Like Tree1Likes
Old 09-05-2012, 03:30 PM   #3841
chrisk's Avatar
Trader Rating: 32 (100%+)
You'll probably find the info in the first couple of pages of this thread.
He's Alive
TAMIYA - SMOKEM - REEDY
smaracing.org
chrisk is offline   Reply With Quote
Old 09-05-2012, 06:22 PM   #3842
Yokomo_Ant3's Avatar
Trader Rating: 29 (100%+)
For those drivers that use Sanwa servo's and want to try the CSO floating servo mount, dont bother. The servo cant be mounted as it hits the steering bellcrank. Just hold off for the proper Tamiya version for sure
Antoni Caretti
Team Yokomo - Racing Performer - Sweep Racing
Yokomo_Ant3 is offline   Reply With Quote
Old 09-06-2012, 05:04 AM   #3843
samshirley00's Avatar
Originally Posted by MatJ View Post
Can you share your setup please ?
I run carpet too, 13.5 (not boosted nor blinky, just a stock 2 year old software). What motor you got, and what temp you reach ?
How big is your track ?
I have a 417 with cut top deck, cut motor mount but not the shock towers from the 417X...
I run sorex 32 or 28 though.
If you say your car was planted, I might try that
I didnt use a setup station or anything, all by eye.
Using a hobbywing sensored motor, with a hobbywing xerum 60a 2.1, with 6000mah 65-130c.The motor gets fairly warm, but not too hot.
400CTS in all 4 shicks, blue's on front, whites on rear i think, tried to get 0 toe in on front, 3 degrees on rear, 5mm ride height with a litthe bit if droop, 5mm hex's, cant remember what holes the suspension go on. The tires get rather hot too, there needs to be 26 shore!
i race on mid small carpet
M chassis racer extraordinaire!
samshirley00 is offline   Reply With Quote
Old 09-06-2012, 06:43 AM   #3844
Nuno Gancho's Avatar
Were may we find some settings for 417x high grip track for 13.5 class.
thanks.
Nuno Gancho is offline   Reply With Quote
Old 09-06-2012, 12:50 PM   #3845
thanks.
http://www.petitrc.com/_forumphp/sheet.php
Just look for your chassis (417 :P)
MatJ is offline   Reply With Quote
Old 09-06-2012, 03:07 PM   #3846
CraigM's Avatar
Trader Rating: 34 (100%+)
thanks.
What surface?
www.facebook.com/mcpheerc
CraigM is offline   Reply With Quote
Old 09-06-2012, 07:01 PM   #3847
Thks, CraigM tarmac, thks for helping
Old 09-07-2012, 01:10 AM   #3848
CraigM's Avatar
Try this, it worked very nicely at TITC. Make sure you use LTC it's the only fast body when the grip is high!
http://www.petitrc.com/reglages/tami...012/index.html
Old 09-07-2012, 01:37 PM   #3849
dc661's Avatar
Trader Rating: 123 (100%+)
I have a nice used 417 in the for sale section if anyone is interested. Tamiya TRF417 with exotek
dc661 is offline   Reply With Quote
Old 09-07-2012, 05:56 PM   #3850
Thank you CraigM. I will test tonight, mean time the race is at night any special secret that can be used.
Old 09-08-2012, 07:29 AM   #3851
Default Cooling Fan direction?
I'm quite certain that there is a better thread to ask this question, but for TRF417 drivers, what is the preferred motor cooling fan direction? in other words, should the air be directed towards the motor, or away?
Strangely enough, I'm getting conflicting responses on my side....
Appreciate!!
mhavlena is offline   Reply With Quote
Old 09-08-2012, 09:11 AM   #3852
Potoczak's Avatar
Trader Rating: 111 (100%+)
Appreciate!!
I have always run my fans blowing on the motor. I guess my question would be is do you put the fan in front of the motor next to the speedo of behind the motor??
Pete Potoczak
Home entertainment specialist
Secure Technologies/ www.stiworldwide.com
Potoczak is offline   Reply With Quote
Old 09-08-2012, 11:03 AM   #3853
Kwikvdub's Avatar
Trader Rating: 90 (100%+)
Send a message via AIM to Kwikvdub
Thumbs up
Originally Posted by Potoczak View Post
......I have always run my fans blowing on the motor..... behind the motor....
Alex Valdes
TQRacing / 360 v2 RC Raceway / Team Downgrade Designs
Kwikvdub is offline   Reply With Quote
Old 09-08-2012, 03:36 PM   #3854
Thanks for the info. I have mine in front of the motor.
According to my LHS, the fan show blow away from the motor much like how it's done on a car. Some people say that cooling is better this way. Just wondering whether anyone has done back to back testing....
Thanks again!!
Old 09-08-2012, 05:54 PM   #3855
Leester's Avatar
Trader Rating: 20 (95%+)
Have a friend who did testing with telemetry on the best fan cooling position. He said that ideally the fan should be placed in front of the motor blowing into it. Can be up to 10-15 degrees cooler than from behind. Problem is with a brushless setup and the speedo in front of the motor, it's hard to get your 3 wire hookup from speedo to motor with the fan in between.
Leester is offline   Reply With Quote
Saudi Arabia RC Club grizzle Manila Racers 6558 01-06-2017 08:50 AM
Tamiya TRF415 JDM_DOHC_SiR Electric On-Road 21094 03-10-2016 11:02 AM
Tamiya TRF416 / TRF416WE / TRF416X academygaz Electric On-Road 10619 01-01-2015 03:36 PM
Tamiya TA05 IFS rcforum Electric On-Road 1132 12-18-2014 05:19 AM
"Ask" Jilles Groskamp Tamiya 416 & 417, Team Orion Motors JGH Electric On-Road 1996 05-27-2014 06:28 AM
