Like Tree1Likes
Old 10-08-2012, 08:14 AM   #3991
CristianTabush's Avatar
Originally Posted by AdrianM View Post
Interesting. Diff height can make a big difference. There is a certain point in diff height where the dog bone will not slide in and out of the drive cups as the suspension compresses. I think if the designer did their job this should be the low diff position on every car. Higher than this and you increase the plunge of the dog bone. On power and under braking this will cause friction that will have the effect of stiffening the suspension on the end of the car with the high diff. You can get a lot of interesting effects from this when you combine this with soft springs and various droop settings.
BTW, I am not cyber stalking you Christian...just looking for a new Sedan. Really impressed with your work!
hey Adrian, thanks for the words. I'll write a bit of what I have found out on the RSD thread. However, I feel the testing is still inconclusive.
Craig, enjoy the items. Hopefully they help you gain some tenths.
REFLEX RACING/ RSD/ GIZMO RACING USA/ HOBBYWING/ AXON/ QTEQ/ TEAM PRIME
CristianTabush is online now   Reply With Quote
Old 10-08-2012, 03:33 PM   #3992
rigelkent09's Avatar
Trader Rating: 44 (100%+)
Default gearing help
need help what tooth of pinion gear to get for my 416, i currently have 64 pitch 102 t spur with tekin 17.5t motor, plan racing it for 17.5 class..thanks..
rigelkent09 is offline   Reply With Quote
Old 10-08-2012, 03:37 PM   #3993
Are you running blinky or boosted? If you're running blinky, probably gonna need a smaller spur gear like around an 88 tooth.
shaggy1 is offline   Reply With Quote
Old 10-08-2012, 04:32 PM   #3994
Im running boosted, does my current spur will work?if so what pinion would you recommend? Thanks.
Old 10-08-2012, 05:04 PM   #3995
I can only offer a guess, but your spur should be good, pinion wise maybe 35 to 45 range. I'm use to running blinky, with 48/88 ratio. Just watch your temps.
Old 10-08-2012, 08:07 PM   #3996
hey shaggy,i did double check my local track for sedan 17.5 class racing and i was wrong on my previous reply, it was BLINKY, now my question is the AE kimbrough spur will fit just fine in my 416??i want to get the same gears as yours, if not, what brand should i get? since tamiya spur gears are really hard to find here in us.
Old 10-08-2012, 08:26 PM   #3997
I'm using the RW racing spurs, version 2, 88 tooth. They are available at speedtechrc. A good starting fdr is right around 4.0. So your looking at around a 46 to 50 tooth pinion range.
Old 10-08-2012, 08:31 PM   #3998
ok, i will try at speedtech rc, do you know the internal gear ratio of the 416??
Old 10-08-2012, 09:20 PM   #3999
Old 10-09-2012, 06:55 AM   #4000
2.055
thanks shaggy, by the way the 48t pinion 64 pitch wont fit in in my 416, it will touch the top plate, i cant even slide it in the motor shaft, just wondering how did you fit yours, sorry for a lot of question i have a race to catch up this coming weekend..
Old 10-09-2012, 07:09 AM   #4001
You slide it on the shaft while the motor is unattached but against the motor mount, secure your motor screws, then tighten the pinion using the hole in the underside of the chassis, then adjust your alignment and gear mesh.
Old 10-09-2012, 07:23 AM   #4002
ok ill try that, thanks a lot again...
Old 10-09-2012, 03:18 PM   #4003
SpeedTech's Avatar
Default SALE on the TRF417X "Reedy Edition" Chassis Combo
Hey Guys,
We put the TRF417X "Reedy Edition" Chassis combo on sale for this week only. $69.99 for both the lower and upper decks (42233/42232). Limited quantities on hand and it's priced to move. The stock chassis alone is over $95.
http://www.speedtechhobbies.com/inde...roduct_id=2201
Cheers,
Jeff Yung
www.SpeedtechRC.com
>>>www.SpeedtechHobbies.com<<<
SpeedTech is offline   Reply With Quote
Old 10-11-2012, 03:40 AM   #4004
kentech's Avatar
http://kentech.blogs.se/ and http://www.tamiya.com/japan/hobbysho...port/news1.htm for first actual pictures on the TRF417 V5 Premium Package...
kentech.wordpress.com
kentech is offline   Reply With Quote
Old 10-11-2012, 07:22 AM   #4005
The wiring on that car would soon lead to disaster! Looks good though, the new chassis would be nice as would the servo mount. The rest are just consumables that I could replace once mine are worn. I don't want those dampers as negative rebound doesn't ever figure in any of my set-ups.
http://www.theRcRacer.com/
TRF419, TBEvo6, TT02, VDF, TRF501x, TRF201, TRF101, Mi5, X-Ray T4-13, BD7 2014, A700 Evo, WR-02G
Qatmix is offline   Reply With Quote
Saudi Arabia RC Club grizzle Manila Racers 6558 01-06-2017 08:50 AM
Tamiya TRF415 JDM_DOHC_SiR Electric On-Road 21094 03-10-2016 11:02 AM
Tamiya TRF416 / TRF416WE / TRF416X academygaz Electric On-Road 10619 01-01-2015 03:36 PM
Tamiya TA05 IFS rcforum Electric On-Road 1132 12-18-2014 05:19 AM
"Ask" Jilles Groskamp Tamiya 416 & 417, Team Orion Motors JGH Electric On-Road 1996 05-27-2014 06:28 AM
