Like Tree1Likes
Old 08-07-2012, 10:24 AM   #3691
jonest's Avatar
New car should be out before end of the year. Why wanna grab the old one?
I'm pretty sure they eud release a WC Ed!
jonest is offline   Reply With Quote
Old 08-07-2012, 03:44 PM   #3692
silverhkswrx's Avatar
Send a message via AIM to silverhkswrx Send a message via Skype™ to silverhkswrx
Those complaining about the 417x price, you might wanna check eBay. There's quite a bit around $600 shipped
SpeedPassion 17.5R powered TRF417X
My son owns: Team Associated RC18R2
(RC18B2 converted to a RC18R)
http://www.tamiya.com/english/rc/manuals.htm
silverhkswrx is offline   Reply With Quote
Old 08-07-2012, 10:31 PM   #3693
scribbler's Avatar
I'm not complaining about the price, I think I have sticker shock. I didn't think I'd see the day when a TC hit $700+. I always expect the Tamiya's to be a bit more on the pricey side.
scribbler is offline   Reply With Quote
Old 08-08-2012, 10:45 AM   #3694
Quantra's Avatar
Hello! Can I ask what sort of front/rear weight distribution is everyone running?
Just had my 417X on 4 sets of scales for the first time and got things balanced up nicely. Currently I have a front/rear weight distribution of 47%/53%. Is that about right? For some reason I think it should be 53%/47%, ie more weight on the front than rear?
Vince Coleman
Quantra is offline   Reply With Quote
Old 08-08-2012, 12:47 PM   #3695
Super Moderator
Cpt.America's Avatar
Trader Rating: 52 (100%+)
Why would you want more weight in the front than the rear?
A big thanks to my sponsors:
- Fantom Racing - www.fantomracing.com -
- Fusion Graphix- www.fusiongraphix.com -
- RCSpecialties -
Cpt.America is offline   Reply With Quote
Old 08-08-2012, 01:16 PM   #3696
MikeO's Avatar
+1
Even at work (machine shop) the more weight I have middle to rear on the parts cart, the less push I have weaving through the mills. I laughed so hard applying racing science to real life, but the 911 isn't the worlds most popular race car for nothing. A neutral to rear weight balance helps the car rotate, but a little weight balance to the front helps on carpet sometimes.
Poorboy Raceway & Hobbies - Mo Speed!
MikeO is offline   Reply With Quote
Old 08-08-2012, 01:24 PM   #3697
nolo148's Avatar
I have a trf417x and have a question on the steering arms. How much mm shims to you put on it so when you tighten the screw the steering is still smooth? When i tighten it the steering arms are locked.
nolo148 is offline   Reply With Quote
Old 08-08-2012, 02:21 PM   #3698
John.C's Avatar
Trader Rating: 36 (100%+)
You'll want to use the specified number of shims from the manual. Front and Rear = 4.5mm. First, ensure that the suspension blocks are completely square when tightening. If the suspension arms still bind simply file/sand down the arms.
- Middle River Hobbies - The Track -
John.C is offline   Reply With Quote
Old 08-08-2012, 02:24 PM   #3699
nolo148's Avatar
Not the arms but the steering arms that connect the turnbuckles to the knuckle. how much mm shims do i put?
Old 08-08-2012, 02:37 PM   #3700
303slowdown's Avatar
Trader Rating: 21 (100%+)
.5mm seems to be what most people run.
Ryan Borgheiinck
303slowdown is offline   Reply With Quote
Old 08-08-2012, 03:06 PM   #3701
gonna get worse as the dollar gets devalued further.
redbones is offline   Reply With Quote
Old 08-08-2012, 03:22 PM   #3702
You want a 3x0.7 shim and a 3x0.1 shim under the bridge on both arms. This is quite clear in the manual.
http://www.theRcRacer.com/
TRF419, TBEvo6, TT02, VDF, TRF501x, TRF201, TRF101, Mi5, X-Ray T4-13, BD7 2014, A700 Evo, WR-02G
Qatmix is online now   Reply With Quote
Old 08-08-2012, 03:29 PM   #3703
Super Moderator
Follow the manual... it's laid out right there.
- RCSpecialties -
Old 08-08-2012, 03:43 PM   #3704
nolo148's Avatar
When i tighten the screws the steering is locked and when its loose theres a bit of play. I thought i needed to put more shims. If i do tighten the screws would that cause to much stress on the servo?
Old 08-09-2012, 01:18 AM   #3705
If that is the case you have not used the correct shims. Check you havent got them muddled up. If they still bind up, then just add 0.1mm shims on each and try them until it doesn't bind.
Saudi Arabia RC Club grizzle Manila Racers 6558 01-06-2017 08:50 AM
Tamiya TRF415 JDM_DOHC_SiR Electric On-Road 21094 03-10-2016 11:02 AM
Tamiya TRF416 / TRF416WE / TRF416X academygaz Electric On-Road 10619 01-01-2015 03:36 PM
Tamiya TA05 IFS rcforum Electric On-Road 1132 12-18-2014 05:19 AM
"Ask" Jilles Groskamp Tamiya 416 & 417, Team Orion Motors JGH Electric On-Road 1996 05-27-2014 06:28 AM
