Old 09-14-2012, 01:31 PM   #3901
Is there a new iteration / variant of the trf 417 coming out that I should wait for if I decide to go the Tamiya route?
BossPlaya is offline   Reply With Quote
Old 09-14-2012, 01:40 PM   #3902
artwork's Avatar
Trader Rating: 56 (100%+)
LOL these threads make me laugh sometimes...Kentech just posted about the new car 417wx and people are asking if there will be a new car coming...I am not slamming on you bossplaya...but sometimes the answer is right in front of you if you look.
I suspect it will be few months before the kit is available, but the 417WX is coming!
Xray | Hudy | Sanwa | R1 Wurks | Avid | Protoform | Proline | 2mm Designs
artwork is offline   Reply With Quote
Old 09-14-2012, 02:08 PM   #3903
Yeah I saw that, but since I'm completely new to the hobby I wanted to make absolutely sure. I'm not gonna make assumptions. I'd rather ask "dumb" questions and get flamed by people like you if it means that more knowledgeable people are gonna point me in the right direction.
Thanks anyways bro.
Old 09-14-2012, 02:23 PM   #3904
artwork's Avatar
Thanks anyways bro.
Either way it is worth waiting for...Tamiya builds a great car and you wont be sorry especially if you plan to run it outside.
Good luck...
Old 09-14-2012, 02:41 PM   #3905
My only concern is the price of the kit and parts. My local track stocks Tamiya parts and there are people that run the car there, so support isn't an issue.
I heard something about leaky diffs and diffs being difficult to deal with on the car? I'm a person with limited time so I want to get a car with minimal issues.
Old 09-14-2012, 02:41 PM   #3906
Jochim_18's Avatar
Originally Posted by CraigM View Post
Not really, if you build them with zero rebound they pull back in for the first few movements then pop back out to about 2mm rebound
Seems like every time I dew build my shocks with zero rebound it's always perfect but it does have a negative rebound when you pull on the shaft I thought this was bad but when I try running the car it handles really well however I stop running my shocks with zero rebound cause I thought having negative rebound is not good... But I guess not
Localrcracing.com - Your premiere source of Radio controlled Racing in central California.
Visaliahobbies.com * SkyRC * casterracingparts.com
Old 09-14-2012, 02:58 PM   #3907
CraigM's Avatar
Trader Rating: 34 (100%+)
top right, search is your friend
if you want minimal issues get an xray
www.facebook.com/mcpheerc
CraigM is offline   Reply With Quote
Old 09-14-2012, 03:40 PM   #3908
At our club its the later X-rays that seem to be pretty delicate (t3 11/12's) the trfs don't break.
Diffs need you to use Vg oil and green slime, in nearly 12months racing since installed Mine don't leak and still feel smooth.
http://www.theRcRacer.com/
TRF419, TBEvo6, TT02, VDF, TRF501x, TRF201, TRF101, Mi5, X-Ray T4-13, BD7 2014, A700 Evo, WR-02G
Qatmix is offline   Reply With Quote
Old 09-14-2012, 03:48 PM   #3909
silverhkswrx's Avatar
Send a message via AIM to silverhkswrx Send a message via Skype™ to silverhkswrx
Speculation on the trf417v3 kit contents? 2.5mm hole-less lower, 2.5 mm upper, one piece servo mount, diff v3.0, aeration dampers, dcjs sounds about right.
SpeedPassion 17.5R powered TRF417X
My son owns: Team Associated RC18R2
(RC18B2 converted to a RC18R)
http://www.tamiya.com/english/rc/manuals.htm
silverhkswrx is offline   Reply With Quote
Old 09-14-2012, 05:39 PM   #3910
Thanks for the info. I really liked the quality of the parts & the look of the chassis (TRF) when I saw the Tc6 & the Trf side by side, not that the quality of the Tc6 seemed poor, it was just a general impression.
Old 09-16-2012, 07:58 AM   #3911
Hi, just a few quick questions.
Ran the car on friday and felt even better then before. Previously I used to run Blue/Yellow springs and 1X/1F rear blocks, and now (Friday) I tried Blue/Blue springs and 1XF/1E. (This combination is slightly narrower than 1X/1F)
The car felt very good, and the tires were screeching a tiny bit in my last race even though I was running on very very old tyres !
The only problem I got was in mid corner , if I held the throttle for a litle too long in a corner, it would spin out at the very midle/exit or the corner. That wouldn't happen often but it did a few time on ONE corner, which was a medium sized corner, and the car would spin ou as described only in that corner.
My question was how could i maybe fix this ? Thought of going White/Blue springs ...
Any recomendation how to get the rear even more planted, or maybe abit more corner speed ?
Cheers
MatJ is offline   Reply With Quote
Old 09-16-2012, 02:54 PM   #3912
CraigM's Avatar
No chance on those carbons, it'll be 2.25 lower and 2.0 upper. Dampers yes, shocks yes, servo mount yes, DCJs MAYBE - if so it'll come with steel spool cups as well. Diff will be the same, maybe the steel gears will be included but probably not since they are only really needed for mod.
Cheers
I don't think tamiya make a 1XF block. If they did it would be incredibly narrow. 1XA is the next narrowest block from X.
I would raise the height of your camber link on the front bulkhead by 0.5-1mm, it sounds like you are getting too much camber change at the front through that corner and making it bite. You could also try a bit more toe out at the front.
Old 09-17-2012, 12:51 AM   #3913
yobouno's Avatar
I'm looking for a TRF417X... I'm wondering if anyone know if there's any online store who has them in stock. I've tried most of the HK shops, non of them have them in stock.
TAMYA M05, TB03, TA05 V2, TRF417X
yobouno is offline   Reply With Quote
Old 09-17-2012, 01:04 AM   #3914
Taman's Avatar
Trader Rating: 64 (100%+)
Try these guys - have bought from them several times - good service
http://banzaihobby.com/index.php?mai...ducts_id=13683
Toms 84C, Nissan R91CP, Porsche 956, TRF 417 V5.
Taman is offline   Reply With Quote
Old 09-17-2012, 06:29 AM   #3915
yobouno's Avatar
Thanks Taman, not the cheapest out there, but hopefully they have one in stock.
Anyone has any wisdom on getting the car built right with a setup to share?
cheers.
Saudi Arabia RC Club grizzle Manila Racers 6558 01-06-2017 08:50 AM
Tamiya TRF415 JDM_DOHC_SiR Electric On-Road 21094 03-10-2016 11:02 AM
Tamiya TRF416 / TRF416WE / TRF416X academygaz Electric On-Road 10619 01-01-2015 03:36 PM
Tamiya TA05 IFS rcforum Electric On-Road 1132 12-18-2014 05:19 AM
"Ask" Jilles Groskamp Tamiya 416 & 417, Team Orion Motors JGH Electric On-Road 1996 05-27-2014 06:28 AM
