Like Tree1Likes
Old 12-20-2010, 11:39 PM   #376
Trader Rating: 31 (100%+)
They had to go change the diff rings again. Now my diff master isn't going to work. Dang!
ittjv is offline   Reply With Quote
Old 12-21-2010, 12:06 AM   #377
crabboy's Avatar
Trader Rating: 58 (98%+)
Hahah i thought the same thing.
Rhys
Rhys Marshall.
crabboy is offline   Reply With Quote
Old 12-21-2010, 12:31 AM   #378
Send a message via MSN to jontang001
HI All
I test my 417 this Sunday, I just say...so Fxxing great!
I copied Jilles's base setup but only keep the steering brace spacer 3mm as the manual. At the start, it got a little understeer. So I changed the rear upper bulkhead spacer from 4 to 3mm and felt better. My conclusion is 417 is better than Mi4 or BD5 in this LiPo dynasty which has more better balance and weight transfer. You don't need to have much "hole" on your chassis then you get good grip. And the upper deck feels more elasticity than older ones.
I'm not a good driver, so waiting for advanced setting!!!
TAMIYA TRF416, EVO5MS, TB03 FullOP
Schumacher Mi4LP, CAT SXII, Cougar
jontang001 is offline   Reply With Quote
Old 12-21-2010, 01:01 AM   #379
izzyracer's Avatar
Trader Rating: 27 (100%+)
Finished my build yesterday. I haven't had a graphite chassis for a while now and I might not know something. What is the easiest way to change the motor and make adjustments. It seem to me unless you use the stock spur gear it's hard to have access to one of the motor mount screws and I can't reach the pinion screw unless I have a special tool. I ended up taking out the upper deck and spur gear before I was able to mount the motor.
Izzy
izzyracer is offline   Reply With Quote
Old 12-21-2010, 03:48 AM   #380
Jack2's Avatar
dont hold me to this, my 417 is still in the mail, but dont you access the pinion grub screw Via the bottom of the chassis?
Schumacher Mi4CX
Mugen MTX & MRX
"He who dies with the most toys wins" - Phil Harris
Jack2 is offline   Reply With Quote
Old 12-21-2010, 03:54 AM   #381
izzyracer's Avatar
Yes, I saw that a couple pages prior to posting but what about mounting the motor. What spur gear around 96 have the holes to access the screw? I'm running 17.5 so I need to run a small size spur than what is provided.
Izzy
Old 12-21-2010, 03:59 AM   #382
Jack2's Avatar
well I know what i'll be doing if my new spurs wont allow motor adjustment, mark where you need to go through and drill holes. only need to be 2-3mm and you could drill 2-4 holes to "even" it up if your really wanted
Schumacher Mi4CX
Mugen MTX & MRX
Old 12-21-2010, 04:03 AM   #383
izzyracer's Avatar
Eh... That is surely one way to do it mate. Thanks!
Izzy
Old 12-21-2010, 04:08 AM   #384
Jack2's Avatar
And I'm sure if you were to only drill one hole, you would never notice the difference, even if you weighed one drilled and one stock, the difference would be 2 pooftenths of 4/5's of 5/8's
Schumacher Mi4CX
Mugen MTX & MRX
Old 12-23-2010, 02:33 AM   #385
Are all the parts available to builds a front ball diff yet? I don't want a gear diff as try are ok for mod but I prefer the extra tuning control of a ball diff for racing 10.5
http://www.theRcRacer.com/
TRF419, TBEvo6, TT02, VDF, TRF501x, TRF201, TRF101, Mi5, X-Ray T4-13, BD7 2014, A700 Evo, WR-02G
Qatmix is online now   Reply With Quote
Old 12-23-2010, 09:45 AM   #386
Trader Rating: 114 (100%+)
RWRacing spurs from Nexus Racing... But you have to drill two 3mm holes to fit the spur assembly.
Chris Furman is offline   Reply With Quote
Old 12-23-2010, 02:44 PM   #387
2-Bad's Avatar
Trader Rating: 24 (100%+)
What size are the diff balls in the 417? Did they change them too?
Yokomo * G Force * Sanwa * SMC * ProSpec
2-Bad is offline   Reply With Quote
Old 12-23-2010, 02:56 PM   #388
izzyracer's Avatar
Same!
Izzy
Old 12-24-2010, 11:44 AM   #389
stitchy's Avatar
More 417 kits and Titanium screw kits have come in
Speedtechhobbies.com
stitchy is offline   Reply With Quote
Old 12-24-2010, 11:46 AM   #390
Are you able to fit a 57 tooth pinion with the stock 111 tooth spur? Or do you run out of space on the motor mount slot?
malkiy is offline   Reply With Quote
Saudi Arabia RC Club grizzle Manila Racers 6558 01-06-2017 08:50 AM
Tamiya TRF415 JDM_DOHC_SiR Electric On-Road 21094 03-10-2016 11:02 AM
Tamiya TRF416 / TRF416WE / TRF416X academygaz Electric On-Road 10619 01-01-2015 03:36 PM
Tamiya TA05 IFS rcforum Electric On-Road 1132 12-18-2014 05:19 AM
"Ask" Jilles Groskamp Tamiya 416 & 417, Team Orion Motors JGH Electric On-Road 1996 05-27-2014 06:28 AM
