 gr.
Old 10-16-2012, 06:53 AM   #4043
jedi's Avatar
Anyone know where I can buy a 417x? Preferably new but used will do as well. Or do I have to wait for the new 417wx?
It's better to be lucky than to be good......when it comes to getting a clean run in qualifying!
jedi is offline   Reply With Quote
Old 10-16-2012, 07:04 AM   #4044
skyball's Avatar
Is it the item #TA-1005C from this page: http://www.cso.com.hk/htdocs/modules...ex.php?ncsn=27 or do you have the whole conversion kit #TA-1007C? They claim it's 2.2 mm, btw.
That one looks good too and it's quite inexpensive at rcmushroom...
Christian
[Sanwa M12][Awesomatix A800][Ronalds Yoke BD-7 2014][Roche P12 2016][Asso RC12R5.2][VBC LightningFXM]
Old 10-16-2012, 07:18 AM   #4045
DaveG28's Avatar
Trader Rating: 54 (100%+)
Hi guys,
I'll post this here as if I go TC racing this'll be the car I use, do any clubs run mod these days or when getting setup will I basically need 10.5/13.5/17.5?
Do the cars come with a range of spurs/pinions or just one spur?
Finally, an actual 417 question, how does it go with 2 gear diffs? I know the new kit will come with a spool on the front but previously when running TC I always found a spool virtually undriveable so my preference will be to run 2 gear diffs!
Viper ESC's ~ Xpert Servo's ~ Sanwa Radio
DaveG28 is offline   Reply With Quote
Old 10-16-2012, 08:29 AM   #4046
Trader Rating: 22 (100%+)
Anyone try this servo mount yet? It's about $10 from RCMushroom.
JoeyE is offline   Reply With Quote
Old 10-16-2012, 09:28 AM   #4047
G-kenny's Avatar
Its absolutely Rubbish!
I bought one until the Tamiya Version is release, It came with three screw holes UN-tapped and it was already bent. I straightened it out, tapped the holes and did one run with it on my car then threw it in the bin!
G-kenny is offline   Reply With Quote
Old 10-16-2012, 09:41 AM   #4048
Good to know, thanks.
Old 10-16-2012, 09:44 AM   #4049
Originally Posted by DaveG28 View Post
Hi guys,
13.5 boosted seems to be the popular class for clubs. Mod seems to have disappeared of the uk scene. Although they will run it at the BIWS this winter.
I use two gear diffs, and my 417 is fantastic. I dont like a spool, it is too agressive for my driving style. I use the TRF VG oil (no leaks). I run 2k in the front and 800 in the rear.
My car is excellent, loads of corner speed and predicable handling. (I am running 13.5 non boosted at my club as its quite a small track).
http://www.theRcRacer.com/
TRF419, TBEvo6, TT02, VDF, TRF501x, TRF201, TRF101, Mi5, X-Ray T4-13, BD7 2014, A700 Evo, WR-02G
Qatmix is offline   Reply With Quote
Old 10-16-2012, 12:44 PM   #4050
DaveG28's Avatar
Thanks dude, I'm actually in the US now though! Good to hear on the gear diffs!
Saudi Arabia RC Club grizzle Manila Racers 6558 01-06-2017 09:50 AM
Tamiya TRF415 JDM_DOHC_SiR Electric On-Road 21094 03-10-2016 12:02 PM
Tamiya TRF416 / TRF416WE / TRF416X academygaz Electric On-Road 10619 01-01-2015 04:36 PM
Tamiya TA05 IFS rcforum Electric On-Road 1132 12-18-2014 06:19 AM
"Ask" Jilles Groskamp Tamiya 416 & 417, Team Orion Motors JGH Electric On-Road 1996 05-27-2014 07:28 AM
SEO by vBSEO 3.5.0
