Like Tree1Likes
Old 08-31-2012, 03:31 PM   #3796
CraigM's Avatar
Trader Rating: 34 (100%+)
Originally Posted by Quantra View Post
Could you elaborate please?
I've got some of these mounts on order and I'm not too keen on adding stiffness to my chassis as I'm enjoying the flexy set up right now. So if there is a way I can use these without adding stiffness that would be cool =]
You can put orings between the screws and the sway bar mount which will allow the bulkheads a little flex
www.facebook.com/mcpheerc
CraigM is offline   Reply With Quote
Old 08-31-2012, 07:03 PM   #3797
CraigM's Avatar
Originally Posted by napoleon1981 View Post
For the hole that fits the antenna holder on the floating mount there is no screw hole in the standard lower deck. You can 1) drill a hole in the chassis or 2) take a droop set screw, grind of 3-4mm and thread this in the servo mount so you can put the antenna holder on. I did option 2.
It probably doesn't matter but you have it mounted incorrectly. The 3rd hole in the mount is in front of the other two, so on the standard deck you use the two rear holes. I lined up the two chassis to check btw.
The mount also brought my servo forward by about 1mm and it hit the wiper arm so I had to sand my servo case a little so the rack would move freely
Old 08-31-2012, 08:11 PM   #3798
Thanks! Looks like i have to do the same
napoleon1981 is offline   Reply With Quote
Old 08-31-2012, 08:12 PM   #3799
NolanP's Avatar
I noticed Tower Hobbies listed the 417 as discontinued......is there a 418 in the works?
Mod Touring Car
Mod 12th
Nitro TC
Nitro GT
Wheeler and Mod Buggy
NolanP is offline   Reply With Quote
Old 09-01-2012, 04:07 AM   #3800
Trader Rating: 55 (100%+)
I was wondering the same. Is the 417 really discontinued?
Jamison R is offline   Reply With Quote
Old 09-01-2012, 04:52 AM   #3801
Skitee's Avatar
The TRF cars are limited/special run kits which are not in continous proudction, hence why they apear as discontinued when the production run ends. Tamiya gauges demand and then do another production run as and when they see necessary.
Xray T4 2017 ~ ORCA Vritra VX3 ~ Motiv RC 4.5
Xray T4 2017 ~ ORCA Vritra VX3 ~ R1 Wurks 13.5
Xray X12 2016 ~ ORCA Vritra VX3 ~ Orca TX 4.5
POWERED BY SPEEDZONE USA
Skitee is offline   Reply With Quote
Old 09-01-2012, 07:13 AM   #3802
Quantra's Avatar
I'll give that a go, thank you very much =]
Vince Coleman
Quantra is offline   Reply With Quote
Old 09-01-2012, 09:15 AM   #3803
Can someone post a link to where i can get marc`s snowbirds setup please
as from reading on here thats what alot of people use as a good starting setup
scytherat is offline   Reply With Quote
Old 09-01-2012, 02:39 PM   #3804
stitchy's Avatar
Yep!
Still one left!
Speedtechhobbies.com
stitchy is offline   Reply With Quote
Old 09-01-2012, 06:54 PM   #3805
Dusttt's Avatar
Trader Rating: 123 (100%+)
I don't see touring cars on the TRF site at all under products? has it been like that for a while?
"Whiskey Tango Foxtrot"
Dusttt is offline   Reply With Quote
Old 09-02-2012, 03:15 AM   #3806
CraigM's Avatar
Originally Posted by Blueman Austria View Post
Hy there!
Today i have recieved the new CSO WC Style 417X lower deck.
The drillings and the shape of it are good, but this is the ONLY positive thing about it!
.) The material is no carbon firbe in my opinion.
It looks like the typical carbon patern are printed.
.) The thikness of mine are 2,11mm on the one side and 2,35 on the other !!! (L-R)
.) It is also 19 gramms heavier than the original 417 lower deck.
SO STAY AWAY FROM THE CSO LOWER DECKS !!!!!
yeah mine was not flat either, but I've heard good reports so it's on my car ready for racing this week. We'll see how it gets around in a couple of days
Old 09-02-2012, 11:38 AM   #3807
silverhkswrx's Avatar
Send a message via AIM to silverhkswrx Send a message via Skype™ to silverhkswrx
I have a few issues I would like some help with...
Setup: 417x
1.5* front toe out
3.5* rear toe in
1.5 front camber
2 rear camber
Front spool
Rear gear diff 1000k
45wt oil all 4 dampers
White front springs
Blue rear springs
Alum c hubs
Stiff swaybar front and rear
2.25mm lower deck
2.5 mm upper deck
Issues: waaaay too twitchy. I have a very fast servo, can that be the issue? Should I go back to the stock decks? The rear is too eager to kick out. I feel that once the twitchiness is resolved, this too will be reduced/removed. The twitchiness is at initial turn in Abd my correction does nothing to assist in reducing it.
A local who also raced the 417 said ot was never good on carpet, tge chassis flexed too much. I explained that I now have the stiffer decks and he said he may bring his to do carpet also.
The surface is traction compound soaked carpet. It's very high bite.
SpeedPassion 17.5R powered TRF417X
My son owns: Team Associated RC18R2
(RC18B2 converted to a RC18R)
http://www.tamiya.com/english/rc/manuals.htm
silverhkswrx is offline   Reply With Quote
Old 09-02-2012, 11:50 AM   #3808
Oh, and savox servos do not work well in very high traction situations. The stregenth isn't there and the response time is very low. I hit one wall at a reasonably slow speed and managed to break 6 teeth. The other just stopped working and was very hot to the touch. They both had metal teeth. I switched to 'ol reliable, my Hitec servo. This one was just fine I just feel its too fast.
Old 09-02-2012, 11:52 AM   #3809
Blueman Austria's Avatar
I dont try it. 20gramms extra, and a chassi wich is thiker on one side then the other? Left to right.... No way.
_______________________________________________________________________
TT01, F104, TRF415MSXXMRE07, TB Evo5 Exoten, TB Evo6, TRF417v7, TRF 418........
Blueman Austria is offline   Reply With Quote
Old 09-02-2012, 11:54 AM   #3810
I will post a Setup later which worked great with the thicker decks!!!
Philipp1990 is offline   Reply With Quote
Saudi Arabia RC Club grizzle Manila Racers 6558 01-06-2017 08:50 AM
Tamiya TRF415 JDM_DOHC_SiR Electric On-Road 21094 03-10-2016 11:02 AM
Tamiya TRF416 / TRF416WE / TRF416X academygaz Electric On-Road 10619 01-01-2015 03:36 PM
Tamiya TA05 IFS rcforum Electric On-Road 1132 12-18-2014 05:19 AM
"Ask" Jilles Groskamp Tamiya 416 & 417, Team Orion Motors JGH Electric On-Road 1996 05-27-2014 06:28 AM
