Old 08-21-2012, 06:22 AM   #3751
CraigM's Avatar
Trader Rating: 34 (100%+)
Think you guys are getting confused between CSO lower deck and tamiya carpet top and lower decks.
When I referred to the top deck I meant the new style the team was using at the worlds, I imagine CSO have that on the way too
www.facebook.com/mcpheerc
CraigM is offline   Reply With Quote
Old 08-21-2012, 06:50 AM   #3752
silverhkswrx's Avatar
Send a message via AIM to silverhkswrx Send a message via Skype™ to silverhkswrx
Originally Posted by Cp Grafix View Post
Link please
eBay.com
Search 42233 and 42232
SpeedPassion 17.5R powered TRF417X
My son owns: Team Associated RC18R2
(RC18B2 converted to a RC18R)
http://www.tamiya.com/english/rc/manuals.htm
silverhkswrx is offline   Reply With Quote
Old 08-21-2012, 11:18 AM   #3753
RC MARKET's Avatar
Link please
http://rcmarket.com.hk/product_info....369b7bd0da724c
RC MARKET is offline   Reply With Quote
Old 08-22-2012, 12:36 AM   #3754
Yea i was talking a tamiyas WC lower deck which 0,05mm ticker than CSO's lower deck.
The one without cut out.
CraigM if you buy one please make a review.
Cp Grafix is offline   Reply With Quote
Old 08-22-2012, 01:44 AM   #3755
CraigM's Avatar
Will do, I've ordered with market so it should be shipped soon. I can't see the thickness making much difference but I know in the past CSO have used dodgy carbon so we'll see when it arrives. I have two cars so I can back-to-back the chassis vs the kit one on the same day.
Old 08-22-2012, 07:15 AM   #3756
Hey Guys,
ive got a Problem!
My car is supereasy to drive on Carpet!!! Enough Steering and good grip all around!
But its starts to traction roll and its a little bit on the slow side, but everything ive tried (rollcenter, ackermann, damper oil, springs etc.) doesnt make a big difference in laptime, only on how good the car feels, so i got back to the standard carpet setup from the trf team .
Ive orderd the 2,5mm TRF Chassis and the 2,25mm TRF Topdeck, i think this will solve my problem.
Have anybody experiences with the thicker chassis and topdeck?
Also i see that the TRF Guys sometimes use the medium stabilizer front and rear, i only used the medium in front and the soft in rear, but i think on high grip carpet the medium ones all around will be much better?
Down below is my setup with the Changes im trying (thicker chassis and topdeck, medium stabilizer rear), maybe somebody can look over it and can tell me if its ok?
Im asking because i not get the parts till now...
And also i read on thard about the steering EPA and how you get it equal on both sides, is this important? Because ive build it like the manual says, the servo horn is about 5 offset and ive got different steering epa on my sanwa m11x, i think 90% right and 120% left. So i wonder if this makes a difference on how the car feels?
Greez from Germany!
Philipp1990 is offline   Reply With Quote
Old 08-22-2012, 10:43 AM   #3757
Marek Gadomski's Avatar
Originally Posted by Philipp1990 View Post
Hey Guys,
ive got a Problem!
Greez from Germany!
Glue (CA) edges of FRONT tires, outside between rim and place where tire normally touches carpet
this always work great for me, when u feel car great and don't want to change setup. If this wont work you can always sand off the glue
____________________________________________________
Tamiya TRF 417X-Speed Passion-Thunder Power-KoPropo
marcgadomski@gmail.com
http://www.facebook.com/marc.gad
Marek Gadomski is offline   Reply With Quote
Old 08-22-2012, 11:34 AM   #3758
John.C's Avatar
Trader Rating: 36 (100%+)
You can also try different tire treatment/saucing techniques before going the CA route. How long and how much you apply can yield different results.
- Middle River Hobbies - The Track -
John.C is offline   Reply With Quote
Old 08-22-2012, 11:36 AM   #3759
Hey,
i know that trick, but made it once and i dont like the feel of the car if the edges are glued! ;-) But thanks also!
But ive drove the car on two different Tracks, both Carpet and the car always starts to traction roll... So i think the car generates too much grip generally, thats why ive ordered the thicker chassis and top deck, because even on medium grip carpet (like on not permanent tracks) ive got that feeling, that the car can be stiffer, because its not that fast as it should be! ;-)
But the basic Setup which the TRF Guys use always worked great on my TRF416x and now on the TRF417X (they also use the thicker Chassis on Carpet i think), so i dont want to change a lot, because its so easy and nice to drive!
I will test it this weekend, i just thought someone who allready tested the thicker upper and lower deck can give me a resume! ;-)
Old 08-22-2012, 11:47 AM   #3760
Allready tested different variations with how long i apply it before the run (like 20 minutes till 5 minutes) and only half the front tires, but i cant change the tire sauce because i can only use LRP Top Grip Carpet adhesive as its in the regulation for the LRP HPI Challenge...
I will try the chassis and than i will post a resume as i think, that will solve my problem!
Old 08-22-2012, 12:15 PM   #3761
syndr0me's Avatar
Trader Rating: 32 (100%+)
Try softer springs all around for traction roll. Maybe like yellow/red to start and then work your way back up. You can also try taking out the front camber and adding it back until the traction roll comes back, then back it off again. Or widen the front of the car, like D/D blocks.
I had a terrible time with the car traction rolling at Snowbirds two years ago, and I finally put the long arms on the car which fixed it. It was pretty much the worst week of my life.
Or, throw the car in the trash and buy an XRay. Save the shocks, though, you'll need them.
syndr0me is offline   Reply With Quote
Old 08-22-2012, 12:59 PM   #3762
meccanico's Avatar
Try with PINK and BLUE Yokomo's springs, damper oil 350, glue the front tires, apply additive 20 min. rear and 5 min front.
meccanico is offline   Reply With Quote
Old 08-22-2012, 01:29 PM   #3763
artwork's Avatar
Trader Rating: 54 (100%+)
Hey Guys,
ive got a Problem!
Greez from Germany!
Does the car traction roll on new tires? The only time my Tamiya has ever tractioned rolled was due to tires. Either replace with tires that are new or glue sidewalls. I would imagine it has less to do with setup and more to do with the tires. Top deck and chassis will not help this situation and in some ways may actually make it worse.
Xray | Hudy | Sanwa | R1 Wurks | Avid | Protoform | Proline | 2mm Designs
artwork is offline   Reply With Quote
Old 08-22-2012, 04:34 PM   #3764
Team Speedy's Avatar
Trader Rating: 42 (100%+)
Thumbs up
Off hand, does anyone know the dimension of the Panaracer/Xenon shim that is used to remove the play between the gear and pulley.
Thank you!
Team Speedy is offline   Reply With Quote
Old 08-22-2012, 06:01 PM   #3765
Thank you!
i use panaracer shim for trf smthng like 2x tamiya orginal
Saudi Arabia RC Club grizzle Manila Racers 6558 01-06-2017 09:50 AM
Tamiya TRF415 JDM_DOHC_SiR Electric On-Road 21094 03-10-2016 12:02 PM
Tamiya TRF416 / TRF416WE / TRF416X academygaz Electric On-Road 10619 01-01-2015 04:36 PM
Tamiya TA05 IFS rcforum Electric On-Road 1132 12-18-2014 06:19 AM
"Ask" Jilles Groskamp Tamiya 416 & 417, Team Orion Motors JGH Electric On-Road 1996 05-27-2014 07:28 AM
SEO by vBSEO 3.5.0
