Old 08-03-2012, 08:35 PM   #3661
Really in stock? Cause I can't find one place. Also, tamiya's website says that the 417 x is discontinued along with other websites.
eman619 is offline   Reply With Quote
Old 08-03-2012, 11:43 PM   #3662
CraigM's Avatar
Trader Rating: 34 (100%+)
Originally Posted by artwork View Post
Where exactly?
I always buy from RC Champ, I'm sure they would have the X or RROC edition
www.facebook.com/mcpheerc
CraigM is offline   Reply With Quote
Old 08-04-2012, 12:59 AM   #3663
Just put together one of these bad boys thanks to Jim at the Mushroom Bowl raceway, his prices are real hard to beat...
Mushroom Bowl Raceway - Tamiya TRF417 - Orion R10 Pro - Durango DESC410r - Tekin RX8-Pro4 4600 - Losi 8ight-e 2.0 - Losi 8ight-Te 2.0 -Tekin 1900 2250 RX8 Savox - Trinity - RevTech - M11x - Hyperion - HUDY - Team Epic - Proline - AKA
ChaseCobra is offline   Reply With Quote
Old 08-04-2012, 08:18 AM   #3664
Ive got a tamiya version 2 gear diff in the back of my car. One of the outdrive seals are leaking and i was wondering wether there are specific seals for the tamiya diff or are they the same as all spec r diffs? same question for the internal gears as il replace them at the same time
scytherat is offline   Reply With Quote
Old 08-04-2012, 02:25 PM   #3665
CraigM's Avatar
V2 diff is completely different spec R. Kyosho orings #ORG05 will fix the leaks
Edit: I discovered today that if you use the mineral diff oils (e.g. the Tamiya VG range) the standard orings don't leak at all even with thin oils
Old 08-05-2012, 01:03 AM   #3666
Thanks craig. What about the diff gears? When i changed the oil when i got the car they looked identical to my spec r diff that was in my mi4
Old 08-05-2012, 01:54 AM   #3667
CraigM's Avatar
It sounds like you have the V1 (black) diff which is the same as Spec R (10t/20t). The V2 (white) diff uses different gears (12t/20t).
Old 08-05-2012, 02:26 AM   #3668
mingnon's Avatar
Thats great to know, Thanks Craig, is on the list for the next order now
---------------------------SMA The Home of GREAT Racing------------------------------
mingnon is offline   Reply With Quote
Old 08-05-2012, 03:42 AM   #3669
chrisk's Avatar
Trader Rating: 32 (100%+)
http://www.feralbatteries.com/Ride-G...tty_p_370.html
Craig is this the front diff putty you use?
TAMIYA - SMOKEM - REEDY
smaracing.org
chrisk is offline   Reply With Quote
Old 08-05-2012, 08:30 AM   #3670
syndr0me's Avatar
Champ only has the Reedy Race version and it's 50904 Yen. That's an expensive alternative until the next kit is released.
syndr0me is offline   Reply With Quote
Old 08-05-2012, 02:46 PM   #3671
No i have the white version 2. I didnt check the tooth count when i had them out. Anyone know anywhere in the uk that will stock the kyosho o rings?
Old 08-05-2012, 02:48 PM   #3672
CraigM's Avatar
Yep
Old 08-06-2012, 02:13 PM   #3673
Sorry for another question. Ive just gone to replace a rear upright on my 417. The parts i have are part number 51333 the same as in the manual (and also on the 416) But the metal snap ring that goes around the cvd to hold the pin in rubs on the upright. Has anyone else had this?
Old 08-06-2012, 02:16 PM   #3674
artwork's Avatar
Trader Rating: 56 (100%+)
This can happen if the ball stud is too long in the rear upright...The ball stud pushes down the material and it can hit the CVA. Either put a shorter ball stud in or just clean out that area with a dremel. should not take much to get it free'd up.
Xray | Hudy | Sanwa | R1 Wurks | Avid | Protoform | Proline | 2mm Designs
artwork is offline   Reply With Quote
Old 08-06-2012, 02:56 PM   #3675
Thanks artwork. Il check this out tommorow when it gets stripped down
Saudi Arabia RC Club grizzle Manila Racers 6558 01-06-2017 08:50 AM
Tamiya TRF415 JDM_DOHC_SiR Electric On-Road 21094 03-10-2016 11:02 AM
Tamiya TRF416 / TRF416WE / TRF416X academygaz Electric On-Road 10619 01-01-2015 03:36 PM
Tamiya TA05 IFS rcforum Electric On-Road 1132 12-18-2014 05:19 AM
"Ask" Jilles Groskamp Tamiya 416 & 417, Team Orion Motors JGH Electric On-Road 1996 05-27-2014 06:28 AM
