Like Tree1Likes
Old 09-24-2012, 10:13 AM   #3961
meccanico's Avatar
Here a good set up for carpet: www.
automodelli.it/forum/topic.asp?TOPIC_ID=40479&whichpage=43
meccanico is offline   Reply With Quote
Old 09-24-2012, 10:30 AM   #3962
just got back it to racing after 2years off
attached my set-up any ideas welcome
i race on astroturf with schuy yellow mini-pins lots of grip but lots of wear
normally put new rears on 2-3 runs & put them on front
with the set up im running i get a lot of off power push /slide on turn in high speed
as the run goes on im chaseing more front grip each run(as tyres wear)
any help please (also some said to me dremel out top plate front brace)?
dean-oz is offline   Reply With Quote
Old 09-26-2012, 03:51 AM   #3963
CraigM's Avatar
Trader Rating: 34 (100%+)
Got my new smokem deck last night. No fibreglass in here, just beautiful matte carbon
Will report back after the weekend with how it performs
www.facebook.com/mcpheerc
CraigM is offline   Reply With Quote
Old 09-26-2012, 04:42 AM   #3964
Blimey, never heard of racing TC on astroturf, which club is it Dean?
The only thing I can really see to try is use a couple mm less under your front camber link and maybe lighter diff oil, maybe 800cst?
cyclonetog is offline   Reply With Quote
Old 09-26-2012, 05:19 AM   #3965
Change your front wheelbase as per the kit setup, less rear toe would also help.
where in the uk runs tc on astro? are there jumps too!
Smartypants is offline   Reply With Quote
Old 09-26-2012, 10:18 AM   #3966
indoor sports hall
norwich
used to be kellers car club theres a web site with pics
no jumps unless u lauch it off the road rail track they run
Old 09-27-2012, 08:15 AM   #3967
Skitee's Avatar
Here's a video of the Mod main from our local Tamiya Cup Finals in South Africa
+ YouTube Video
Xray T4 2017 ~ ORCA Vritra VX3 ~ Motiv RC 4.5
Xray T4 2017 ~ ORCA Vritra VX3 ~ R1 Wurks 13.5
Xray X12 2016 ~ ORCA Vritra VX3 ~ Orca TX 4.5
POWERED BY SPEEDZONE USA
Skitee is offline   Reply With Quote
Old 09-27-2012, 10:34 AM   #3968
Kyosho Inferno MP9 TKI4
TLR 22 3.0
Apex RC Proshop
inpuressa is offline   Reply With Quote
Old 09-27-2012, 11:32 AM   #3969
very nice kit
rcguy888 is offline   Reply With Quote
Old 09-28-2012, 02:26 AM   #3970
daleburr's Avatar
Originally Posted by CristianTabush View Post
Recently we acquired a 417 to do some testing and develop some items for the car. I have been very curious about the geometry and weight distribution of the car to help us further develop our RSD6 chassis platform. I also wanted to see which items would work cross-platform.
For what it's worth, I tested our bladders, shock seals and purple springs on the car. Every item outperformed the Tamiya counter parts and the purple springs actually had a better feel than the HPI Silver. However, our springs are 13mm vs 14mm in I.D.
Out of interest, what is the front/rear weight distribution on the 417? It looks quite far rearwards compared to a TC6 (maybe more similar to the RSD6 with its more rearwards battery placement?)?
Team Xray
RC-Timing Software - http://www.rc-timing.com
Mercedes AMG F1 - http://www.mercedes-amg-f1.com/
daleburr is offline   Reply With Quote
Old 09-29-2012, 05:05 PM   #3971
narcotiks's Avatar
Do all the steel spool cups not use drive shaft blades ?
narcotiks is offline   Reply With Quote
Old 09-29-2012, 05:34 PM   #3972
CristianTabush's Avatar
The 417 is a lot more rear biased than the tc6. The motor, and battery are a good 6-8 mm further back than on the tc6. The rsd6 is somewhere in between as the battery can be moved back 5mm vs the tc6. Geometry wise the 6.1 arms are almost a copy from the trf ones, but the upper rear hub position is 2-3mm further out in the 6.1
Diff position is also another thing that is different as well. The tc6's diffs are either higher than the lowest 417 or a bit higher. I feel like it lacks an in between position.
Lastly, the wheelbase is a lot longer on the tc6 in std setting.
At the moment, they are both fast, very similar laptimes. The rsd6 feels more locked in on the track, while the 417 feels like it has more corner speed, however the lap times come out so close it's not funny.
I am trying to replicate the geometry of the 417 on the rsd6 to see what the effect on the car is. The rsd6 is narrower and the motor does not overhang as far out. So it will be interesting to ser what happens.
REFLEX RACING/ RSD/ GIZMO RACING USA/ HOBBYWING/ AXON/ QTEQ/ TEAM PRIME
CristianTabush is offline   Reply With Quote
Old 09-30-2012, 08:08 AM   #3973
Dean I didnt you were running a tamiya. Thats 4 at trowse now. (I race there aswell btw) My car has plenty of steering but can be a little on the edge with rear end grip. My brothers trf417 is the opposite, he has loads of rear end grip but his has a bit of understeer.
scytherat is offline   Reply With Quote
Old 09-30-2012, 10:57 AM   #3974
what parts (numbers) do I need if I want to rebuild my 417x dampers to that of the 417WX?
thanks
DPRacing is offline   Reply With Quote
Old 09-30-2012, 11:43 AM   #3975
thanks
Parts are not available yet, they were prototypes new car gets released in December
Saudi Arabia RC Club grizzle Manila Racers 6558 01-06-2017 08:50 AM
Tamiya TRF415 JDM_DOHC_SiR Electric On-Road 21094 03-10-2016 11:02 AM
Tamiya TRF416 / TRF416WE / TRF416X academygaz Electric On-Road 10619 01-01-2015 03:36 PM
Tamiya TA05 IFS rcforum Electric On-Road 1132 12-18-2014 05:19 AM
"Ask" Jilles Groskamp Tamiya 416 & 417, Team Orion Motors JGH Electric On-Road 1996 05-27-2014 06:28 AM
